LUDIC HEIMDALL Filtered Power Distributor 8 Sockets Aluminum Black
The Ludic Heimdall filtered power distributor effectively eliminates any unwanted interference from the power grid or other connected devices. It thus allows your devices to deliver their full potential for high quality listening.
4.8 / 5
Reference : 15175
179,00 €tax incl.
149,17 € tax excl.
Shipping date: 30-04-2024.
Shipping from France
Billing in France
Technical support in France
Ludic Heimdall
Ludic Heimdall Distributeur Secteur Filtré 8 Prises Schuko Aluminium Noir
The components of this power distributor are concealed under a solid brushed aluminum frame with a damped subframe to reduce mechanical vibrations. The power strip consists of 8 high-quality Schuko sockets. The input is made on an IEC C14 connector and will allow you to use a high-performance cable instead of the supplied one.
The power distributor also includes surge protection to effectively protect your devices. A vumeter on the front panel indicates the operating status of the power strip and an LED illuminates red, indicating the need to control the grounding. Two pushbuttons allow them to turn on or off the two power supply rails independently.
The vumeter only lights up when the "2" button is pressed and line 2 is powered.
Product typeFiltered power distributor
Input voltage220V AC, 50/60Hz
Input1x IEC C14
Outputs8x Female Schuko
Max power3000W
Max load15A
Surge protection
Housing materialBrusshed aluminum
Dimensions31 x 13 x 11cm
Package1x Ludic Heimdall
1x Power cable
Number of sockets8
FilteringYes
6 reviews
Sonorité ample et équilibrée
Belle sonorité de manière générale, aérée et équilibrée. Apport important sur un lecteur CD, plus de densité et de présence, ampleur des graves, aigus plus doux, bien entendu avec un bon câble secteur mais qui s’est révélé encore meilleur avec ce distributeur. Par contre, l’ampli intégré perd nettement en dynamique, donc, retour sur une prise non filtrée. Une prise non filtrée aurait été la bienvenue. Les détails sont soignés, deux interrupteurs souples, vumètre éclairé. Ce distributeur est très bien réalisé.
This review has been posted for LUDIC HEIMDALL Filtered Power Distributor 8 Sockets Aluminum Black
filtre Heimdall
Installé sur des sources : très efficace. Un peu "léger" par rapport à d'autres produits (?...)
Muy bien
He comprado esto desde España en dos días lo tenía en casa. El aparato funciona muy bien y es muy práctico lo de los dos interruptores
Feel and looks perfect
Solid and good feeling, I bought it adviced by audiophonic.
effective product, well constructed
very nicely built product which works well.
Sockets are well spaced so its easy to fit various connections.
online instructions are a bit confusing but Ludic themselves responded rapidly to online questions and provided improved information
The Ludic Heimdall filtered power distributor effectively eliminates any unwanted interference from the power grid or other connected devices. It...
