HiVi SWANS F6 Serious Speaker / Medium Kevlar 6.5 "
HiVi F6 Haut-Parleur Grave/Médium Kevlar 6.5"
Reduced price!
Limited special offer
79,00 €tax incl.
71,10 €tax incl.
59,25 € tax excl.
Shipping date: 23-03-2018.
Orders placed before 1pm (GMT+1) will be shipped the same day (working day).
HiVi's "F" loudspeaker range is a synthesis of all the technological advances made in the last few years in the field of electroacoustics.
It is also the expression of the extraordinary know-how of a team of engineers and music lovers resolutely in the forefront.
Ultra rigid cone from a learned combination of Kevlar and paper
Peripheral suspension in natural rubberGerman-made loudspeaker system that provides long-lasting loudspeaker performance and absorbing parasitic vibrationsoriginating at the surface of the cone
Mobile Crew wound on Kapton support for betterpowerand greaterresistance to heat
Powerful magnetic motor consisting of 2 magnets mounted in symmetrical and ventilated
Magnetic shielding authorizing the use of the unit in a Multimedia or Home Theater configuration
Can be used as a severe / medium unit on a 2-way system ,or as a medium loudspeaker on a 3-way system more sophisticated.
  • Nominal Impedance:
  • Resonant Frequency: 45Hz
  • Rated Power:45W
  • Maximum Power Output:90W
  • Sensitivity (2.83v / 1m): 88dB
  • Resistance DC:/ Strong>6.5Ω
  • Diameter Coil: 25mm
  • Length Coil:14.5mm
  • Mounting Type:Kapton
  • Composition Magnetic Circuit: Ferrite
  • Magnetic Shielding:/ Strong>Yes
  • BL:9.0
  • Hey :6.0mm
  • XmaX:4.3mm
  • Cms:658
  • Qms:3.91
  • Qes:0.38
  • Qts:0.35
  • Mms:18.3g
  • Sd:0.0139m2
  • Vas:16.4L
  • Recommended Type of Load: Bass Reflex
  • Recommended Load Volume: 15L
  • Recommended Cut-Off Frequency -3dB: 42Hz
  • Weight:2.1kg
HiVi F6:Dimensions
HiVi F6:Frequency Response
HiVi F6:Impedance Curve
Colissimo - TNT - SoColissimo
