FURUTECH FT-785M (R) 3 Poles Male XLR Inlet Rhodium Plated Copper Alpha Treatment (Unit)
Furutech FT-785M Rhodium Embase XLR Mâle
This FT-785M (R) 3-pole XLR male connector uses excellent materials to increase audio signal conductivity and takes advantage of Furutech's specific know-how and techniques. Thus, the connector contacts are made of high purity Rhodium plated and Alpha treated copper (α).
Reference : 8917
47,90 €tax incl.
39,92 € tax excl.
Shipping date: 30-04-2024.
Shipping from France
Billing in France
Technical support in France
Furutech FT-785M (R)
Furutech FT-785M (R) Embase XLR Mâle^Plaqué Rhodium
This FT-785M (R) 3-pole XLR male connector uses excellent materials to increase audio signal conductivity and takes advantage of Furutech's specific know-how and techniques. Thus, the connector contacts are made of high purity Rhodium plated and Alpha treated copper (α). This treatment, which mainly consists of the cryogenization of the material, increases its conductivity. Contacts are also maintained and isolated by a Liquid Crystal polymer. The connector body is made of Nylon and Fiberglass anti resonance with Piezo Ceramic resin.
Product type3 poles male XLR inlet
Contacts materialHigh purity Copper, Alpha (α) treatment
Contacts platingRhodium
BodyNylon / Fiberglass with Piezo Ceramic resin
Pin holder and internal insulationLiquid Crystal polymer resin
Connection typeTo solder
Dimensions32 x 27 x 32mm
QuantityUnit
Max cable diameter (mm)N/A
Mounting typeTo weld
ConnecticMale
Contacts number3
Max panel thickness (mm)N/A
ConnectorXLR
2 reviews
Parfait
En remplacement de la connectique Mini xlr acss audio GD entre un master 10 et un he7 r2r ladder dac. Cela permet de mettre un très bon câble ce qui n'est pas le cas avec les Mini xlr, tout simplement génial Au niveau sonore. Par contre il faut être un bon bricoleur l'opération est très compliqué. Je vais pouvoir mettre un furutech Das le top quoi mimi xlr on est très limité.
This review has been posted for FURUTECH FT-785M (R) 3 Poles Male XLR Inlet Rhodium Plated Copper Alpha Treatment (Unit)
Très bien mais
A ce prix, Furutech pourrait livrer avec 2 vis !!!
This FT-785M (R) 3-pole XLR male connector uses excellent materials to increase audio signal conductivity and takes advantage of Furutech's...
