HiVi SWANS DMN-A Dome Medium Speaker 50mm
HiVi DMN-A Haut-Parleur Médium à Dôme 50mm
99,00 €tax incl.
82,50 € tax excl.
Resolutely high-end by its technicality and performance, the DMN-A is equipped with a formwork of reasonable dimensions, characterized on the back by an extended acoustic chamber in order to eliminate parasitic reflections.
Its sophisticated engine uses 2 magnets Neodymiums arranged in sandwich over and over the field platesuperior, in order to create a powerful symmetrical magnetic field limiting the phenomena of distortion.
This technique gives the speaker a uniform dispersion of sound power, even at the most sensitive frequencies, and ensures a smooth and natural coupling with the tweeter.
The frequency curve of the unit is particularly stable from 800Hz to 8000Hz , with deviations never exceed -1.5 dB .
The DMN-A is also capable of very impressive dynamic pulses with sound pressure levels up to 108.8dB peak SPL , which makes its use possible both in a family and professional context.
www.audiophoni<html "alt =" "/>
  • Nominal Impedance:
  • Resonant Frequency: 800Hz
  • Rated Power Output: 60W
  • Sensitivity (2.83v / 1m): 93dB
  • DC Resistance: 4.3Ω
  • Diameter Reel: 50mm
  • Composition Coil: Aluminum Wire Copper Plated
  • Number of Layers: 2
  • Chassis: Aluminum
  • Composition Magnetic Circuit: Double Magnet Neodymium
  • Magnetic Shielding: No
  • Recommended Cutoff Frequencies: > 800Hz / <9000Hz
  • Weight: 0.4kg
HiVi DMN-A: Dimensions
center ">
HiViDMN-A:Frequency Response
HiViDMN-A:Impedance Curve
Colissimo - TNT - SoColissimo
