FURUTECH FI-E48 NCF (R) Schuko Type E/F Power Connector Rhodium Plated Copper Alpha Treatment NCF Ø20mm
FURUTECH FI-E48 NCF (R) Rhodium Plated Copper Schuko Connector Alpha Treatment NCF Ø20mm
The Furutech FI-E48 NCF (R) is part of the brand's range of connectors incorporating the NCF material and benefiting, as with all Furutech products, from an excellent quality design. It uses high quality components, carefully selected for their performance in audiophile use.
4.7 / 5
By buying this product you get 60 loyalty points
Reference : 13896
309,00 €tax incl.
257,50 € tax excl.
Shipping date: 14-05-2024.
Shipping from France
Billing in France
Technical support in France
Furutech FI-E48M NCF (R) Connecteur Schuko Cuivre Plaqué Rhodium Traitement Alpha NCF Ø20mm
The Furutech FI-E48 NCF (R) is part of the brand's range of connectors incorporating the NCF material and benefiting, as with all Furutech products, from an excellent quality design. It uses high quality components, carefully selected for their performance in audiophile use. The connector contacts are made of pure Rhodium-plated pure copper with Alpha treatment (α). The latter consists of a first cryogenization step and a second demagnetization step, which increases the conductivity of the contacts.
The connector body is made of Nylon and Fiberglass as well as NCF (Nano Crystal² Formula), an anti-resonance material. The latter uses a crystalline material with two active properties. The first is to generate negative ions to eliminate static electricity and the second is to convert thermal energy into infrared. Furutech combines NCF with ceramic nano-particles and carbon powder for a piezoelectric damping effect. The connector shell is made of non-magnetic SUS303 Steel, improving both the durability of the connector and limiting the impact of interference on the signal. The connector also uses an efficient cable holding system, using a metal clamp.
Floating Field Damper System
The magnetic field running through a cable and its connector create a magnetic and electrostatic field around them several times a second. This magnetic field induces current leakage and electrical potential in small components such as screws that hold the connector body and must be made of metal for effective clamping. Current leaks in these components create a magnetic field floating around them and interfering with the larger magnetic field of the cable and connector and generating distortion and noise.
The Floating Field Damper System technology solves this problem by grounding these metal parts. All the different metal parts of the connector are connected to each other and shunt the generated electrical potentials to ground. This significantly reduces noise by reducing distortion for extremely clean and stable energy transfer.
Product typeSchuko Connector
Contacts materialPure Copper, Alpha Treatment (α)
Contacts platingRhodium
Insulation technologyFloating Field Damper System
Connector body materialNylon / Fiberglass and NCF
Damping materialCeramic nanoparticles and carbon powder for piezoelectric damping
Connector shell materialNon Magnetic SUS303 Stainless Steel
Min / Max cable diameterMin : 6mm
Max : 20mm
Connector dimensionsBody: 55.4x Ø39.5mm
Total length: 93.2mm
Cable tightening systemMetal clamps
Weight207.8g
Max cable diameter (mm)20.0
Mounting typeTo screw
ConnecticMale
ConnectorPLug CEE 7/7
Rated current (A)N/A
7 reviews
Excellent
Excellent product. At first the couple of Shuko/IEC with my Acoustic Revive cable sounded very harsh but after 2/3 days it became very smooth and extended. Cost is very high but I really recommend AAA+++
This review has been posted for FURUTECH FI-E48 NCF (R) Schuko Type E/F Power Connector Rhodium Plated Copper Alpha Treatment NCF Ø20mm
Wouah
En premier lieu je tiens à remercier Patrick pour son analyse des prises secteur, super sympa et pro de ta part ;)
Je me suis effectivement décidé à me lancer sur ces connecteurs haut de gamme Furutech et j'aime mieux vous dire que durant le montage j'avais comme une impression de serrage de fesse assez prononcé me demandant si j'avais pas claqué 460€ dans du vent lol. Après avoir monté les Schuko et IEC sur mon Yarbo SP1100, j'ai lancé un cd juste sur mon petit Shanling Tempo. Ma première sensation fut un soulagement personnel; la décontraction revenue je me suis surpris à entendre mes Focal s'amuser avec la musique comme jamais. En effet mon ampli a trouvé plus de sérénité, les timbres, les fines dynamiques, la scène bien en place, tout est là mais en plus maitrisé, le son est plus propre je dirai. J'avais des Viborg qui me donnaient déjà de bons résultats mais là on passe un cran au dessus, c'est assez impressionnant. Prochaine étape, passage de mon dac R7 en Furutech aussi.
Encore merci à Patrick et aussi à Audiophonics, bonne journée à tous
 (4)
Comparative evaluation of six AC connectors.
Le commentaire qui suit est l’exacte traduction de mon commentaire originel en Français.
The following commentary is the exact translation of my original commentary in French.
I carried out comparative tests for two years of the six AC connectors below, which allowed me to finely characterize their strengths and weaknesses.
All these connectors were mounted on the RAMM Amadeus 5 MK2 cable in length of 3 meters (Item no.: 12202); which establishes a common basis of comparison.
(Cable configuration: DOUBLERAMM, cable construction which I describe in detail in the Amadeus 5 MKII cable overview page)
The RAMM Amadeus 5 MK2 OCC Copper cable is completely transparent, a truly natural sound, it acts as a revealer of the personality of the SCHUKO-IEC connectors.
Thus, the dynamics, the definition, the sound scene will be defined by the connected connectors; this cable will always allow the qualities and defects of the connectors to pass.
Astonishing, no? These are the rarely seen abilities of the Amadeus 5.
Real advantage for a comparison. In absolute terms, the Amadeus 5 MK2 cable is a real buy-in whose audio performance is far from the price. For half a century of audiophilia (I'm 60 years old and yes I started young, the music academy educates your ear and not just your ear), you imagine that systems and cables sold at price of Gold, there are full crates, but sometimes, rarely, there is one that emerges and stands out from all the others.
The Amadeus 5 is one of those select few who work for music more than their profit margins ...
That this cable is not better known is a little mystery for me, a strangeness, a paradox ...
The general manufacturing quality of the six connectors presented below is excellent, which is the minimum given the prices charged… With a superlative addition for the FURUTECH E48 and their mirror-polished stainless steel cases connected to the earth, the top "cosmetico-technical"of the six connectors below.
On the other hand, the quality of the screws of the three electrical contacts seems to me unworthy of connectors of this price category; and this for the six connectors evaluated. M3 screws whose indentations break as soon as you tighten a little ... hard, or M4 stainless steel, always one screw per contact, that's sad (even scandalous) .... Suggestion to all manufacturers who sell connectors for several hundred $ each: for your contacts, you put two M5 copper screws (DIN 916, or grub screws) per contact, or even M6, and it will be just normal , thank you in advance….
01: YARBO RHODIUM (Ref. Article: 11020): Mounted on DOUBLERAMM cable 3 meters.
With YARBO / Rhodium connectors, we have a beauty of the timbre difficult to surpass, but a loss in dynamics. A very neutral, very fine and very defined extreme high; more than the OYAIDE M1e.
Formidable in the extreme high, very good in the rest of the spectrum, however, it has difficulties in the areas of dynamics, the separation of instruments ...
A soft and fine connector at the same time, certainly very good for classical music in small groups; not recommended for Rock N’roll….
An excellent choice in the price category 120 € incl. Tax per Schuko-IEC pair.
02: NEOTECH Gold (Ref. Article: 8939): Connectors mounted on DOUBLERAMM cable, length 3 meters.
Overall good connectors, nothing more. Listens better in the bass than in the treble.
Outstanding quality: very dynamic in the bass, its faults are less audible in these registers ...
Notable flaws: lack of definition, its rather rough in the medium, as confused. These connectors have a bit of the sound signature of a Pangea AC14 se MKII.
Poor spatialization, poor instrument separation.
Recommended use: sub-bass or bass; high limit: 300Hz.
The worst of the six audiophile connectors reviewed here ...
Price category: 150 € TTC per Schuko-IEC pair.
03: NEOTECH RHODIUM (Item no.: 10518): Connectors mounted on DOUBLERAMM cable length 3 meters.
Very good connectors, smooth listening from bass to treble.
Very good dynamics, good definition, good spatialization, a little behind the separation of the instruments. Stamps barely worse than those of YARBO Rhodium.
A listening profile that reminds me of Furutech Ag a little worse.
Recommended use: Full range, treble way.
An excellent choice in the price category 170 € incl. Tax per Schuko-IEC pair.
04: FURUTECH E48 Ag (SILVER) (Item no.: 13895): Connectors mounted on DOUBLERAMM cable length 3 meters.
Very, very good connectors, smooth listening from bass to treble.
Very good dynamics, very good definition, good spatialization, good separation of instruments, good timbres. Connectors a little better than the NEOTECH RHODIUM.
Recommended use: Full range, or any way.
An excellent choice in the price category 460 € incl. Tax per Schuko-IEC pair.
05: FURUTECH E48 Rh (RHODIUM) (Item no.: 13896): Connectors mounted on a "doubleramm" cable (section 8.5mm2), ie two RAMM5 cables, 3 meters long.
Exceptional connectors, homogeneous from bass to treble, a master buy in full range use.
Extremely good in definition, dynamics, separation of instruments, spatialization, this connector stands out especially in the treble; or it seems unsurpassed and is without a doubt the best connector of this test in this register.
The high register delivered by this connector is delicately and subtly full of emotions; it makes the music rich, natural and alive, quite simply ...
A "sound flavor" so pleasant to listen to, that happiness ...
A master purchase in the price category 480 € TTC per Schuko-IEC pair.
06: OYAIDE M1e Pt-Pd (Platine-Palladium) (Item no .: 10387): Connectors mounted on a 3-meter "DOUBLERAMM" cable.
With the OYAIDE M1e connectors, we have more dynamics, but the quality of the timbres is slightly lower (compared to YARBO/Rhodium).
OYAIDE connectors have exceptional transients ("fast" cable), and exceptional instrument separation, unique in its genre. The spatialization is extraordinary, each instrument is in its place and it stays there ... A real soundstage in three dimensions !!! However, they have a slightly "bright" high-pitched (beyond eight Kilo-hertz) and barely less definition than YARBO/Rhodium (beyond eight Kilo-hertz).
The low register has exceptional definition, dynamics and depth.
The medium, the vocals, are unmatched in dynamics, clarity, clarity and transparency. The soundstage is incredible and unparalleled, the separation of the instruments is very impressive, perfect, in fact.
The M1e is undoubtedly the best connector of those tested for sub-bass tracks; bass tracks; medium up to +/- 8 KHz. It is however less usable in full-range, because of its slight degradation in listening quality in the treble of 6-8 KHz to the high end of the sound spectrum.
In its register, it seems to me a reference hardly surpassing; the only regret is for its irrational price of 800 $ TTC the Schuko-IEC pair.
This connector is a demonstration of a manufacturer who "found" an excellent combination of plating metals and abuses that in the pricing of this product.
The message is here: if you want to access this quality, you will have to pay a maximum ...
The price of this connector is only justified by its listening performance; I can therefore only tell you (unfortunately and against my will): buy them, the result is spectacular ...
Recommended use: Sub-bass, bass & midrange amplifiers (6-8 KHz limit).
An absolute master buy in the price category of $ 800 including VAT per Schuko-IEC pair.
After numerous tests for over a year, here are my personal choices for the distribution of my AC connectors for my high-fidelity system:
For sources (DAC, crossover, preamplifier, streamer, Mac mini) as well as all-purpose "full range" (amplifier in mono-amplification): The FURUTECH E48 Rhodium. Alternative choice: the OYAIDE M1e-F1 with the treble limitations described in the evaluation, everyone to listen and build their own truth.
For amplifiers: sub-bass, bass, medium: OYAIDE M1e-F1 Platinum-Palladium.
Alternative choice to OYAIDE M1e-F1 (from the preferred choice to the less preferred choice): FURUTECH Rhodium or Silver, NEOTECH Rhodium, YARBO Rhodium (except for an treble where this is very good).
For the treble amplifier: FURUTECH Rhodium; alternative choice for the treble way: FURUTECH Silver, YARBO Rhodium.
Addendum: please note that after many tests in my own system, I found a surprising optimal combination: my DAC Audio-gd R7 (Full range, therefore…) powered by OYAIDE M1e and my treble amplifier by FURUTECH E48 Rhodium . Surprisingly and counter-intuitively, my treble has all the qualities of Furutech Rhodium, full and complete. While one might have feared that the Oyaide-powered DAC had imposed its own treble limitation; which is not the case, ... good surprise ...
The sound in my quad-amplification is therefore optimal at "all stages"; what happiness!
I also want to mention in this comment the effectiveness and relevance of the advice of our online seller Audiophonics. Always attentive to its customers, the sales team has an ability to advise you and offer you alternative solutions that I have not seen in any other. When the time comes to order and it is in stock, shipping is always immediate and the quality of the packaging is always "superlative"; kind the delivery man can swing your precious parcel by over the garden gate without causing any problem ...
On the other hand, if your purchase is not in stock, you will have to be patient ... May I suggest that management do everything possible to avoid stockouts, this will be a win-win plan. Thank you in advance ...
Can I invite you to read my review of the RAMM AUDIO Amadeus 5 MKII cable
(Item no .: 12202).
If you want to know more about the quad-amplification on which all the evaluations were carried out, go to the Ebay site and visit my announcements in the name of the pseudo luculluspatrick, and in particular: Crossover Filtre Actif Marchand XM44/4 "Audiophile edition".
Through these announcements, you can, if you wish, ask me any questions you deem useful ...
(GOOGLE translation…)
 (5)
Evaluation comparative de six connecteurs AC.
J’ai réalisé pendant deux années des essais comparatifs des six connecteurs AC ci-dessous, ce qui m’a permis de caractériser finement leurs forces et leurs faiblesses.
Tous ces connecteurs ont été montés sur du câble RAMM Amadeus 5 MK2 en longueur 3 mètres(Réf. article: 12202); ce qui établit une base de comparaison commune.
(Configuration du câble: DOUBLERAMM, construction de câble que je décris en détail dans la page de présentation du câble Amadeus 5 MKII)
Le câble RAMM Amadeus 5 MK2 Cuivre OCC est totalement transparent, un son vraiment naturel, il agit comme un révélateur de la personnalité des connecteurs SCHUKO-IEC.
Ainsi, la dynamique, la définition, la scène sonore seront définies par les connecteurs raccordés; ce câble laissera toujours passer les qualités et les défauts des connecteurs.
Etonnant, non? Telles sont les capacités rarement vues de l’Amadeus 5.
Véritable avantage pour un comparatif. Dans l’absolu, le câble Amadeus 5 MK2 est un véritable maître-achat dont les performances audio sont sans aucune commune mesure d’avec son prix. Pendant un demi-siècle d’audiophilie(j’ai 60 ans et oui j’ai commencé jeune, l’académie de musique, ça éduque votre oreille et pas seulement votre oreille), vous imaginez que des systèmes et des câbles vendus au prix de l’Or, il y en a des pleines cagettes, mais parfois, rarement, il y en a un qui émerge et se distingue de tous les autres.
L’Amadeus 5 fait partie de ces rares élus qui oeuvrent pour la musique plus que pour leurs marges bénéficiaires…
Que ce câble ne soit pas plus connu est un petit mystère pour moi, une étrangeté, un paradoxe…
La qualité générale de fabrication des six connecteurs présentés ci-dessous est excellente, ce qui est le minimum vu les tarifs pratiqués… Avec un plus superlatif pour les FURUTECH E48 et leurs boitiers en acier inoxydable polis miroir connectés à la terre, le top "cosmético-technique"des six connecteurs ci-après.
Par contre, la qualité de la visserie des trois contacts électrique me semble indigne de connecteurs de cette catégorie de prix; et ceci pour les six connecteurs évalués. des vis M3 dont les empreintes cassent dès que vous serrez un petit peu…fort, ou M4 en inox, toujours une vis par contact, c’est triste(voire scandaleux)…. Suggestion à tous les fabricants qui vendent des connecteurs à plusieurs centaines d’Euros la pièce: pour vos contacts, vous mettez deux vis M5 (DIN 916, soit des vis sans tête)en cuivre par contact, voire M6, et ce sera juste normal, merci d’avance….
01: YARBO RHODIUM(Réf. article: 11020): Montés sur câble DOUBLERAMM 3 mètres.
Avec les connecteurs YARBO/Rhodium, nous avons une beauté des timbres difficile à surpasser, mais une perte en dynamique. Un extrême-aigu très neutre, très fin et très définis; plus que le OYAIDE M1e.
Formidable dans l’extreme-aigu, très bon dans le reste du spectre, il accuse cependant des difficultés dans les domaines de la dynamique, de la séparation des instruments…
Un connecteur doux et fin à la fois, surement fort bon pour la musique classique en petites formations; déconseillé pour le Rock N’roll….
Un excellent choix dans la catégorie de prix 120€ TTC la paire Schuko-IEC.
02: NEOTECH OR(Réf. article: 8939): Connecteurs montés sur câble DOUBLERAMM longueur 3 mètres.
Connecteurs globalement bons, sans plus. Ecoute meilleure dans le grave que dans l’aigu.
Qualité marquante: très dynamique dans le grave, ses défauts sont moins audibles dans ces registres là…
Défauts marquants: manque de définition, son assez brouillon dans le médium, comme confus. Ces connecteurs ont un petit peu la signature sonore d’un Pangéa AC14 se MKII.
Spatialisation pas terrible, séparation des instruments mauvaise.
Utilisation recommandée: voies sub-grave ou grave; limite haute: 300Hz.
Le moins bon des six connecteurs audiophile évalués ici…
Catégorie de prix: 150€ TTC la paire Schuko-IEC.
03: NEOTECH RHODIUM(Réf. article: 10518):Connecteurs montés sur câble DOUBLERAMM longueur 3 mètres.
Connecteurs très bons, écoute homogène du grave à l’aigu.
Très bonne dynamique, bonne définition, bonne spatialisation, un peu en retrait sur la séparation des instruments. Timbres à peine moins bons que ceux du YARBO Rhodium.
Un profil d’écoute qui me fait penser au Furutech Ag en un peu moins bon.
Utilisation recommandée: Full range, voie aigue.
Un excellent choix dans la catégorie de prix 170€ TTC la paire Schuko-IEC.
04: FURUTECH E48 Ag (ARGENT)(Réf. article: 13895): Connecteurs montés sur câble DOUBLERAMM longueur 3 mètres.
Connecteurs très très bons, écoute homogène du grave à l’aigu.
Très bonne dynamique, très bonne définition, bonne spatialisation, bonne séparation des instruments, bons timbres. Connecteurs un petit peu meilleurs que les NEOTECH RHODIUM.
Utilisation recommandée: Full range, ou n’importe quelle voie.
Un excellent choix dans la catégorie de prix 460€ TTC la paire Schuko-IEC.
05: FURUTECH E48 Rh (RHODIUM)(Réf. article: 13896): Connecteurs montés sur câble "doubleramm"(section 8,5mm2),soit deux câbles RAMM5 longueur 3 mètres.
Connecteurs exceptionnels, homogènes du grave à l’aigu, un maître-achat en usage full range.
Extrêmement bons en définition, dynamique, séparation des instruments, spatialisation, ce connecteur se distingue spécialement dans l’aigu; ou il semble insurpassable et est sans aucun doute le meilleur des connecteurs de ce test dans ce registre là.
Le registre aigu délivré par ce connecteur est d’une finesse et d’une subtilité pleine d’émotions; il rend la musique riche, naturelle et vivante, tout simplement…
Une "saveur sonore" tellement agréable à écouter, que du bonheur…
Un maître achat dans la catégorie de prix 480€ TTC la paire Schuko-IEC.
06: OYAIDE M1e Pt-Pd (Platine-Palladium)(Réf. article: 10387): Connecteurs montés sur câble "DOUBLERAMM" 3 mètres.
Avec les connecteurs OYAIDE M1e, nous avons plus de dynamique, mais la qualité des timbres est légèrement en retrait(par rapport aux YARBO/Rhodium).
Les connecteurs OYAIDE ont des transitoires exceptionnelles (câble "rapide"), et une séparation des instruments exceptionnelle, unique dans le genre. La spatialisation est extraordinaire, chaque instrument est à sa place et il y reste… Une véritable scène sonore en trois dimensions!!! Cependant, ils ont un extrême-aigu(au delà de huit Kilo-hertz) un petit peu "brillant" et d’une définition à peine moins bonne que les YARBO/Rhodium(au delà de huit Kilo-hertz).
Le registre grave est d’une définition, d’une dynamique et d’une profondeur exceptionnelle.
Le médium, les voix, sont d’une dynamique, d’une limpidité, d’une clarté et d’une transparence sans équivalent. La scène sonore est incroyable et sans égal, la séparation des instruments est très impressionnante, parfaite, en fait.
Le M1e est sans aucun doute le meilleur connecteur de ceux testés pour les voies sub-grave; grave; médium jusque +/- 8 KHz. Il est cependant moins utilisable en full-range, à cause de sa légère dégradation de qualité d’écoute dans l’aigu de 6-8 KHz jusque l’extrémité haute du spectre sonore.
Dans son registre, il me semble une référence difficilement surpassable; le seul regret est pour son prix irrationnel de 800€ TTC la paire Schuko-IEC.
Ce connecteur est une démonstration d’un fabricant qui à "trouvé" une excellente association de métaux de plaquage et qui abuse de cela dans la tarification de ce produit.
Le message est ici: si vous voulez accéder à cette qualité, vous allez devoir payer un max…
Le prix de ce connecteur n’est justifié que par ses prestations aux écoutes; je ne peux donc que vous dire(malheureusement et à mon corps défendant): achetez-les, le résultat est spectaculaire…
Utilisation recommandée: Amplis voies sub-grave, grave & médium(limite 6-8 KHz).
Un maître achat absolu dans la catégorie de prix 800€ TTC la paire Schuko-IEC.
Après moult essais durant plus d’un an, Voici mes choix personnel de répartition de mes connecteurs AC pour ma chaîne haute-fidélité:
Pour les sources (DAC, filtre actif, préampli, streamer, Mac mini)ainsi que tout usage "full range"(amplificateur en mono-amplification):Le FURUTECH E48 Rhodium. Choix alternatif: le OYAIDE M1e-F1 avec les limitations dans l’aigu décrites dans l’évaluation, à chacun d’écouter et de se construire sa propre vérité.
Pour les amplis: voies sub-grave, grave, médium: OYAIDE M1e-F1 Platine-Palladium.
Choix alternatif au OYAIDE M1e-F1 (du choix préféré vers le choix le moins préféré): FURUTECH Rhodium ou Argent, NEOTECH Rhodium, YARBO Rhodium(sauf pour une voie aiguë ou celui-ci est fort bon).
Pour l’ampli d’aigus: FURUTECH Rhodium; choix alternatif pour la voie aiguë: FURUTECH Argent, YARBO Rhodium.
Addendum: veuillez noter que après de nombreux essais dans mon propre système, j’ai trouvé une combinaison optimale surprenante: mon DAC Audio-gd R7 (Full range, donc…) alimenté par OYAIDE M1e et mon ampli d’aigus par FURUTECH E48 Rhodium. Etonnement et contre-intuitivement, mon aigu a bien toutes les qualités du Furutech Rhodium, pleines et entières. Alors que l’on aurait pus craindre que le DAC alimenté par l’Oyaide eu imposé la limitation dans l’aigu propre à celui-ci; ce qui n’est pas le cas, …bonne surprise…
Le son dans ma quadri-amplification est donc optimal à "tous les étages"; que du bonheur !
Je souhaite aussi évoquer dans ce commentaire l’efficacité et la pertinence des conseils de notre vendeur en ligne Audiophonics. Toujours à l’écoute de ses clients, l’équipe commerciale a une capacité à vous conseiller et à vous proposer des solutions alternatives que je n’ai observé chez aucun autre. Lorsque vient le moment de la commande et que celle-ci est de stock, l’expédition est toujours immédiate et la qualité du conditionnement est toujours de type "superlatif"; genre le livreur peut balancer votre précieux colis par dessus la grille du jardin sans que cela ne pose de problème…
Par contre, si votre achat n’est pas en stock, il faudra faire preuve de patience… Puis-je suggérer à la direction de faire le maximum pour éviter les ruptures de stock, cela sera un plan gagnant-gagnant. Par avance je vous en remercie…
Puis-je vous inviter à aller lire mon commentaire du câble RAMM AUDIO Amadeus 5 MKII
(Réf. article: 12202).
Si vous souhaitez mieux connaître la quadri-amplification sur laquelle ont été effectuées toutes les évaluations, allez sur le site de Ebay et visitez mes annonces au nom du pseudo luculluspatrick, et notamment: Crossover Filtre Actif Marchand XM44/4 "Audiophile edition".
Par le biais de ces annonces, vous pouvez, si vous le souhaitez, me poser toutes questions que vous jugeriez utiles…
 (6)
Not so sweet.
I bought this connector with FI-46. FI-46 is made from satinised aluminium and is light, FI-E48 is made from some steel and chrome coated and is much heavier. Look absolutely different. Inside metal case is thin plastic, where in this thin plastic we screw screws that connect both sides of plug. Very delicate solution if you use thick and rigid cable. I bought once and never more even if it sound like divine.
The Furutech FI-E48 NCF (R) is part of the brand's range of connectors incorporating the NCF material and benefiting, as with all Furutech...
