AUDIOPHONICS HA-B6120 Full Balanced Headphone Amplifier TPA6120 MUSES8920
AUDIOPHONICS HA-B6120 Amplificateur casque symétrique MUSES8920
The Audiophonics HA-B6120 is a balancedheadphone amplifier with excellent sound reproduction thanks to its high-quality design and the use of high-performance components. Thus, the amplifier stage of the device embeds a TI TPA6120 chip allowing the HA-B6120 to develop an important power in order to accompany high sensitivity earphones as well as high impedance headphones.
Reference : 14573
189,00 €tax incl.
157,50 € tax excl.
Shipping from France
Billing in France
Technical support in France
Full Balanced Headphone Amplifier MUSES8920
Audiophonics HA-B6120 Amplificateur Casque Symétrique MUSES8920
The Audiophonics HA-B6120 is a balanced headphone amplifier with excellent sound reproduction thanks to its high-quality design and the use of high-performance components. Thus, the amplifier stage of the device embeds twp TI TPA6120 chips allowing the HA-B6120 to develop an important power in order to accompany high sensitivity earphones as well as high impedance headphones. The amplifier also offers a gain selector on the front panel to match your listening device. This amplifier stage is associated with an input stage, based on double J-FET MUSES8920 AOPs in buffer, offering excellent technical characteristics.
The balanced structure of the HA-B6120 allows a reduction in distortion (0.001%) and an improvement in dynamics for a precise, rich and lively reproduction. The amplifier has a balanced XLR input, a balanced XLR 3-pin headphone output and a balanced XLR 4-pin headphone output. For added versatility, the HA-B6120 also features an unbalanced input on stereo RCA and an unbalanced headphone output on 6.35mm jack. A front-panel switch allows simple selection of XLR or RCA input.
For the rest, the amplifier benefits from an optimized design to deliver a beautiful sound reproduction, in particular through the integration of quality components such as WIMA capacitors, Philips diodes, an ALPS potentiometer or Neutrik connectors. It also incorporates an effective protection system, checking the status of the left and right channels and protecting your headphones. The integrated linear regulated power supply provides a clean electrical signal to all circuits.
Product typeBalanced headphone amplifier
Amplification chipDual TI TPA6120
Inputs1x Balanced stereo XLR
1x Single-ended stereo RCA
Outputs1x Balanced stereo 3 poles XLR
1x Balanced stereo 4 poles XLR
1x Single-ended stereo Jack 6.35mm
Gain switchH (High)
L (Low)
SensitivityL (Low): 1.40V RCA
H (High): 0.70V RCA
L (Low): 2.80V XLR
H (High): 1.40V XLR
Output level9V (RCA)
18V (XLR)
Frequency response2Hz - 20kHz
Distortion0.001%
Accepted impedances18 - 600 Ohm (Recommended: 300 Ohm and above)
Housing materialAluminium
ColorFront panel: Black
Rest of the housing: Silver
Dimensions (without connectors)25.2 x 16.1 x 6.2mm
Weight1.94kg
Power cableNot inclued
InputXLR
OutputJack 6.35mm
ColorSilver
ClassN/A
10 reviews
ampli casque
Super son . Utilisé avec connexion symétrique casque Audio technica
This review has been posted for AUDIOPHONICS HA-B6120 Full Balanced Headphone Amplifier TPA6120 MUSES8920
ampli casque symétrique
très bon ampli symétrique (surtout).Je l'utilise sur un dac smsl : nickel ! Son précis et ample sur audio technica ATH MSR7b.Merci pour les renseignements sur service technique (David Aubert).
Quel ampli
Moi, qui recherche toujours des test a gauche ou à droite avant de choisir.... Ce coup ci j'y suis allée un peu a l arrache, le son est formidable avec mon focal celestee, de plus le s.a.v répond très rapidement. Première commande et sans doute pas la dernière. Encore merci
Y A PAS PHOTO !
Nouvel ampli casque ....j'en suis ravi ! ...après déception sur déception , j'ai enfin trouvé celui qui me convient . Puissance, précision du message, plans respectés . Conseils d'Audiophonics bienvenus ! Merci.
AUDIOPHONICS HA B6120
Excellent ampli qui remplace avantageusement un ampli tubes qui manquait de puissance.
Rapidité d'envoi sur le site.
The Audiophonics HA-B6120 is a balancedheadphone amplifier with excellent sound reproduction thanks to its high-quality design and the use of...
