Stereo Preamplifier Board Low Noise JRC5534 LME49710
Stereo Phono Preamplifier Board Low Noise JRC5534 LME49710
This preamplifier module offers excellent sound performance, with a reproduction marked by great transparency and deep bass. Its careful design has been thought to avoid any sound coloration. It uses four JRC 5534D AOPs mounted on DIP8.
Reference : 15687
34,90 €tax incl.
29,08 € tax excl.
Shipping date: 30-04-2024.
Shipping from France
Billing in France
Technical support in France
Preamplifier board
Stereo low noise JRC 5534D
Module préamplificateur Stéréo faible bruit JRC 5534D
This preamplifier module offers excellent sound performance, with a reproduction marked by great transparency and deep bass. Its careful design has been thought to avoid any sound coloration. It uses four JRC 5534D AOPs mounted on DIP8. These are therefore easily modifiable, allowing you to adapt the sound reproduction of the module according to your listening or your system. The power supply stage is equipped with LM317 and LM337 voltage regulators, allowing to provide a clean electrical signal to the audio circuits. The module is delivered with a volume control card and its potentiometer.
To set the OPA offset to 0mV, use the variable resistors marked "p1", "p2", "p3" and "p4" in the diagram below. Using a voltmeter, measure the following points to obtain a value of 0mV by adjusting the variable resistors:
  • P1 -> measure with a voltmeter at points E and A
  • P2 -> measure with a voltmeter at points E and B
  • P3 -> use a voltmeter to measure at points E and C
  • P4 -> use a voltmeter to measure at points E and D
Product typePreamplifier module
Input1x Analog input on PCB connector
Output1x Analog output on PCB connector
AOP4x JRC 5534D
Amplification gain+12dB
Power supply12-20VAC on screw terminals
Dimensions145 x 76 x 44mm
Weight160g
InputPCB Connector
OutputPCB Connector
Channel2 (Stereo)
This preamplifier module offers excellent sound performance, with a reproduction marked by great transparency and deep bass. Its careful design has...
