MONACOR MRD-180 80W Horn Speaker Driver High Midrange 80W 8 Ohm Ø 2.5cm
Compression Monacor MRD-180 1"
Reference : 1519
125,00 €tax incl.
104,17 € tax excl.
This product is no longer in stock
Medium-high frequency motor, 150 W MAX, 8 Ω.
High-performance, high-performance, professional-grade, high-performance, professional-quality, professional speaker with 12 "and 10" woofer. Replacement SP-30PAX / VC is available as an option, the acoustic values ​​are given for a combination with the MRH-200 horn.
blank.gifImpedance (Z) blank.gif8 Ω
blank.gifResonance frequency (fs) blank.gif800 Hz
blank.gifMaximum bandwidth blank.giffx-19000 Hz
blank.gifCrowds. cutoff (fmax.) (12dB / oct.) blank.gif1800 Hz
blank.gifMaximum power blank.gif180 WMAX
blank.gifNominal power (P) blank.gif80 WRMS
blank.gifPressure sound. (1W / 1m) blank.gif109 dB
blank.gifAngle dispersion (green / sun) blank.gifaccording to flag
blank.gifCoil diameter blank.gif44.4 mm
blank.gifMagnet diameter blank.gif130mm
blank.gifcutting blank.gifaccording to flag
blank.gifMounting depth blank.gifaccording to flag
blank.gifdimensions blank.gifØ 134 mm x 58 mm
blank.gifWeight blank.gif2.75 kg
PDF Download
Speaker Power (W RMS)80
Speaker TypeChambre de compression
Impédance8
Diamétre Haut Parleur (cm)25
Colissimo - TNT - SoColissimo
