Resolutely high-end by its technicality and performance, the DMN-A is equipped with a formwork of reasonable dimensions, characterized on the back by an extended acoustic chamber in order to eliminate parasitic reflections.
Its sophisticated engine uses 2 magnets Neodymiums arranged in sandwich over and over the field platesuperior, in order to create a powerful symmetrical magnetic field limiting the phenomena of distortion.
This technique gives the speaker a uniform dispersion of sound power, even at the most sensitive frequencies, and ensures a smooth and natural coupling with the tweeter.
The frequency curve of the unit is particularly stable from 800Hz to 8000Hz , with deviations never exceed -1.5 dB .
The DMN-A is also capable of very impressive dynamic pulses with sound pressure levels up to 108.8dB peak SPL , which makes its use possible both in a family and professional context.
Specifications:
HiVi DMN-A: Dimensions
center ">
HiViDMN-A:Frequency Response
HiViDMN-A:Impedance Curve
