AUDIOPHONICS BT60W V2 HiFi USB DAC Amplifier TPA3116 Bluetooth 2x50W / 4 Ohm
AUDIOPHONICS BT60W V2 HiFi USB Amplifier Bluetooth 2x50W
The BT60W V2 is a revised and corrected version of the excellent BT60W amplifier, more powerful and more ergonomic!
4.7 / 5
Reference : 12043
39,90 €tax incl.
33,25 € tax excl.
Shipping date: 30-04-2024.
Shipping from France
Billing in France
Technical support in France
Audiophonics BT60W V2
Bluetooth 5.0 DAC Amplifier 2x50W
Audiophonics offers you a revised and corrected version of the compact but no less excellent BT60W amplifier with version V2. On the menu of improvements: an increase in power and more ergonomic entries.
Small but powerful
Now equipped with two 50W TPA3116D2 amplifier modules, the BT60W V2 will offer you a significant boost of power, ideal for use with a computer, tablet or smartphone as input.
Ergonomics first and foremost!
To adapt to your needs in terms of connections, the BT60W V2 offers a USB input and an auxiliary jack 3.5mm.
You do not want to be constrained by the use of cables and want to stream your music from your sofa? It comes with a Bluetooth 5.0 controller!
As for the audio output, a terminal block allows you to connect the amplifier to your speakers. Finally, the power plug is now placed on the back, much more convenient for wiringopre.
A volume control also allows you to simply adjust the audio level of your device.
The Bluetooth / AUX switching is done automatically by detecting the presence or not of a 3.5mm jack.
An amp yes, but a DAC too
This BT60W V2 offers a great versatility since in addition to being a quality amplifier, it also proves to cover the function of DAC. In addition, the Micro-USB supports a sampling rate of 16bit / 44kHz. What to offer you a sound reproduction of quality!
Designed around a chassis made of black anodized aluminum and white plastic, it is both extremely compact but also very elegant. It can be easily integrated into an audio system or on your desktop.
Connections: Inputs
Micro-USB Soundx1
3.5mm Jackx1
Bluetooth 5.0Yes
Terminal Blocks-
Amplifier Modules2x TPA3116D2
Power2x50W (4Ω)
Bluetooth range10m
SwitchOn / Off
Volume ControllerYes
Power supply (included)12V 5A via Jack DC 5.5 / 2.5mm - Accepts a voltage from 9 to 24V
Miscellaneous
Chassis materialBlack anodized aluminum and white plastic
Dimensions78 x 70 x 38mm
Weight118g
Package
3.5mm Male to RCA Stereo Male to Male Cable1x
3.5mm Male to 3.5mm Jack Cablex1
Power supply adapter 12V 5Ax1
Noticex1
InputJack 3.5mm
OutputSpeaker terminal
Channel2 (Stereo)
Amplifier chipTPA3116D2
Power (W)50.0
34 reviews
Petit par le prix et la taille, mais puissant et musical !
Pour :
- Minuscule, facile à installer n’importe où sur un bureau.
- Gros son incroyable pour sa taille. Changer l’alimentation d’origine 12V 5A par une 19V 4.74A d’un PC portable augmente le son … et le plaisir. NB. Une alim avec prise de terre provoque un ronflement.
- Entrées BT et USB de même qualité (aucun souffle ni crachotement) mais le niveau du BT est plus élevé que l’USB.
- Un décalage image-son apparaît sur certaines vidéos Youtube : basculer alors sur USB au lieu de BT.
Contre :
- Entrée AUX grésille et crachote, à éviter si possible.
Branché sur des JBL L96 (8 Ohms, 89 dB, 125 W) et des Triangle Antal ESW (8 Ohms, 91 dB, 120 W) : que du bonheur musical, des basses profondes et solides, une clarté de son sur toutes les fréquences que je peux encore entendre à 64 ans. Nul besoin de caisson de basses. Pourvu que les enceintes soient bien placées à bonne hauteur, au bon écartement et bien orientées, on obtient une belle image sonore en prime.
Sur des enceintes Surround Eltax AV2000 90W, ça manque de basses par rapport à une enceinte JBL Xtreme II mais le BT60W n'y est évidemment pour rien !
Pour équiper un bureau, je n'ai jamais trouvé mieux à ce jour !
This review has been posted for AUDIOPHONICS BT60W V2 HiFi USB DAC Amplifier TPA3116 Bluetooth 2x50W / 4 Ohm
BT60W étonnant pour sa taille et son prix !
A l'origine, je cherchais à un ampli sous 12 v pour pour constituer une petite chaine autonome.
J'ai été bluffé par la qualité de cet ampli qui, testé sur des bonnes enceintes de salon, n'a presque pas montré ses limites !!
j'en reprend un autre pour remplacer une mini chaine HS.
bien
utilisé pour un bureau, mais testé sur des colonnes Klipsch ......ça le fait bien. Dommage que Qobuz parle d'une sortie casque que je ne trouve pas .....
Presque parfait
Ce petit ampli Bluetooth fonctionne étonnamment bien vu sa taille, le Bluetooth fonctionne jusqu'à 10 mètres environ.
Je n'ai pas mis 5 *, car sur celui que j'ai reçu il y une inversion de phase entre les 2 sorties.
Mini ... ampli, mais il fait le MAXIMUM
Certes ne comparons pas ce "moustique" à certains poids lourds de l'amplification, mais il en fait autant que d'autres coûtant 10 fois plus cher ! Petit, amusant avec un son tout à fait correct, clair et précis sans agressivité; ne le poussons pas dans ses retranchements, mais il en fait beaucoup. Le Blue-tooth porte loin, la liaison filaire avec un platine CD est bonne. RIEN à reprocher pour le prix ! Bravo Audiophonics !
