Module unbalanced to balanced symetrizer DRV134 stereo
Module Kit unbalanced to balanced symetrizer DRV134 stereo
4.6 / 5
Reference : 12571
9,90 €tax incl.
8,25 € tax excl.
Shipping date: 09-05-2024.
Shipping from France
Billing in France
Technical support in France
-DRV 134 balanced module-
This audio module makes it possible to symmetricate all unbalanced HIFI-RCA-CINCH line level signals into balanced XLR signals independently and qualitatively. Equipped with passive quality components, the unbalanced input signal is processed by a DRV134 PDO per side.
This card ensures a high level of fidelity and low noise thanks to this PDO intended exclusively for this use.
It is suitable for the following mounting and drawing cases:
  • Audio sources on analog CINCH-RCA outputs (CD, BluRay, DAC players) to studio and sound equipment, e. g. balanced input mixers.
  • Home theater or HIFI preamplifier with RCA outputs to professional amplifiers with balanced XLR inputs.
  • HIFI preamplifier with RCA outputs to high-end HIFI High-End high-end balanced XLR audio amplifier.
Features:
  • Asymmetric stereo modules, line to symmetrical level
  • Cards supplied assembled
  • Required supply voltage DC 15V recommended (5-24V)
  • DRV134 Symmetric AOP
  • DC voltage regulator 7805
  • Dimensions and weight:
  • Dimensions: 50 x 50 x 22 mm (L x W x H)
  • Centre distances: 43x43mm
  • Weight: 28 g
InputPCB Connector
OutputPCB Connector
Channel2 (Stereo)
5 reviews
High quality
I used this utility board to add a balanced output from preamp to active speakers with XLR inputs. This little beast works great at first glance and delivers clean balanced signal. 100% recommended
This review has been posted for Module unbalanced to balanced symetrizer DRV134 stereo
Rectificatif
Je rectifie mon avis précédent : ce module a été testé à nouveau , le précédent essai ayant été réalisé dans un environnement bruité par l’extérieur.le bruit externe a apparemment disparu; ce module a été plus sensible que le symétriseur à base de NE5532, qui, lui avait fourni un résultat moins détaillé mai exempt de parasites, d'où ma première impression.
Le niveau de détail et la scène sonore s’avèrent meilleurs avec les DRV 134.
Bruit de fond
Bonne idée d'une alim non symétrique, mais le bruit de fond augmente dès qu'elle augmente mème au delà de 5V (tests avec une alim faible bruit : ça ne change rien)
ECCELLENTE ! !
Ordinato domenica, spedito il lunedì e ricevuto giovedì. Imballaggio semplice ma molto efficace: complimenti AudioPhonics!
Dunque io cercavo da tempo una schedina per portare le uscite di un filtro passa basso attivo per subwoofer, da sbilanciate a bilanciate. però avevo due problemi : lo spazio limitato a disposizione, e l'alimentazione del filtro 15 Vcc non duali. Quasi tutti i circuiti RCA/XLR necessitano di alimentazione duale. Io avevo a disposizione invece 15 Volt CC molto ben filtrati, e non avevo nessuna intenzione di aggiungere una alimentazione dedicata, e non avendo lo spazio avrei dovuto aggiungere uno "scatolotto".
Lo spazio libero all'interno del filtro passa basso era di 50-55 /60-65 mm. Questa piccola PCB soddisfa entrambe le mie necessità. Quindi verificato questo, ho ordinato. La scheda si presenta bene, buone le saldature, e SOPRATUTTO DOTATA DI CAVETTI SCHERMATI con relativi connettori. La scheda è sicuramente di costruzione Cinese, ma ripeto di buona qualità Le aree di massa sulla scheda sono più che abbondanti. Nessun circuito integrato è zoccolato, essendo tutti in versione SMD.-SOC, e neppure servirebbe. L'alimentazione in CC della scheda va dai 5Volt ai 24 Volt, io la utilizzo a 15V e funziona benissimo. Non capivo come potessero lavorare due DRV134 senza alimentazione duale. Molto semplicemente il circuito funziona con un LM7805 sul ramo positivo, mentre il ramo negativo viene generato da un LM2662M: semplice e geniale: in sostanza il circuito lavora con +/-5V, ottenuti riducendo i 15 Vcc del filtro passa basso attivo. La scheda penso che abbia una uscita di 2rms per ramo. Proprio quello che mi serviva per pilotare un finale BTL in classe D ! Il circuito ha anche un piccolissimo diodo LED rosso che indica la presenza della alimentazione. La circuitazione di presenta molto "standard" quasi presa da una application note della Texas Inst. La misura della PCB è esattamente quella indicata : 50x50mm e l'ho montata senza nessuna difficoltà nel medesimo case del filtro passa passo. Funziona davvero molto bene, nessun ronzio nessun disturbo. Ancora complimenti a AudioPhonics che riesce a "trovare" questi prodotti!
Bon produit
Bon montage sans condensateur sur le trajet et surtout utilisable en mono tension et montage propre les câbles de raccordement sont fournis donc gros plus
