AUDIO-GD MASTER 3 2019 EDITION Balanced Class A Amplifier ACSS 2x 500W 4 Ohm
Audio-GD MASTER-3 2015 Balanced Class A Amplifier ACSS 2x 250W / 8 Ohm
The Master 3 is a symmetrical Class A power amplifier with a neat design and excellent performance.
KEY POINTS:
  • Class A
  • symmetrical
  • ACSS
  • 2x250W 8 Ohms / 2x500W 4 Ohms
Reference : 9712
2 090,00 €tax incl.
1 741,67 € tax excl.
Including 1,00 € for green tax
Shipping from France
Billing in France
Technical support in France
AUDIO-GD Master 3 - Edition 2019
Power Amplifier / Class A Symmetrical ACSS Audio-GD MASTER-3
2019 Edition
Linear Fidelity & Non Negative Feedback
For this 2019 Edition of its Master 3, Audio-GD has updated its Class A amplifier to allow it to offer ever better audio measurements. The brand thus integrates Linear Fidelity technologies into the output circuits and Non-Negative Feedback into the amplifier in general. This particular design allows to obtain a linear response curve as well as a very low distortion level, for a sound reproduction of a very high transparency and this whatever the output level and the reproduced frequency.
Amplifier sublime in every point ...
Audio-GD presents us once again the quintessence of the technology in terms of audio with this amplifier architecture more than neat and clean.
The famous brand of high-fidelity audio offers here an amplifier in the most accomplished form possible with outstanding performance: it delivers 2x 250W under 8 Ohm, and 2x 500W under 4 Ohm.
Every product of the brand is scrupulously tested in all seams with one of the most powerful systems in the world: the Audio Analyzer 2700 Series from Audio Precision.
A sleek and incredibly efficient connectivity
The Master 3 has 4 analog inputs: 2x XLR and 2x ACSS. The output is of course on 2 HP terminals, where you just have to connect your speakers to enjoy.
The result is simple: great musicality, thanks to an exceptional dynamic and a rich sound extremely detailed in all points.
Audio-GD Master-3
Class A
Class A
A class A amplifier has the particularity of having all its active components always in conduction. They fully amplify the input signal, thereby limiting harmonic distortion on the output signal. The outgoing signal of the Master 3 is therefore of excellent quality, due to the absence of this famous distortion of crossing of the alternations of the sinusoids.
Output Power2x250W under 8 Ohm / 2x500W at 4 Ohm
Switch Class A / Class ABClass A up to 10W at 8 Ohm / Class AB from 10 to 250W at 8 Ohm
Output Voltage48V
Input sensitivity94K Ohm (XLR) / <10 Ohm (ACSS)
Frequency Response20Hz - 20kHz to 0.01dB
crosstalk> -115dB
inputs2x XLR / 2x ACSS
Exits2x HP Stereo Terminal Blocks
Food4 transformers, including 2 R-Core for 1500W
Miscellaneous
Consumption130W
Weight40kg
Housing material100% Aluminum
Dimensions480 x 440 x 190mm
Accessories1x Power cable
InputACSS
InputXLR
OutputSpeaker terminal
Channel2 (Stereo)
ClassClass A / AB
Amplifier chipN/A
Power (W)250.0
6 reviews
Une valeur sûre
Je possède la version 2017 (acheté en Juin)
Il est lourd, il chauffe, il est vivant, profond, puissant et délivre la musique avec amour. Jusqu'à ce jour le meilleur ampli que j'ai possédé .
Je confirme l'avis de Frédéric A. : inutile d'essayer les Ampli classe D style Hypex ou Icepower.
This review has been posted for AUDIO-GD MASTER 3 2019 EDITION Balanced Class A Amplifier ACSS 2x 500W 4 Ohm
Pour la musique à l’état pur
D’abord, pardonnez-moi de laisser mon avis ici, alors que l’appareil a été acquis directement de la maison-mère.
Cetains amplificateurs de haut de gamme ont été mis au point en priorisant l’atteinte de spécifications phénoménales, mais aussi, dans la plupart des cas en considérant le résultat à l’écoute. Parmi ces appareils, nous pourrions en nommer plusieurs utilisant des modules de classe d conçus en Europe de Nord. Chez Audio-gd, l’atteinte des meilleures spécifications passe après l’appréciation subjective du produit. Il s’agit davantage de comprendre comment utiliser les mesures pour atteindre le nirvana à l’écoute, plutôt que de viser la contemplation froide et purement intellectuelle d’un rapport de mesure parfait quant au chiffres.
D’où le Master-3. Sur papier, il est largué par tout Hypex qui se respecte, notamment au point de vue du rapport signal bruit et de la distorsion. A l’écoute, on observe toutefois que le Master-3 fait preuve d’une plus grande douceur, tout en restituant une grande quantité de détails comparable et une scène sonore plus convaincante. En prime, les timbres sont supérieur et le fond est plus noir. Pourquoi? Peut-être simplement parce que les spécifications sont obtenues avec une charge qui ne représente un haut-parleur de façon réaliste. Avec cette dernière version du Master-3, Audio-gd a enlevé toute rétroaction. Il en résulte, à ce qu’il me semble, un amplificateur qui fait fi de la charge et performe à haut niveau peu importe celle-ci, qui peut sembler contre-intuitif. La raison de cette écoute fluide, détaillée, remplie d’émotion musicale est peut-être simplement dans le contrôle parfait de l’impédance de sortie en fonction de la demande courant afin de maintenir la tension voulue en tout temps. Cela plutôt de se fier à la rétroaction, qui observe se qui se passe à la sortie, qui elle-même subit des retours de courant correspondant aux retours de membrane. C’est donc l’idée générale que de ne pas observer un signal de sortie compromis
Et ca marche!
Ce compte-rendu est seulement préliminaire parce que l’amplificateur a été reçu il n’a que 4 jours. Des semaines de rodage sont encore requise avant de connaître les vraies limites de l’appareil, mais déjà il surpasse mes amplificateurs mono à base de NC500 sans être pour l’instant aussi rapide dans le bas du registre. Mais c’est le seul avantage réel concédé. Et l’entrée courant n’a pas encore été mise à l’essai...
Bravo à Audio-gd, et à Kingwa, le concepteur. Il s’agit d’une amplificateur exceptionnellement neutre et musical.
 (5)
 (3)
Je complète mon avis du 11 novembre dernier:
J'utilisais initialement des HP Proac Signature. Petites enceintes de très bonne qualité.
Au cas où.... j'ai essayé ma vieille paire de Cabasse Galion (40 ans tout de même et pas une rayure), que je trouvais toujours poussives, empatées. J'avais essayé avec un quad 405, un gros Harman Kardon AVR 7000, un Yamaha RX 3020,..., rien à faire aucune présence. Et la c'est une véritable naissance. Elles n'ont fait que dormir pendant toutes ces années en attendant cet accord avec ce Master 1 et 3. Tout est clair, les enceintes disparaissent dans un tableau de musiciens. L'orchestre symphonique si exigeant est parfaitement restitué, chaque instrument positionné, chaque vibration retransmise, chaque envolée restituée avec une clarté émouvante. Dans un tout autre style, le titre "Thorn in my Heart" (Lisa Ekhal) est maintenant d'une délicatesse émouvante. Elle nous soufle à l'oreil des paroles retranscrites avec une sensualité epoustouflante!
Je n'aurais jamais imaginé pouvoir disposer chez moi d'une restitution sonore aussi authentique!!!
Merci aux ingénieurs et à Audiophonics de nous faciliter l'accès à ce niveau de qualité avec des prix contenus.
 (3)
Toujours au top!
Premier test il y a 9 mois avec Le préampli Master 1. Premier bon en avant! Merci!
Deuxième test aujourd'hui avec l'ampli master 3. Et encore une claque!
Vraiment un couple au top.
En synthèse la qualité du son progresse de façon exponentielle avec la qualité de l'enregistrement....
A chaque fois je découvre de nouveaux détails dans ma collection dématérialisée constituée avec Qobuz.
La musique est parfaitement spacialisée, la signature est neutre. Les basses ne bavent pas, aucune fréquence agressive. On peut pousser le volume sans rien perdre de l'aération d'ensemble. C'est propre, c'est précis, c'est pro.
Faute de place, j'utilise des Proac Signature qui me surprennent toujours.
Il me reste à remplacer mon DAC Naim, trop chaud et pas assez ciselé à mon goût, par le petit dernier d'Audio GD le D77.
L'ES9038Pro est déjà au top, alors en deux fois mono et packagé par Audio Gd, je n'ose imaginer...
Et enfin, un upgrade de toute la connectique finira le travail.
Pour info mes enregistrements sont stockés sur un serveur SOtM SQ1000 qui me satisfait pleinement.
Je tiens sincèrement à remercier Audiophonics pour la qualité de son service et de ses conseils.
La encore c'est propre, rapide, efficace et sincère.
Chaque réponse qui m'est apportée est la bonne. Je n'ai jamais été déçu des avis personnalisés qui me sont donnés.
Cela devient tellement rare d'acheter en confiance que je tiens à le souligner.
Conclusion: rapport qualité/prix imbattable, il faut juste garder les yeux ouverts pour le plaisir...
 (5)
 (3)
Après avoir longtemps admiré l’architecture, les caractéristiques de ce préampli et de l’ampli Master 3 qui va avec, je me suis enfin décidé à franchir le pas.
Car il faut du courage pour résister aux sirènes de la pub, des rédacteurs payés à la ligne ou au compliment et abandonner les marques et leur marketing aliénant pour acheter chinois.
Je ne le regrette pas bien au contraire !
Ces deux appareils pèsent à eux deux près de 60 kg (qui dit mieux) tels que les canons de la vrai Hifi le préconisent depuis des décennies et on en a plus que pour son argent.
En sortie j’ai 2 panneaux Magnepan 20.7, immenses et gourments en courant, qui maintenant sonnent magnifiquement et remplissent parfaitement une grande pièce de 75m².
- l’ampli Master 3 est très classique, chauffe peu, 450w très purs, pousse très fort et en silence entre les plages. Car j’ai connu un gros ampli intégré d’une marque prestigieuse qui vibrait si fort entre les plages…..
- le préampli est une merveille : des aigües fins et déliés jamais agressifs, des détails que je n’avais pas encore entendus comme la respiration de musiciens ou des pages de partition que l’on tourne.
La musique est ample c’est ce qui surprend le plus, les attaques sont très franches et les solos de batterie incroyables. La scène sonore est élargie et beaucoup plus profonde.
Les voix sont extraordinairement présentes, incarnées.
Les basses sont très profondes et parfaitement naturelles et les contrebasses ont enfin une largeur normale ! On entend, on voit, la corde et son grain, l’archet. Quel plaisir !
Mais il faut des enregistrements à la hauteur, la seule limite est là.
L’association de ces deux appareils est une réussite : la main de fer et le gant de velours.
Bref je ne regrette pas mon choix, je regrette de ne pas l’avoir fait plus tôt !
Je remercie Audiophonics d’aller dénicher au bout du monde des produits capables de sonner aussi bien mieux même que ceux que l’on nous présente partout mais cinq ou dix fois moins chers.
 (3)
The Master 3 is a symmetrical Class A power amplifier with a neat design and excellent performance. KEY POINTS: Class A symmetrical...
