ARYLIC COBBLESTONE WiFi Receiver AirPlay UPnP DLNA Multiroom 24bit 192kHz
ARYLIC MÜZO COBBLESTONE WiFi Receiver Preamplifier 24bit 192kHz
The Arylic Cobblestone is a WiFi receiver that allows you to easily and efficiently stream your files from your network, smartphone/tablet or your favorite streaming services. The original design of the Cobblestone makes it a real decorative object that can easily be integrated into a living room or bedroom.
4.0 / 5
Reference : 13866
59,90 €tax incl.
49,92 € tax excl.
Shipping from France
Billing in France
Technical support in France
Arylic Cobblestone
WiFi Receiver 24bit 192kHz
Arylic Müzo Cobblestone Récepteur Préamplificateur WiFi 24bit 192kHzArylic Müzo Cobblestone Récepteur Préamplificateur WiFi 24bit 192kHz
Arylic Cobblestone Récepteur WiFi AirPlay UPnP DLNA Multiroom 24bit 192kHz
The Arylic Cobblestone is a WiFi receiver that allows you to easily and efficiently stream your files from your network, smartphone/tablet or your favorite streaming services. The original design of the Cobblestone makes it a real decorative object that can easily be integrated into a living room or bedroom. Indeed, it adopts the soft curves and appearance of a pebble, bringing a Zen touch to your room. Only 3 touch buttons are located on the top of the device to control the playback of your music.
Getting started is very simple since it is enough to connect the Arylic Cobblestone to your network, connect the device to your HiFi system and then connect to the same network with your smartphone/tablet. Cobblestone supports AirPlay, DLNA, UPnP and Spotify Connect protocols.
Multiroom & Multizone
The Arylic Cobblestone will allow you to create a true Multiroom and Multizone system. All you need to do is use several Cobblestones in your home and then stream your music seamlessly into all your rooms. Using a control application will allow you to play the same audio stream in each room (multiroom) or select a file / playlist for each room (multizone).
Müzo Player & iEast Play App
These free mobile applications available on both Android and iOS will allow you to easily and remotely control the playback of your music, with an area management system. By connecting to your local network, you can then select the files stored on your computer / NAS, smartphone or use streaming services such as Qobuz, Spotify or Tidal.
The Qobuz streaming service is only available on the iEast Play application.
Mise en place et utilisation
Product typeWiFi Receiver
Supported sampling rate24bit 192kHz
Supported file formatsFLAC, WAV, APE...
Supported streaming servicesQobuz, Spotify, Tidal, Napster, Tune In, iHeartRadio....
Supported protocolsSpotify Connect, AirPlay, DLNA, UPnP
Multiroom / MultizoneYes
Android / iOS AppiEast Play, Müzo, 4Stream, Bubble UPnP...
Supply voltage5V DC (power supply included)
Dimensions138 x 126 x 35mm
ColorCobblestone effect
Package1x Arylic Cobblestone
1x Jack 3.5mm cable
1x Jack 3.5mm to RCA cable
1x Power adapter 5V
1x USB-A to Micro USB cable
InputRJ45
InputWiFi
OutputJack 3.5mm
ColorOther
ColorGray
2 reviews
L'efficacité liée à la simplicité
Simple d’utilisation et efficace il ne faut néanmoins pas lui demander des performances extrême. il faut l'associer à du matériel plutôt de bonne facture pour avoir un plaisir sonore digne d 'audiophile et de mélomane. Cependant je cherchais une solution simple et efficace sans passer par google chrome, et donc , sans allumer ma télé, ce petit matériel esthétique de sir quoi fait le job a merveille. Il a le mérite d’être à la fois beau mais aussi sa petite surface faite d'une matière proche du velours ajoute à l’expérience sonore et visuelle une expérience tactile intéressante.
Tout ceci dans un petit objet.
This review has been posted for ARYLIC COBBLESTONE WiFi Receiver AirPlay UPnP DLNA Multiroom 24bit 192kHz
Bon boitier
J'ai deux lecteurs iEast depuis plusieurs années et j'enrage régulièrement avec des pertes de connexion, des coupures lors de la lecture...
Je les utilise pour écouter Qobuz.
Pour installer à la campagne, j'ai d'abord acheté des Chromecast qui sont catastrophiques lorsqu'ils sont pilotés par un : il est très difficile de lancer la lecture, le son apparaissant parfois... ou pas ! Probablement un problème de compatibilité avec Apple.
Pour les remplacer, j'ai donc acheté un Arylic qui fonctionne parfaitement. L'installation est très simple et le pilotage avec l'appli iEast permet de lancer Qobuz parfaitement. La liaison est stable et je ne constate aucune coupure, moins qu'à mon domicile principal avec les boitiers Qobuz...
Le son est bon, la puce de conversion apportant une sonorité agréable.
Il ne rate sa cinquième étoile que du fait de l'absence d'une sortie numérique qui aurait permis d'associer un DAC externe.
Mais au regard du prix, il ne faut peut-être pas trop en attendre.
The Arylic Cobblestone is a WiFi receiver that allows you to easily and efficiently stream your files from your network, smartphone/tablet or your...
