MUNDORF MRESIST SUPREME MRES20-2.2 Resistor 20W 2.2 Ohms
Resistance MResist Supreme 20W 2.2 Ohm
The Mundorf MResist SUPREME resistance range offers products of exceptional quality. Having a real impact on the sound restitution, these resistances allow to obtain finer details and a much better spatialization.
Reference : 4067
11,90 €tax incl.
9,92 € tax excl.
Available
Shipping date: 12-12-2018.
Orders placed before 1pm (GMT+1) will be shipped the same day (working day).
Mundorf MResist SUPREME MRES20-2.2
Mundorf resistor MRES20-2.2
The Mundorf MResist SUPREME resistance range offers products of exceptional quality. Having a real impact on the sound restitution. This type of resistance allow finer details and a much better spatialization.
The structure of this resistance is composed of two wires 1Ω wound around a heat-resistant cement, this design stabilizes the inductance and maintains its value under 75µH.
Moreover, the resistors of the MResist SUPREME range are very useful for electronic systems designed for a deep neutrality in the sound reproduction. Thanks to a fire-resistant special molding compound, the resistance winding is stable and maintained in its optimal position, thus preventing the circuit from microphonic effects.
Finally, to guarantee a high quality sound even with heavy loads, a special Copper/Nickel alloy is applied as conductor with a positive and extremely low temperature coefficient of 50ppm/°C.
Resistance2.2 ±2%
Power20W
Body dimensions of the resistance51 x ⌀ 14.4mm
Wires dimensions40 x ⌀ 1mm
Colissimo - TNT - SoColissimo
la Formule 1 de la résistance
Mundorf MResist Suprême 2R2 :
Suite à la modification de mes Klispch RF5 qui sont maintenant équipées de condensateurs Mundorf en gamme EVO et Suprême, je voulais finaliser mon tweak en changeant la résistance d'origine par une Mundorf MResist Suprême, une modification pour laquelle je ne pensais pas qu'elle serait aussi pertinente et efficace.
Le fait d'avoir remplacé tous les condensateurs par des Mundorf avait déjà amélioré largement la richesse des timbres des instruments et la manière d'articuler la musique, mais même si elles respiraient fort bien ^^ il leurs manquait juste la MResist qui leurs a redonné encore plus de vie et de fougue qu'avant!!!!! comment l'expliquer ? si ce n'est que la résistance d'origine ralentissait considérablement la musique et je n'avais pas conscience jusqu'à tel point cela puisse être autant perceptible, pour ma part ce gain en rapidité est juste simplement inespéré et surprenant, je ne m'attendais pas à autant d'amélioration pour le simple fait d'avoir changé cette résistance.
J'ai goûté à la Mresist et le gain apporté est réel ! en simplifiant et en imageant ce changement bénéfique '' comme pour internet, la Mresist vous fait passer du bas débit au haut débit pour un coût dérisoire contenu du bien fait qu'elle apporte.
J'ai longtemps hésité à changer cette résistance dans le doute que cela n'apporte guère mieux, si j'avais eu conscience du gain ! je n'aurais pas hésité une seconde et j'aurais adopté la MResist plus tôt pour profiter de son indéniable qualité.
Je remercie toute l'équipe Audiophonics pour leur réactivité et la qualité de leur support technique pour lequel on peut être rassuré, car en effet il y a une vraie équipe de professionnels derrière toujours présente et réactive pour répondre aux questions d'ordres techniques dans les plus brefs délais.
This review has been posted for MUNDORF MRESIST SUPREME MRES20-2.2 Resistor 20W 2.2 Ohms
The Mundorf MResist SUPREME resistance range offers products of exceptional quality. Having a real impact on the sound restitution, these...
