PACK DAVIS ACOUSTICS MIA 20 Bookshelf Speakers + FX-AUDIO XL-2.1B Amplifier
PACK DAVIS ACOUSTICS MIA 20 Bookshelf Speakers + FX-AUDIO D302 PRO FDA Amplifier
This package consists of a pair of Davis Acoustics MIA 20 two-way bookshelf speakers and an FX-AUDIO XL-2.1B amplifier. It thus constitutes an almost complete audio system at a low price but still powerful. An ideal set to enjoy a quality reproduction, especially in a small / medium room.
Reference : 13996
195,00 €tax incl.
162,50 € tax excl.
Instead of 239,90 €
Shipping from France
Billing in France
Technical support in France
Pack content
Pack Davis Acoustics MIA 20 + FX-AUDIO XL-2.1B
Speaker Bookshelf 2 Way + Amplifier 2x50W
Pack Enceintes Bibliothèques Davis Acoustics MIA 20 + Amplificateur SMSL SA-36A Plus
This package consists of a pair of Davis Acoustics MIA 20 two-way bookshelf speakers and an SMSL SA-36A Plus Amplifier. It thus constitutes an almost complete audio system at a low price but still powerful. An ideal set to enjoy a quality reproduction, especially in a small / medium room.
Pack Enceintes Bibliothèques Davis Acoustics MIA 20 + Amplificateur FDA FX-Audio D302 Pro
Davis Acoustics MIA 20 Bookshelf Speaker
Smaller model from Davis Acoustics, the MIA 20s benefit from advanced technological solutions that can be found in higher range models. These small 2-way bookshelf speakers are equipped with a 13cm fiberglass driver/midrange driver offering good transient performance while ensuring low mechanical deformation, as well as a 25mm soft dome tweeter made of coated fabric. In addition, the speaker body contains a high quality crossover filter, providing linear listening for long hours of listening without listening fatigue while providing accurate playback. A Bass Reflex system with a large front vent allows you to deliver deep bass. The frontal positioning of these vents allows the MIA 20 to be placed directly against a wall. The 88dB efficiency of these speakers allows them to be associated with all amplifiers on the market.
At the rear, the speaker offers screw terminals that accept banana plugs, but also a system that allows the speakers to be simply positioned against a wall.
Test des Davis Acoustics MIA 20 par On-Mag
" Listening, the Davis Mia 20 are real HiFi speakers that have a lot of charm. For the price at which they are offered, there is not much to complain about. We know of many more expensive ones that sound much worse. "
FX-AUDIO XL-2.1BL Amplifier
Here is the FX-AUDIO XL-2.1BL, an audio amplifier TPA3116D2 complete with bluetooth, AUX jack 3.5mm, and especially a subwoofer output stereo delivering up to 100W under 8 Ohm.
It has 2 inputs on the rear: the first being the 3.5mm jack input, and the second one RCA stereo input. The 3rd way to use it is via bluetooth 4.0, to which it is enough to add the antenna provided (to be screwed behind).
This amplifier with exceptional value for money is also equipped with numerous tone settings: bass, treble adjustment, accessible from the front of the device. This littleamplifier in ultra-compact format will deliver unmatched sounds and performance for this price range.
Qobuzissime for the SMSL SA-36A Plus
(Review by Qobuz)
" This S.M.S.S.L SA-36A Plus switching amplifier may have amazed us even more than the AD18 and A8 models of the brand..."
Test Qobuz
Davis Acoustics MIA 20 Specifications
Product typeSpeakers
Speaker formatBookshelf speaker
PowerNominal: 80W RMS
Max: 110W
Number of way2
Speaker driver number2
Efficiency88dB
Frequency response55Hz - 20kHz
Tweeter25mm, dôme souple
Medium / Woofer13cm, fiberglass
ImpedanceMin. 5Ω
Cutout frequency3000Hz
Bass ReflexFront laminar air vent
Binding post typeScrew binding posts, accept banana plugs
FinishBlack wood
SMSL SA-36A Plus
Amplifier chipTPA3116D2
Power output2x50W @ 4 Ohm
Bluetooth Version4.0
Power supply24V DC (included)
InputsRCA
Bluetooth
3.5mm jack (AUX)
OutputStereo speaker terminals
Dimensions250x188x68mm
Weight322G
Pack content1x Pair of Davis Acoustics MIA 20 speakers
InputSD Card
InputJack 3.5mm
OutputSpeaker terminal
Channel2 (Stereo)
Amplifier chipTPA3118
Power (W)30.0
Le matériel chinois m’étonneras toujours
FX-AUDIO D302 PRO entièrement plug and play aucun drivers usb a installer même sous XP, déactive toute la couche audio du pc pas dommage.
la qualité du son est égale voir supérieur a mon ampli NAD C658 de 10kg , avec la puissance en moins , mais largement suffisante pour sonorisé un salon de 75m²
les enceintes Davis bonnes pour leurs dimensions, rendement pas terrible les basses manque de définition, pour ce prix il ne faut pas rêver non plus .
This review has been posted for PACK DAVIS ACOUSTICS MIA 20 Bookshelf Speakers + FX-AUDIO XL-2.1B Amplifier
This package consists of a pair of Davis Acoustics MIA 20 two-way bookshelf speakers and an FX-AUDIO XL-2.1B amplifier. It thus...
