DAYTON AUDIO AMT MINI-8 Speaker Driver Ribbon Tweeter Air Motion Transformer Neodymium 15W 8 Ohm 88dB 3500Hz - 40kHz
Dayton Audio AMT Mini-8 Tweeter Air Motion Transformer 8 Ohm
The Dayton Audio AMT Mini-8 Dayton Audio loudspeakers features an exceptional analysis capability from 5500Hz to over 30Khz coupled with a well known high resolution timbre of a design close to the legendary Heil AMT speakers.
Reference : 10183
34,90 €tax incl.
29,08 € tax excl.
Shipping date: 20-03-2024.
Shipping from France
Billing in France
Technical support in France
This tweeter brings clarity, transient speed, and musical finesse to your design.
The large AMT technology membrane and the high power neodymium motor provide extremely wide bandwidth and high sensitivity.
It uses "Air-Motion" technology to deliver ultra-clean, detailed and dynamic treble.
The pleated ribbon offers a large area of ​​condensed acoustic radiation in a compact chassis, for a very high efficiency and a better management of the power.
Characteristics :
  • Nominal Power (RMS): 15 watts
  • Impedance: 8 ohms
  • Sensitivity: 88 dB @ 1W / 1m
  • Frequency response: 3500Hz - 40000 Hz
  • Resistance DC (Re): 7.92 ohms
  • SMQ: 1.86
  • Qts: 1.84
  • Diameter: 40.5 mm
  • Overall Depth: 23 mm
  • Mounting plate supplied
  • 5 Year Warranty
Speaker Power (W RMS)15.0
Speaker TypeRibbon tweeter
Impedance (Ω)8
Loudspeaker diameter (mm)40.0
Diaphragm typeMylar
Efficiency / Sensitivity (dB)88.0
Max Linear Excursion (Xmax) (mm)N/A
Lowest frequency (Hz)3500
Highest frequency (Hz)40000
Clair et précis
Commandé par deux pour remplacer les aigus de mes enceintes-bibliothèque (max. 8 Ω 5 W), faciles à monter à leur place (la platine fournie avait exactement le même diamètre), offre un son à la fois clair et chaud, mais très orienté (il faut vraiment l'écouter à la pointe du triangle et à hauteur de tweeters).
Livraison en une semaine à La Réunion, excellent emballage carton+mousse d'origine.
Très satisfait !
This review has been posted for DAYTON AUDIO AMT MINI-8 Speaker Driver Ribbon Tweeter Air Motion Transformer Neodymium 15W 8 Ohm 88dB 3500Hz - 40kHz
The Dayton Audio AMT Mini-8 Dayton Audio loudspeakers features an exceptional analysis capability from 5500Hz to over 30Khz coupled with a well...
