NEOTECH SOCT-12 Wiring cable Copper UP-OCC PTFE 3.3mm²
NEOTECH SOCT-16 Fil câblage UP-OCC PTFE 1.3mm²
Neotech has long been the leader in cable production using UP-OCC "single crystal" copper developed by Professor Ohno of the Chiba Institute of Technology in Japan.
Reference : 9834
28,90 €tax incl.
24,08 € tax excl.
Shipping from France
Billing in France
Technical support in France
NEOTECH SOCT-12
UP-OCC is 99.99998% pure.
UP-OCC is considered the "nec plus ultra" of conductors used today.
Characteristics:
  • Insulation : PTFE
  • Conductor : UP-OCC (99,99998% pure)
  • Internal diameter : 2.05mm
  • External diameter : 2.80mm
  • 12AWG / 3.3mm²
  • Color : Red
  • Sold by meter
https://www.audiophonics.fr/img/cms/products/8941/UPOCC-1.png https://www.audiophonics.fr/img/p/7/4/4/0/7440.jpg
Diameter (mm)2.8
Length (m)Sold by length
Number of conductors1
Insulation materialPTFE
ShieldingNo
Section (mm²)3.30
Ground / ShieldingNo
4 reviews
Exelent en straps sur bornier d enceinte
J ai confectionné quatre fils avec gaine coton et nylon pour la finition sur des viborg banane cu pl argent qui remplace mes straps de 4mm2 up occ multibrin. Resultat exelent. Grave plus dynamique et puissant plus riche en details. Monté croisé plus med aigus et moins grave. Allié au jmr 1120 cu arg. 2mm2. Equilibre tonal parfait. Plié en une courbe grande. Long des fils 20 cm.
This review has been posted for NEOTECH SOCT-12 Wiring cable Copper UP-OCC PTFE 3.3mm²
Excellent
Un peu cher mais indispensable pour obtenir des résultats de qualité.
Best copper available
I have always preferred single core copper for audio and SOCT is the best I have used.
I'm refreshing a few amps that are in working condition but are getting old. Just for fun I put this 12AWG cable between the internal amp stage and speaker terminals. What a difference! The deep bass became very fluid and there is no hint of harshness in the high frequencies any more. The old wire was 18AWG tinned copper and I only make one change at a time to evaluate the effect. It's a stiff cable so of course you have to secure it for vibration by that is a small price to pay.
 (3)
Intéressant!
Ce type de câble donne une très bonne qualité de transmission partout où on l'utilise. Par exemple on peut l'entourer de gaine coton (pour s'inspirer de la mousse de polyéthylène), ce qui devrait donner un des meilleurs isolants qui soit! Pour les médiums/aigüe, peut-être utiliser plusieurs câble plus fin en parallèle...
Neotech has long been the leader in cable production using UP-OCC "single crystal" copper developed by Professor Ohno of the Chiba...
