MONACOR SPH-250CTC Speaker Driver Subwoofer Dual Coil 2x100W 2x8 Ohm 91dB
Monacor SPH-250CTC (Double bobine)
Reference : 1931
155,00 €tax incl.
129,17 € tax excl.
Shipping date: 30-04-2024.
Shipping from France
Billing in France
Technical support in France
Subwoofer Hi-Fi, 2 x 150 WMAX, 2 x 8 Ω
Salad bowl in cast aluminum, double coil, carbon fiber reinforced membrane. For high-quality Hi-Fi subwoofers in medium bass-reflex speakers and in 3-way systems.
blank.gifImpedance (Z) blank.gif2 x 8 Ω
blank.gifResonance frequency (fs) blank.gif20 Hz
blank.gifMaximum bandwidthblank.giff3-3500 Hz
blank.gifFreq. cut. (F max.) blank.gif2000 Hz
blank.gifMaximum powerblank.gif2 x 150 WMAX
blank.gifRated power (P)blank.gif2 x 100 WRMS
blank.gifPressure sound. (1W / 1m)blank.gif91 dB
blank.gifCompliance susp. (Cms)blank.gif0.98 mm / N
blank.gifMoving mass (Mms)blank.gif70 g
blank.gifMechanical resistance (Rms) blank.gif1.7 kg / s
blank.gifMechanical overvoltage. (Qms) blank.gif5.12
blank.gifElectrical overvoltage (Qes) blank.gif0.26
blank.gifFact. total surge (Qts)blank.gif0.25
blank.gifVolume equ. (VAS) blank.gif220l
blank.gifDC resistance. (Re) blank.gif2 x 6.8 Ω / 3.4 Ω
blank.gifInductance coil. (The)blank.gif2 x 1.0 mH / 1.0 mH
blank.gifCoil diameter blank.gif50 mm
blank.gifCoil holderblank.gifKapton
blank.gifHeight windingblank.gif17 mm
blank.gifAir gap heightblank.gif8 mm
blank.gifLinear excursion (X MAX)blank.gif± 4.5 mm
blank.gifTransmitting surface (Sd) blank.gif343 cm2
blank.gifFlight. air displaced (Vd) blank.gif155.7 cm3
blank.gifForce factor (BxL)blank.gif9.6 Tm
blank.gifRef. (No) blank.gif0.8%
blank.gifMagnet diameter blank.gif145 mm
blank.gifMagnet Weightblank.gif42.7 oz.
blank.gifCutting blank.gifØ 229 mm
blank.gifMounting depthblank.gif120 mm
blank.gifDimensionsblank.gifØ 256 mm
blank.gifWeightblank.gif3.8 kg
blank.gifclosedblank.gif35 l
blank.gifbass reflexblank.gif60 l
Speaker Power (W RMS)100.0
Speaker TypeSubwoofer
Impedance (Ω)8
Loudspeaker diameter (mm)250.0
Diaphragm typeCarbon fiber
Efficiency / Sensitivity (dB)91.0
Max Linear Excursion (Xmax) (mm)4.5
Lowest frequency (Hz)N/A
Highest frequency (Hz)3500
