Jean-Pierre W.
Excellent module
Idéal pour remplacement d’ampli dans un caisson de basse , ici je l’ai adapté dans un caisson Klipsch avec boomer 38 , je...
Jean-Pierre D.
Préampli musical et propre intéressant dans sa gamme de prix
J'avais le P26, j'ai voulu avoir un préampli moins neutre, avec un son moins clair, ce H26 plus haut en gamme est...
Joseph B.
Très bon produit, conforme aux avis. Niveau son bien mieux que le Bada 5600.
Jamais déçu par toutes les commandes passées.
LITE MV04 volume control module Motorised 2+2 channels - reviews - There are 7 reviews.
Istvan N.
Very nice device, but no standby
What I like:
1. Overall the build quality is very good, the PCB is sturdy, seems to be populated with quality components.
2. Sort of nice surprise: if wired properly, one can control 5(+1) stereo inputs ;)
There are is one thing which I don't like: there is no Standby functionality.
Pay attention when wiring the rotary control. If plugged in incorrectly, the input selection will always go only one way. If wired correctly, turning left will decrease the input number, turning right will increase it. When it gets to the end, it starts from the opposite end.
One question: what is the MON button supposed to do? Press once, the currently selected channel LED blinks, press 2 times, all the LEDs light up for a second.
Istvan N.
Not bad, could've been better
What I like:
2. Sort of nice surprise: if wired properly, one can control 5+1 stereo inputs ;)
There are two things which I don't like:
1. there is no Standby functionality
2. The input selector goes only one way, no matter which direction the rotary is turned. I would've expected that if it's turned to the left, the inputs are switched by decreasing order, and if turned to right, the other way around...
jean paul g.
JLG
produit excellent je l'ai associé à mon ampli tubes pour commander mes entrées USB, optique, etc, le tout enfermé dans un boitier métallique non relié aux masses de l'électronique .pas de bruit de fond .....super
Elsa A.
Bon mais incomplet...
Bonne qualité de signal (la telco est opérante à plus de 8 m )et de commutation, dommage que seule la LED du canal1 fonctionne, les autres restent éteints...
la façade du pot est à la masse, je l'ai isolée du boitier pour éviter une boucle de masse, à chacun de voir...
Philippe H.
Attention les résistances R17 et R18 sont absentes, n'oubliez pas de les commander si vous ne souhaiter pas la remise à zéro du volume à l'allumage et à chaque changement de voie.
eden D.
Les valeurs données pour R17 et R18 sont fausses :
R17=10R --_ pas de reset du volume à chaque changement de canal!
R18=10R --_ pas de reset du volume à la mise sous tension!
Nécessiterait des liaisons blindées pour les parties modulation!
Frederic g.
Super rapport qualité. Idéal pour ce monter un petit pré ampli sans se soucier de la fonction sélection de source et commande de volume.
