In-Ear Monitor IEM 8 Ohm 102dB 20Hz-40kHz Black
Hidizs unveils with the MD4 a model of in-ear earphones (IEM) of very high quality, integrating no less than four speakers. These are the result of a long period of R&D of the brand, each element being optimized in the smallest details to provide a sound restitution as rich as precise and immersive.
The Hidizs MD4 combines four custom Balanced Armature drivers, specially developed and optimized over years by the brand's engineers, to deliver incredible sonic performance. Each earpiece features a high-frequency driver for precise, detailed sound, a midrange driver for presence and texture, and two bass drivers to deliver deep, rich bass.
The internal audio transmission structure has been redesigned, with a straight acoustic tube, the result of high-precision 3D printing. It ensures a continuous and clean audio flow from the four BA drivers, reducing frequency overlap between each channel. An architecture that effectively increases sound density while reducing distortion and harmonic resonance. It also contributes to precise filtering for exceptional sound performance.
MD4s accurately calculate the distribution of different frequency bands, reasonably allocating high, ultra-high, mid and low frequencies. This improves the accuracy and clarity for each channel for a perfect sound balance.
The Hidizs MD4 IEMs offer the ability to select one of four sound profiles via a double switch. These different sound signatures make it possible to adapt to different musical genres and listening styles.
Balanced : Classic Hidizs setting, suitable for most musical genres.
Warm : Excellent performance in all frequency bands, enhanced musicality. Especially suitable for folk and pop music.
Treble : High frequency emphasis for increased accuracy. Suitable for rock and electronic music.
Bass : Accentuation of low frequencies, for a more impactful bass. Ideal for classical music.
The MD4 has an elegant and luxurious design, with a meticulously CNC machined aluminum alloy body encircled by a rose gold frame. The amber-finished celluloid faceplate is laser-cut and hand-polished, then coated with a skin-friendly EU IIA-certified medical grade resin.
The earphone connector has an angled design to better fit the shape of the ear. This makes the MD4 very comfortable to wear, even for long listening sessions.
The MD4 cable also benefits from a high quality design, using materials that promote excellent conductivity. It incorporates four interwoven conductors. Two are made of OFC copper, the other two are made of silver.
The MD4 cable is also detachable, each earphone having a 2 pin 0.78mm connector. It is thus possible to easily replace the original cablee.
In order to protect and transport your headphones without damaging them, Hidizs provides with the MD4 a leatherette case with a metal inner layer. This one closes simply with a magnetic system.
Product type | In-Ear monitors |
Drivers | 1x high frequency 1x mid range 2x low frequency |
EQ | 4 profiles : Balanced Warm Treble Bass |
Filter | 3 way |
Impedance | 8Ω @ 1kHz |
Frequency response | 20Hz - 40kHz |
Sensitivity | 102 ±1dB @ 1kHz |
Rated power | 3mW |
Cable conductors | OFC Copper Silver |
IEM connectors | 2 pins 0.78mm gold plated |
Cable connector | Jack 3.5mm gold palted |
Body material | Aluminum alloy, CNC machined Celluloid plate |
Weight | ~ 14g |
Color | Black |
Package | Hidizs MD4 1x Jack 3.5mm cable 1x Leatherette Carrying case 9x Eartips 1x Cleaning brush |
Color | Black |
Impedance (Ω) | 8 |
Efficiency / Sensitivity (dB) | 102.0 |
Lowest frequency (Hz) | 20 |
Highest frequency (Hz) | 40000 |
