Here's a stable, regulated linear power supply for any high-quality audiophile DIY project. All the necessary technical refinements are incorporated in this power supply dedicated to audio, and it will work perfectly with your HiFi devices operating at 15V.
This power supply includes a Talema transformer coupled with an AOP 177 for even greater voltage stabilization and control. EMI filtering is also included to eliminate interference created by alternating current (AC). Furthermore, a set of three CLC filters positioned at the input and output of the power supply ensure efficient filtering and guarantee a noise-free signal. Last but not least, a bridge rectifier ensures reliable current stabilization, even during prolonged use. The result is a stable output signal with a noise level not exceeding 200uV when used to its full capacity.
The power supply features an aluminum alloy case for efficient heat dissipation and two DC 5.5/2.1mm jack output. Finally, you can adjust the output voltage on the back of the device by ±0.5V if required.
Input voltage | 220-240V |
Output Voltage / current | 15V 1.5A Max 15V 1A Continuous |
Outputs | 2x Jack DC 5.5/2.1mm |
Input | IEC |
Case material | Aluminium alloy |
Dimensions | 110 x 155 x 63mm |
Weight | 1.114kg |
Package | 1x LHY AUDIO LPS25VA 1x DC 5.5/2.1mm male/male jack cable 80cm 1x power supply cable |
Input | IEC C14 |
Output | Jack DC 5.5/2.1mm |
Color | Black |
Output voltage (V) | 15.0 |
Output current (A) | 1.5 |
Input voltage (V) | 220.0 |
Power Supply | Regulated Linear Power Supply |
