DAYTON AUDIO ME620C Coaxial Ceiling Speaker Kevlar 35W 8 Ohm 88dB 50Hz - 20kHz Ø16.5cm (The Pair)
DAYTON AUDIO ME620C Coaxial Ceiling Speaker 8 Ohm Ø16.5cm (The Pair)
These ME620C Dayton Audio ME620C loudspeakers are designed for ceiling flush-mounted installation, delivering both high-prepared sound at the top of the spectrum and high bass depth to ensure efficient sound quality in your spaces.
POINTS CLÉS :
  • Woofer 6.5" Kevlar
  • Tweeter 1" Silk
  • Power handling : 35W (RMS)
Reference : 12494
149,00 €tax incl.
124,17 € tax excl.
Shipping date: 30-04-2024.
Shipping from France
Billing in France
Technical support in France
DAYTON AUDIO ME620C
Coaxial ceiling speaker - 6.5" (16.5cm)
dayton audio hauts parleurs de plafond
These Dayton Audio ME620C loudspeakers are intended for recessed installation in ceilings. They will allow you to sound large spaces (home, local, shop...), without sacrificing sound quality.
Incredible sound reproduction
In order to offer a very good sound quality, each speaker has 2 loudspeakers. First, there is a 6.5" cone woofer driver with Kevlar cone, providing high response speed, hot midrange and deep bass, often forgotten by most ceiling speakers. The silk dome tweeter they advance a clear and pure high spectrum.
In addition, these speakers can also be used in a surround system as rear or side speakers.
A very refined design
The Dayton Audio ME620C features a white metal cover that covers the entire speaker. This elegant design makes them almost transparent when mounted on a white ceiling.
Speaker applicationCeiling
Speaker configurationCoaxial
Input rating
Power handlingRMS : 35W
MAX : 70W
Frequency response45Hz - 20kHz
Sensivity89dB @ 1W/1m (+-3dB)
Woofer TypeKevlar
Woofer diameter6.5"(16.51cm)
Tweeter typeSilk
Tweeter size1" (2.54cm)
CrossoverOui
ColorBlanc
Grill typeMetal
Total diameter9.75" (24.77cm)
Depth3.625" (9.21cm)
Mounting hole size8.25" (20.96cm)
Speaker Power (W RMS)35.0
Speaker TypeCeiling Speaker
Speaker TypeMidbass
Impedance (Ω)8
Loudspeaker diameter (mm)165.0
Diaphragm typeCarbon kevlar
Diaphragm typeKevlar
Efficiency / Sensitivity (dB)88.0
Max Linear Excursion (Xmax) (mm)N/A
Lowest frequency (Hz)50
Highest frequency (Hz)20000
Surprenant
Agréablement surpris par la qualité de ces haut-parleurs.
Je les ai, dans mon cas, achetés pour sonoriser ma salle de bain (de 9m²). J'ai fais un essai à blanc, sur la table du salon et je ne trouvais pas de basses, normal me direz vous... Une fois encastrés ces haut-parleurs sont convaincants ! J'avais une bande de plafond droite, de 30 cm puis ensuite le rampant jusqu'au sol donc le diamètre (21cm) est juste parfait. les caches sont magnétiques donc c'est parfait aussi. J'ai couplé ces deux HP avec un module ampli Tinysine TSA3118 qui est juste super ! L'association des deux me convient parfaitement et donne un son vraiment prémios.
This review has been posted for DAYTON AUDIO ME620C Coaxial Ceiling Speaker Kevlar 35W 8 Ohm 88dB 50Hz - 20kHz Ø16.5cm (The Pair)
These ME620C Dayton Audio ME620C loudspeakers are designed for ceiling flush-mounted installation, delivering both high-prepared sound at the top...
