DAYTON AUDIO PC105-8 Speaker Driver Full Range 40W 8 Ohm 86dB 80Hz - 15kHz Ø10.7cm
DAYTON AUDIO PC105-87 4 Haut parleur Large Bande 10.1 cm
A full range speaker, compact and beautiful finishes. Ideal for building / repairing a small audio system or as a building block for more complex assemblies requiring multiple speakers of the same type.
4.7 / 5
Reference : 12630
16,90 €tax incl.
14,08 € tax excl.
Shipping date: 30-04-2024.
Shipping from France
Billing in France
Technical support in France
Full Range Speaker PC105-8 4" by Dayton Audio
PC105-87 4 Full range speaker Dayton Audio
Despite its small size, the PC105-8 4" gives a good sound reproduction and is suitable for many uses. It works well when used as a mid-range speaker in a three-speaker system. It can also be used in the design / repair of portable speakers, line arrays, sound bars or any other configuration requiring speaker networking.
PC105-8 4" compact design and natural response
Full Range Speaker Dayton Audio
The cone is fiberglass with a shape designed to respect the signal in a natural way. The coil and the pole are vented to better manage the high power. The PC105-8 4" is equipped with a high energy ferrite magnet for increased performance and efficiency. A harmonious response and true reproduction of the broad spectrum makes it an ideal speaker for single-hp systems..
SPECIFICATIONS
Speaker TypeFull Range
PowerRMS : 40 Watts
Max : 80 Watts
Impedance8 Ohm
DimensionsØ107 mm  x 102 mm
Frequency Response80 - 15000 Hz
Sensitivity86.3 dB @ 2.83V/1m
Coil diameter2.54 cm
Resonant Frequency84.8 Hz
Nominal Diameter4 Pouces / 10.7 cm
DC Resistance (Re)6.7 Ohm
Voice Coil Inductance (Le)0.54 mH
Electromagnetic Q (Qes)0.88
Mechanical Q (Qms)2.29
Total Q (Qts)0.64
Diaphragm Mass including airload  (Mms)4.2g
Mechanical complicance of suspension (Cms)0.84 mm/N
Surface of Cone (Sd)52.8 cm²
Maximum linear excursion (Xmax)2.0 mm
Weight720g
Speaker Power (W RMS)100.0
Speaker TypeFull range
Impedance (Ω)8
Loudspeaker diameter (mm)107.0
Diaphragm typePaper
Diaphragm typeCarbon kevlar
Diaphragm typeGlass fiber
Diaphragm typeTitanium
Diaphragm typeMylar
Diaphragm typePolypropylene
Diaphragm typeComposite alloy
Diaphragm typeFabric
Diaphragm typeAluminium
Efficiency / Sensitivity (dB)86.0
Max Linear Excursion (Xmax) (mm)2.0
Lowest frequency (Hz)80
Highest frequency (Hz)15000
3 reviews
Dayton PC105-8
The product is as I expected.
This review has been posted for DAYTON AUDIO PC105-8 Speaker Driver Full Range 40W 8 Ohm 86dB 80Hz - 15kHz Ø10.7cm
Dayton PC105-8
The speakers have a good quality/price ratio.
Enceintes portables
Utilisé en double dans un caisson portable,très bon rendu. Je ne suis absolument pas un pro donc mon avis est à prendre avec des pincettes, comme on peut s'y attendre cela manque un peu de basses. La prochaine fois je prend une enceinte plus accès basses et je rajoute un tweeter.
A full range speaker, compact and beautiful finishes. Ideal for building / repairing a small audio system or as a building block for more complex...
