FiiO BTA30 Bluetooth 5.0 Receiver / Transmitter CSR8675 DAC AK4490 aptX-HD LDAC 24bit 192kHz
FiiO BTA30 Récepteur Bluetooth 5.0 CSR8675 LDAC DAC AK4490
Versatile and powerful, the FiiO BTA30 is a Bluetooth receiver and transmitter, but also a DAC. Featuring a complete set of connectivity, a control application and very good sound qualities, the BTA30 is the ideal companion to enjoy your music with ease.
Reference : 14873
129,00 €tax incl.
107,50 € tax excl.
Shipping from France
Billing in France
Technical support in France
This product has been replaced by the new version, the FIIO BTA30 PRO Bluetooth receiver with DAC ES9038Q2M.
FiiO BTA30
FiiO BTA30 Récepteur / Émetteur Bluetooth 5.0 CSR8675 DAC AK4490 aptX-HD LDAC 24bit 192kHz
3 Modes of operation
The BTA30 offers 3 distinct operating modes: Bluetooth reception (BT Rx), Bluetooth transmission (BT Tx) and DAC. The selection is made simply by a button on the front of the device. The embedded Bluetooth chip supports high resolution codecs such as aptX-HD and LDAC.
Bluetooth Reception
Bluetooth Transmission
DAC
Complete Connectivity
Although compact, the BTA30 is equipped with a complete set of connectors. It is equipped with Bluetooth 5.0, Toslink Optics, Coaxial and USB-C. At the output, the device offers Bluetooth, Optical, Coaxial and RCA line output.
The coaxial input and output are shared on a single connector.
The USB-C connector allows both data transmission and power supply to the unit.
Bluetooth CSR8675 Chip
Bluetooth reception and transmission of the BTA30 is enabled by a Qualcomm CSR8675 Bluetooth chip, supporting transmission up to 24bit 96kHz (depending on the codec used).
High Performance DSP
The BTA30 also features an independent CR5302SN DSP, which allows the BTA30 to tune to the different formats supported by the camera. In addition, it allows 192kHz upsampling of all digital audio streams for improved accuracy and listening experience.
AK4490EN DAC
The digital/analog conversion is carried out by an AKM AK4490 chip with excellent performance. Its implementation allows you to enjoy a great sound richness thanks to a better SNR and a better dynamic range than the DAC integrated in the Bluetooth chip. The DAC is combined with film capacitors for clearer and more transparent highs.
Volume control
The BTA30 incorporates a high level volume control. This allows a precise adjustment of the sound level thanks to the ADC curve reconstruction. It acts on both digital and analog output volume and can be remotely controlled via the mobile application.
When using the unit in USB DAC mode, the volume control cannot be used.
Control App
Your smartphone, when connected to the BTA30, can control the BTA30 via the FiiO Music or FiiO Control application. The application allows you to act on the balance, filters, Bluetooth format priority, to disable LED indicators, to adjust the volume level and to activate a fixed output level.
Download FiiO Control app for Android
Download FiiO Control app for iOS
Download FiiO Music app for Android
Download FiiO Music app for iOS
Dual Hi-Res certification
The BTA30 has the dual certification of Hi-Res Audio and Hi-Res Audio Wireless, awarded by the Japan Audio Society. These certifications guarantee high quality sound reproduction.
Product typeBluetooth Receiver
InputsBluetooth 5.0
1x USB-C
1x Optical Toslink
1x Coaxial (shared with the output)
Outputs1x Optical Toslink
1x Coaxial (shared with the input)
1x RCA stéréo
Bluetooth ChipCSR8675
DSP ChipCR5302
DAC ChipAK4490
AOPOPA1662
Supported Bluetooth codecsSBC, AAC, aptX, aptX-HD, aptX LL, LDAC
Supported sampling ratesOptique : PCM jusqu'à 24bit 96kHz
Coaxial : PCM jusqu'à 24bit 192kHz, DSD64 (DoP)
USB : PCM jusqu'à 16bit 48kHz
Transmission rangeApprox. 30m (without obstacles, SBC codec)
LED IndicatorsSBC : Blue
AAC : Teal
aptX HD : Yellow
aptX : Purple
aptX LL : Green
LDAC : White
Analog output levelMax 3Vrms
THD+N (RCA)0.002% (SPDIF input 24bit 48kHz, 1kHz -3dB)
SNR (RCA)115dB
Housing materialAluminum
Dimensions120 x 55 x 23.5mm
Weight115g
Package1x FiiO BTA30
1x Bluetooth Antenna
1x USB Cable
1x RCA Cable
OutputBluetooth
OutputOptical Toslink
OutputCoaxial SPDIF
DAC / ADC ChipAK4490
5 reviews
Très bon rapport qualité / prix
Excellente conception pour ce petit boîtier, son dynamique et précis. Destiné à redonner vie à un vieil ampli de trente ans d'âge et enceintes de qualité, je suis ravi.
Livraison rapide et soignée.
This review has been posted for FiiO BTA30 Bluetooth 5.0 Receiver / Transmitter CSR8675 DAC AK4490 aptX-HD LDAC 24bit 192kHz
Excellent produit
Je cherchais un dispositif peu onéreux pour écouter occasionnellement YouTube ou des radios sur ma chaîne à partir de mon smartphone en Bluetooth. Ce Fiio BTA30 comble mes attentes. Il délivre un son d’excellente qualité que je ne pensais pas trouver vu sa taille et surtout son prix.
Excellent rapport qualité/prix
Très bon produit, facile à installer, extrêmement polyvalent et d'une bonne qualité sonore.
Seul bémol: je ne peux plus régler le volume à partir de l'émetteur (un Sony NW-ZX507), alors que c'était possible sur mon ancien récepteur (en BT 4.0).
Côté service: livraison rapide et emballage soigné... je recommande sans réserve.
Excellent transmetteur BT LDAC
Petit boitier très complet et très efficace avec de belles finitions ! Je l'ai branché en optique sur la TV pour pour transmettre en bluetooth LDAC sur mon casque Sony WH-1000XM4 et ca fonctionne très bien !
Très efficace
Utilisé pour diffuser Qobuz sur ampli HK et enceintes BW - impressionné par le rendu sonore en utilisant l Aptx HD ce en couplant un tel huawey (les deux reposent sur des processeurs Qualcomm)
Versatile and powerful, the FiiO BTA30 is a Bluetooth receiver and transmitter, but also a DAC. Featuring a complete set of connectivity, a control...
