FURUTECH FI-E38 (G) Schuko Type E/F Power Connector Gold Plated Ø17.5mm
FURUTECH FI-E38 (G) Connecteur Schuko High-End Gold Ø17.5mm
Schuko mains plug very high performance, ideal for the construction of an Audiophile mains cable without compromise. In addition to its contacts Copper Gold plated, the FI-E38 also benefits from the proprietary anti-magnetism treatment FURUTECH Alpha α.
4.9 / 5
By buying this product you get 33 loyalty points
Reference : 8877
119,00 €tax incl.
99,17 € tax excl.
Shipping date: 30-04-2024.
Shipping from France
Billing in France
Technical support in France
In addition to its contacts Copper Gold plated, the FI-E38 also benefits from the proprietary anti-magnetism treatment FURUTECH Alpha α,which involves 2 steps:
1-Cryogenization of metals by -250 ° C with the aid of liquid nitrogen in order to consolidate their molecular structure and to improve their conductivity significantly.
2- Submission of these same metals to a powerful magnetic field created by means of magnets arranged in rings and whose attraction force is constantly controlled so as to leave no residual magnetic at the end of the treatment.
The FI-E38 also takes advantage of the patented technology "Floating Field Damper System"which makes it possible to eliminate almost entirely the creation of micro-magnetic and electrostatic turbulence zones internally of the plug, disturbances generated by the passage of the current in the vicinityof certain sensitive component parts (metal fixing screws, cable clamping elements, etc.).
These "floating" field micro-fields conflict with the much more powerful primary magnetic flux generated by the current flow through the cable and the connectors, thereby inducing a form of electrical resistance detrimental to conductivity, generate a form of distortion.
FURUTECH manages to master these phenomena by connecting all the metal parts concerned with each other by means of a conductor charged with bringing all these undesirable energies to the earth.
His bodyof composite material nylon and fiberglassinjected from carbon particlesit demonstrates extreme resistance to shocks, electric arcs and high temperatures.
The conductors are fixed by means of3 screws (2 poles + ground) marked with color code and whose firmness of maintenance, obtained thanks to the technology FURUTECH "Wire Clamp", makes it possible to exclude any risk of tearing or accidental deterioration of the cable, while significantly improving the contact surface.
Compatible with cables in the section is included between 6 and 17.5mm in diameter.
Features:
  • contacts Copper Pure Gold Plated
  • Traimagnetism FURUTECH Alpha α
  • Technology Owner "Floating Field Damper System"
  • Nylon Body & Fiberglass Injected Carbon Particle
  • Screw plug (3 screws marked with color code)
  • Patented "Wire Clamp" Cable Tightening Technology (Improved Contact Area of ​​17%)
  • Compatible with Cables with a diameter between 6 and 17.5mm
  • Body Length: 90.5mm
  • Body Diameter: 39.6mm
  • 250V / 10A - 125V 15A
https://www.audiophonics.fr/images2/8877/8877_furutech_FI-38G_connector_1.jpg
https://www.audiophonics.fr/images2/8877/8877_furutech_FI-38G_connector_3.jpg
https://www.audiophonics.fr/images2/8877/8877_furutech_FI-38G_connector_4.jpg
">https://www.audiophonics.fr/images2/8877/8877_furutech_FI-38G_connector_2.jpg
https://www.audiophonics.fr/images2/8877/8877_furutech_FI-38G_connector_5.jpg
https://www.audiophonics.fr/images2/4754_FURUTECH-FI-E38(R)_4.jpg
https://www.audiophonics.fr/images2/4754_FURUTECH-FI-E38(R)_3.jpg
Max cable diameter (mm)17.5
Mounting typeTo screw
ConnecticMale
ConnectorPLug CEE 7/7
Rated current (A)10.0
Rated current (A)15.0
14 reviews
entrer dans le son furutech
Par rapport à une FI 11, le gap est très significatif, je l'ai monté sur du câble furutech 32 et le mariage me convient très bien. C'est à la fois chaud et détaillé, cette prise me parait plus homogène que la 38 au rhodium.
P.S : un sacré bon en avant quand je l'ai monté sur du nordost red dawn.
This review has been posted for FURUTECH FI-E38 (G) Schuko Type E/F Power Connector Gold Plated Ø17.5mm
The best connector, very solid.
Great connector to finish your high end cable. Very solid and good quality.
Excellent
Beaucoup de détails, silences profonds.
Un bon upgrade pour mes Nordost Heimdall 2
charmeuse
Bonjour , schuko furuetch fi 38 mis sur ma murale oyaide or , douceur exquise, medium lisse et plein, aigu doux filé, basse precise et dynamique ,tonalité chaude je dirai pour moi la meilleure schuko que j ai testé ( viborg or ,rodhium,iego or,neotech,charlin, ) bonne construction sans plus, pour systeme un peu dur ou froid le top. Franck
connecteur cable alim source
Par rapport au connecteur FI-E11-N1(G) qu'il remplace, celui ci apporte focalisation et densité des sons sur l'ensemble du spectre et au final un bénéfice certain sur le timbre.
Schuko mains plug very high performance, ideal for the construction of an Audiophile mains cable without compromise. In addition to its contacts...
