claudio c.
claudio c.
YANN P.
Excellente barette secteur
Avis clients - Il y a 20148 avis.
Giorgio V.
XDUOO 05BL PRO Récepteur Bluetooth 5.0 aptX HD LDAC pour XD-05 / XD-05 PLUS Le xDuoo 05BL Pro est une extension destinée aux xDuoo XD-05 et XD-05 Plus, permettant d'offrir à ces DAC / amplificateurs casque une connectivité...
Articolo spedito in tempi brevissimi . confezione di alto livello, l'ho collegato al mio XDuoo Xd-05 primo modello. Nessun problema. L'impressione d'ascolto si è rivelata ottima. Non fà assolutamente rimpiangere la connessione via cavo, anzi trovo che non vi sia differenza se non a mio parere in meglio. Praticissimo senza vincoli di spostamento.
Thomas M.
FURUTECH FI-15 PLUS (G) Connecteur IEC C15 Cuivre Plaqué Or 24k Ø16mm Fiche secteur IEC femelle haute performance, idéal pour la constitution d'un câble secteur Audiophile haut de gamme. Outre ses contacts en cuivre plaqué or...
Refined and relaxed
I like this gold-plated IEC in combination with the Furutech FI-E11-N1 (G) Schuko. The FI-15-Plus G provides a lot of refinement while still sounding relaxed and effortless. I use the two plugs with an old Vovox initio power cord, made form silver-plated solid-core copper. Massed strings are simply beautiful with this combo. Silk and cream.
The usual choice for an IEC together with the Furutech FI-E11-N1 Gold Schuko would be the Furutech FI-11-N1-G, of course. But I never warmed up to it. To my ears, the Furutech FI-11-N1-G IEC simply messes with the timing. E.g. instrumental groups in symphony orchestras lose their cohesion. In the long run, it's annoying and tiresome. I tried the FI-11-N1-G time and again, but I simply can't stand it.
To my ears, this Furutech FI-15 Plus (G) is the much more musical, natural and involving IEC plug. And on top of that, it's cheaper.
Thomas M.
Great choice for high-current applications, it seems
I use a Furutech eTP66EG power strip. However, my wall socket is very much pedestrian. I have beeen looking to upgrade the plugs on my Vovox initio power cord (silver-plated solid core copper) that feeds the Furutech strip for some time now, trying all kinds of different plugs. Now, I've found my solution: FI-E11 (Cu) as Schuko and FI-11 (Cu) as IEC. It provides superior dynamics, more authority, weight and slam than e.g. the Furutech FI-E11 Gold oder the Viborg VE501 pure copper.
For some resaon, using the FI-E11 (CU) in the power strip, supplying power to individual components, doesn't work quite as well for me. There it tends to sound a bit tired, with somewhat subdued treble. It lacks refinement. But for the power strip, where the plug has to deliver a lot of wattage and current, it seems ideal to me.
Thomas M.
As solid as beautiful
The knob looks and feels soild indeed. It's flawlessly finished. And it's a pleasure to use. I feel it's a great choice, not just because of its surprisingly low price.
Alexandre W.
La bonne alim
Après avoir testé toute sorte d'alim plus ou moins au de gamme pour mon auralic femto , c'est celle qui sort du lot. C'est le meilleur compromis entre patate et subtilités d'articulation, c'est pêchu et naturel à la fois. On conserve une bonne profondeur avec de l'air autour des pupitres très posés. On n'est plus dans l'analyse mais dans le plaisir de profiter de la musique.
Si vous êtes dans une configuration avec un dd ou SSD en USB et que vous alimenté une interface USB , c'est la bonne alim.
TELEGARTNER MFP8 T568B Connecteur RJ45 Ethernet High-End Métal TELEGARTNER MFP8 T568B, tout simplement pour nous le meilleur connecteur RJ45 du marché, son corps métal, son exceptionnel blindage et sa facilité d'usage...
Trés bon connecteur
Très bien conçu, très bon guidage des fils!
Et même mieux: le connecteur se relie au blindage du câble, ce qui permet de conserver la continuité du blindage.
Attention: il y a un modèle T568A et T568B, et il ne sont pas permutable grâce (ou à cause) d'un mécanisme de détrompeur.
Je le recommande...
TELEGARTNER MFP8 T568A Connecteur RJ45 Ethernet Haute qualité Métal Connecteur RJ45 à montage facile (pas d'outil nécessaire). Blindage 360°C; grande connectivité.
Trés bon connecteur
Et meme mieux: le connecteur se relie au blindage du câble, ce qui permet de conserver la continuité du blindage.
Je le recommande...
Montage aléatoire
J'ai acheté cette paire en connaissance d'un risque de problème...
Dans ce connecteur, il manque un guide fil. L'espace pour enficher les fils est beaucoup trop large. Pire: deux des 8 contacts métallique ne sont pas à la même hauteur que les autres, ce qui pousse à mettre les fils en désordre. Donc on contrôle très difficilement l'ordre des fils une fois enficher. Résultat pour moi: les deux fils bleu se sont inversé au moment du sertissage. Alors J'ai donc jeter la paire de connecteur directement à la poubelle...
Je vous conseil plutôt Telegartner MFP8, très bien conçu, guidage sûr des fils, et même mieux: le connecteur est blindée! Attention il y a un modèle TC568A et un modèle TC568B.
Gregory O.
PANGEA PREMIER Câble Ethernet RJ45 Cat7 Cuivre Plaqué Argent Triple Blindage 0.129mm² 1.5m Si vous disposez de périphériques audio high-end connectés en réseau, alors il est essentiel d'utiliser des câbles Ethernet de qualité pour permettre à vos appareils de délivrer...
PANGEA
Has improved the picture from my router/internet box to my oled tv. Fast post to Ireland, 5 days Great job again AUDIOPHONICS
AUDIOPHONICS TPA-S100 Amplificateur Class D TPA3255 Bluetooth 5.0 2x 85W 4 Ohm Noir Nous vous proposons avec le Audiophonics TPA-S100 un amplificateur Class D profitant d'une belle conception, lui permettant de délivrer une puissance confortable de 2x85W...
BEAU PRODUIT
Il a un bel aspect et une construction solide mais mon soucie est ça télécommande qui est pas très avenante. Et j'aimerai savoir si l'on peut la remplacer par un modèle "universelle" comme pour une TV. Sinon pas de doute sur qualité sonore de cet ampli signé Audiophonics... (testé avec des B&W 607 et Médiasun 2.5 silver) Pourquoi dépenser plus !!!
Joris J.
Pricy, but best sounding caps for the money. I use them also as kathode bypass caps in my SET tube amp.
Joris J.
Connecteur USB-C 3.1 Mâle Plaqué Or DIY Ce connecteur à monter vous permettra de créer vos propres câbles avec connecteurs USB-C plaqué Or. Vous pourrez ainsi profiter du format réversible de ce connecteur, pouvant...
Fragile
Hard to make a study connector. My soldered connection broke at use.
Joris J.
Good product
In combination with “ Linear Power Supply board MJE15034G Low noise 4.8V à 24V 2A" this transformer gave huge improvement in sound quality of my DAC e.a.
Joris J.
Gave my huge improvement of sound quality of DAC and another one in sound quality op raspberry SPIDF HAT, both in combination with a 30W R-core transformer.
Joris J.
Fer à Souder Réglable avec Écran 110W 500°C Ce fer à souder d'une puissance de 110W offre une température de chauffe ajustable de 80°C à 500°C. Son utilisation est facilitée par un...
Disappointing
I expected faster warm up, at warming up the real temperature of the tip is reached much later than is indicated on the display. At soldering the reheating/step up in warming seems to be lagging; that causes problems at soldering f.i. chassis parts. In stand by mode, you need to switch it off and on to reheat.
Joris J.
Prolongateur Extension pour AOP DIP8 Cuivre OCC Argent 30mm Cette extension pour AOP au format DIP8 s'avérera particulièrement pratique pour effectuer des montages d'AOP sur des PCB ne laissant que peu de place à ce...
Quality product. Great value.
Good, sturdy, quality wiring.
I used it to solder and seperate little circuit around the sparkos ss3602, powered by seperate power supply (seperate from digital part of the DAC.). Spectacular improvement over the sparkos directly dropped in.
Joris J.
Great value
Very precise cutting. Sharp and strong.
Joris J.
Usefull
I use it more often than I expected to do.
Joris J.
Disappointing
Physical qualities are very good, but for high end sound quality the semi-balanced use of a symmetrical cable (shielding connected at only one end) is just better, I experienced.
Joris J.
Better than SC-221OOC
I first tried the ELECAUDIO SC-221OCC because that has PTFE isolation, but this less expensive Neotech cable simply sounds better with my SET tube amplifier. And a bit easier to work with.
Gernot E.
A delight for audiophile ears
The unit is easy to assemble, helped by very clear illustrated instructions. The quality of the housing is very good, the aluminium surfaces are beautifully brushed and all parts fit together perfectly.
The sound quality is outstanding, and the display with the large ticker showing the metadata of the music currently playing is also very nice.
The documentation of the DAC functions and the remote control can be found in the article description of the DAC board ("Datasheet Evo Sabre"). Unfortunately, this documentation leaves many questions unanswered and some of the items in the settings menu that are accessible via the remote control are not addressed or are perhaps no longer up to date.
Example: According to the documentation, the Raspberry Pi cannot control the power supply state of the DAC board. But in the settings menu, the item "GPIO Power Control" (not mentioned in the documentation) appears, which, when set to "yes", seems to let the Raspberry Pi shut down the device in a controlled manner.
Conclusion: A beautiful and high-quality device that is a lot of fun. However, the documentation could be improved.
Alexis M.
3 mois plus tard : parfait
Le titre pourrait se suffire à lui-même mais je vais un peu détailler.
Ce qui m’a attiré au départ c’est la connectique parfaitement adaptée à mon usage : TV sur la fibre optique ; platine vinyle sur l’analogique ; RPi + serveur MPD sur USB. Le prix très attractif aussi.
Les enceintes sont des quarts d’ondes diy (90dB/W/m) qui donnent tout leur potentiel avec ce petit ampli bien cool.
Les plus : petit, consomme peu, facile à prendre en main et à utiliser, s’allume tout seul quand on a la bonne source de sélectionnée, s’éteint tout seul quand il n’y a plus de son, puissance très suffisante pour une utilisation quotidienne ; télécommande ok…
Les moins : un peu de souffle sur l’entrée analogique RCA qui s’efface dès qu’on passe le 10/12 en volume, pas de souffle audible sur les entrées numériques ; les presets ne sont pas fabuleux et je reste un flat avec les réglages eq à zéro ou éventuellement +2dB sur les basses ; l’écran en affichage en spectre est mal foutu, c’est en linéaire et ça va de 100Hz à 20kHz, donc pas d’affichage du bas de spectre et le linéaire c’est pas très représentatif ; l’éran pourrait être moins lumineux (ou réglable en intensité). Ne s’allume pas en auto si on a pas le bonne source sélectionnée précédemment.
Divers : je n’ai pas testé le casque, je n’écoute pas de musique au casque. Ce petit ampli donne avec mes enceintes sont plein potentiel à partir d’un niveau de 20/25 (faut avoir de gentils voisins), le son est très percutant sans être agressif.
Content de cet achat, il fait le job, il est discret, il est pratique.
La bonne mesure
La valeur affichée est conforme à celles mesurées: 8,17µf sur le premier condensateur et 8,19µf sur le second. Avec une tolérance de 5%( soit 0;41µf en + ou en -) . C'est parfait pour l'application prévue en filtre passif d' enceinte. Merci Audiophonics.
Jean Louis L.
Mes câbles secteurs étaient tous des Pangea AC14SE, très bons pour leur tarif, mais je souhaitais expérimenter quelques choses plus haut de gamme avec 2 câbles DIY, le Furutech TCS31 et ce Yarbo SP-1100PW, tous deux avec des prises secteurs Viborg VE502S en cuivre pur plaquées argent, en tous point excellentes.
J'ai réalisé de nombreux essais avec ces deux câbles secteurs, sur l'ampli (un Elekit TU9200, petit ampli à tubes à simple étage de 7581A Tung-Sol + Psvane 12AU7, merveilleusement musical), le DAC (Denafrips Ares II) et la barrette secteur. Ces deux excellents câbles secteurs ne sont pas des concurrents mais par contre, ils se complètent à merveille, à la condition de les placer judicieusement dans votre système audio.
Le combo magique chez moi est le Yarbo entre la prise murale et la barrette secteur et le Furutech TCS31 entre la barrette et l'ampli.
Le remplacement du Pangea par le Yarbo apporte une scène sonore en 3D étonnante, large et surtout profonde, des voix sans aucune sifflante, pures. C'est d'ailleurs souvent une constante avec le cuivre OCC, une impression d'une reproduction musicale pure et naturelle.
Le Furutech TCS31 apporte lui une grande richesse harmonique, des voix charnelles, émouvantes, un grave qui descend très bas. C'est une écoute pour ceux d'entre nous qui recherchent une proximité avec les artistes, le jeu des musiciens, les voix, presque une communion.
Tout le contraire d'une écoute exacerbée et démonstrative, presque intime, vraiment sublime sur les voix, les instruments acoustiques, le jazz vocal, la musique baroque, les voix de Brel, Nougaro, Stacey Kent, Youn Sun Nah, Véronique Gens...
La dynamique est effectivement sage ici et la douceur l'emporte, avec quand même une analyse troublante sur les voix, mais qui demeurent charnelles et douces. Si vous vous reconnaissez dans cette description musicale, ce combo est fait pour vous !
Sinon, pour une écoute plus transparente et dynamique, une analyse plus poussée, mieux vaut aller voir ailleurs.
Étonnant et un peu mystérieux de constater à quel point des câbles secteurs peuvent apporter tellement sur la reproduction musicale.
Yannick r.
TOPPING D70S MQA DAC Symétrique 2x AK4497 I2S XMOS Bluetooth 5.0 LDAC 32bit 768kHz DSD512 Noir Le Topping D70S MQA est un convertisseur numérique / analogique symétrique extrêmement polyvalent et performant. Profitant d'une conception...
Un DAC aussi précis que doux à l'oreiller
Suite aux différents avis sur le site et ailleurs, j'ai décidé de tenter ce D70s qui semblait bien prometteur.
Alors malgré quelques frayeurs après une mise à jour et un câble USB défectueux (rapidement remplacé par ailleurs), le joujou électronique fonctionne superbement. Une quantité de détails impressionnante, une dynamique au rendez-vous et une délicatesse en haut du spectre, tout est là pour se lancer dans de belles et longues écoutes. A voir maintenant si les iPurifier et iSilencer de chez iFi audio pourront optimiser les qualités intrinsèques de l'appareil, lisant la musique depuis un PC Windows, et bientôt depuis un streamer.
Attention cependant à la sensibilité en entrée de l'ampli si vous utilisez les sorties XLR. Sur mon ampli casque, j'ai utilisé le mode DAC, la puissance disponible est phénoménale, mais les distorsions ont commencé à se faire entendre sur certains morceaux. Si cela arrive, préférez le mode Pré Amp et atténuez le niveau de sortie. En revanche, rien à signaler sur les sorties RCA, qui bénéficient également d'un bon niveau de sortie et d'un rendu tout à fait plaisant.
La navigation n'est pas trop compliqué et l'affichage est assez lumineux à mon goût.
Pour conclure, ce DAC a tous les atouts pour être au centre d'une installation de qualité, eu égard à son niveau de performance.
jean michel G.
MUNDORF MRESIST SUPREME MRES20-1.5 Résistance 20W 1.5 Ohm La gamme de résistance Mundorf MResist SUPREME propose des produits d'une qualité exceptionnelle. Avec un réel impact sur la restitution sonore, des...
Merci pour votre retour
Petr K.
An excelent simple DAC
This DAC ,despite its sophisticated internal architecture is simple to attach to RPI4, no boring I2C control, OPA necessary, worked immediately with Volumio generic DC i2S driver. I connected it to TI 2x50 W TPA3116D2 chip amp. With two Magnat premium 102 speakers the set generates great sound, for a daily listening. Can compare to PCM5102A which I installed to another DIY DAC, both are good ones, Sabre seems to me better in high freq, IT in lower ones. May be its a little bit subjective view.
IFI AUDIO IPOWER X Adaptateur Secteur Alimentation Faible Bruit 5V 3A iFi Audio propose avec son adaptateur secteur iPower X une alimentation très faible bruit, destinée à alimenter proprement vos modules et appareils HiFi,...
Exelent utilisée avec le Ifi digital interface.
J ai utilisé ma 2eme Ifi interface pour améliorer grandement le son tire de mon extracteur audio hdmi. Avec une Ifi I power standard. Pas mal. J ai utilisé une Ali Ifi x power si dessus la différence est impressionnante. Plus d épaisseur de naturel et de dynamique sur une largeur de bande encore plus étendue. Le prix et bien étudié pour les performance audio. Si vous voulez aller encore plus loins. La version élite elle. Sais encore mieux. Bien mieux. Ses deux alimentations sont génial. À recomender sans retenue.
Bon produit, de bonne facture, j'ai juste une remarque au sujet de l'affichage qui aurait pu être réglable, car ça brille un peu fort dans le noir, et dans une chambre, c'est pas terrible.
Serge H.
Un accessoire incroyable
Sceptique au départ, Il faut le voir pour l'entendre.
Couplé à un conditionneur de 1000 euros sur une multiprise pour les sources audio, cet accessoire apporte une plus value incroyable au système.
Une extinction des notes qui ne s'arrêtent, son palpable...
L'accessoire le plus bluffant à ce jour.
Damien C.
TOPPING EX5 Amplificateur Casque DAC 2x ES9038Q2M Bluetooth 5.0 LDAC 32bit 768kHz DSD512 MQA Noir Topping propose avec son EX5 un combo DAC et amplificateur casque extrêmement performant. Son étage de conversion se base en effet sur deux puces DAC ES908Q2M et...
Meilleur rapport Q/P
Après avoir longtemps cherché, je voulais un DAC avec prise casque, alimentation intégrée, prise USB B plus robuste que le micro USB d'un SA300 par exemple, et des sorties XLR en remplacement d'un ampli DAC Yamaha A-U670.
Totalement satisfait par ce petit bijou. L'intégration des composants est au top (partenariat et expérience partagée entre Topping et Shenzhenaudio oblige), le son est pure comme jamais même s'il n'utilise pas les flagship comme le ES9038Pro ou le AK4497/99 à 60 ou 70€ la puce !
Il est tout de même équipé de 2 ES9038Q2M offrant des caractéristiques similaires à son grand frère mais ici 1 puce par canal.
Un bon compromis et largement suffisant de le cas d'une utilisation pc fixe à la maison avec 2 enceintes Wharfedale Diamond 220 et un petit caisson de basse Yamaha.
Pour le moment je l'ai connecté à un SMSL SA300 (celui de mon fiston) en attendant la réception d'un SMSL AO200 (adieu les bruits parasites je ne vous regretterai pas) non encore dispo au moment de passer commande mais dont le rendu sonore est, selon les tests et vidéos, plus chaleureux que sur le SA300 sans toutefois atteindre celui des amplis de class-a.
Je tiens enfin à remercier le service client et support d'Audiophonics pour leur professionnalisme et la qualité de nos échanges. Dommage juste qu'on en puisse les contacter au téléphone, çà apporte un côté plus humain tout de même.
Damien C.
Câble Adaptateur XLR Mâle 4 Pins vers Jack 4.4mm Femelle Plaqué Or 15cm Ce câble adaptateur symétrique est doté d'une part d'un connecteur XLR mâle 4 pins et d'autre part d'un connecteur Jack 4.4mm femelle. Il vous...
Très bon adaptateur
Utilisé sur un DAC TOPPING EX5, des écouteurs FIIO FH7 et un câble de remplacement FiiO LC-4.4D 4.4mm (introuvable en France...).
Le serrage est parfait. Cet adaptateur est suffisamment flexible, résistant et respire la qualité tant physique qu'au niveau du son.
Laurent C.
J'ai du mal à le croire !!!
Après avoir essayé du Real cable, Qed, Nordost à des prix bcp plus élevés, avec le Canare j'ai tapé ds le mille. Connecté entre un Roksan kandy k2 et Marantz na6006 clarté, détails et des basses rondes sans aucune agressivité sur des Focal aria926. Incroyable. Bravo Audiophonics de proposer des produits de cette qualité à ce tarif. Chapeau !!!
Nico V.
NEOTECH STDST-20 Fil de câblage multibrins UP-OCC SILVER PTFE 20AWG Ce câble multibrin argent Neotech avec isolation PTFE est idéal pour le recâblage et l'amélioration d'amplificateurs à tubes, ou tout appareil...
For DIY power cable
I used this cable to power my Topping D70S DAC. Phase + Neutral are UP-OCC silver, ground is UP-OCC copper. All cables are screened separately by the copper sleeves. Sleeve-ends are connected to the power plug input (ground). With Furutech connectors and you have a ultra high end power cable and it is all save because of fused DAC and no more than ..mA of current dissipation.
Diogo P.
VIBORG VE502 Connecteur Secteur Schuko Type E/F Cuivre Pur Ø20mm Ce connecteur secteur Schuko mâle Viborg VE502G est idéal pour créer des câbles d'alimentation de qualité. Il utilise en effet des contacts en...
Worth it
Good weight, good copper and the aluminium body a must.
rodrigue L.
MUSICIAN PEGASUS DAC R2R Discret Symétrique 32bit 1536kHz DSD1024 Noir Le Musician Pegasus se présente comme un magnifique et particulièrement performant DAC, profitant d'une architecture R2R soignée. Intégrant les...
Voilà une semaine que je l ecoute via qobuz usbridge ampli atoll enceintes jmr.
Par rapport à mon ancien dac ds ess9018
Soundstage plus grand plus profond sans nul doute.
Timbres plus réaliste
Timing plus précis.
Je ne trouve pas que cela dégage une chaleur dans le son trop prononcé et il n est pas mou du genoux.
En résumé
Soundstage très bon ecoute plus live plus enveloppant
Timbre excellent instruments cuivre,cordes parfait.
Voix j aurais aimé plus de corps de grain encore.
tous les styles de musique passe je suis très ecliptique
Bref je suis refait .
Un belle achat
Thierry W.
Très bon streamer
Très bon streamer, surtout au regard du tarif affiché.
S'utilise avec Volumio ou en direct avec l'adresse IP.
Comparable à un Rasberry Pi, mais en plus compact et plus propre. Pas besoin de deux alimentations non plus.
J'avais un Lumin U1 mini avant, mais l'interface est moins bien et moins intuitive que le stream. Sans compter la différence de prix :-)
Pas de différence en terme de qualité sonore... Juste plus de sorties sur le Lumin....
A recommander !!
jean michel G.
Idéal pour basse ou haute fréquence ?
Je me pose cette question.
Le mieux pour ce type de résistance.
Idéale pour toute la bande, basse et haute fréquence, grâce à la conception double enroulement à moins de 75µH.
Antoine P.
Câble de qualité
Très satisfait par ce fil, utilisé pour refaire le câblage interne d'une alimentation. Souple, facile a dénuder et l'isolant ne souffre pas lors de la soudure.
Tomas H.
SMSL TABEBUIA WAVECOR Enceintes Bibliothèques 2 Voies 100W 4Ω 88dB 56Hz-32kHz Noir (La paire) Les Tabebuia sont les premières enceintes proposées par l'acclamée et reconnue marque SMSL. Ces modèles compacts au format bibliothèque...
Great quality from small, easy to drive speakers
I am connecting these speakers to Astell&Kern ACRO L1000 DAC/AMP for a very nice near-field set-up on my working desk. Despite the modest output of my amp (15W per channel), these speakers produce wonderful music, very enjoyable, full of detail and color. They do not get very loud of course, but they render the music with authority and help me get through my working day with more joy and energy :) I can highly recommend these.
Finesse...
Montés sur un HA-B6120 après des Muses02.
On gagne beaucoup en finesse, en quantité de détails entendus. L'aigu est fin et semble filer haut. La scène sonore n'est peut-être pas la plus large mais c'est très précis, les Muses02 le sont beaucoup moins.
Bel équilibre les basses sont là sans excès de rondeur, les aigus pas en avant comme avec certains AOP...
Sur la musique classique c'est top, dont un enregistrement qui n'a jamais passé aussi bien que sur ce set... Visions of Prokofiev par Lisa Batiashvili: grosse caisse énorme d'origine qui est à sa place, violon parfait pas du tout acide, séparation de tous les pupitres un vrai régal! mais tous les styles passent bien et on distingue facilement les prises de son/éditions qui sont bonnes, quelque soit le choix sonore de la prise.
Le capot de l'ampli chauffe davantage, sachant que l'on est en été avec des 30° dans la journée.
Cet ampli gagne à être connu. J'ai utilisé d'autres amplis à base de l'excellente puce d'amplification TI TPA6120, celui-ci est le meilleur.
Présence d'AOP en entrée, je l'ai écouté avec des Muses8920, Muses02 et Burson V6 Classic. Avec les Muses c'est très bon, je préfère les V6 Classic encore plus fins et détaillés.
Le HA-B6120 drive facilement tous types de casques, à basse et haute impédance. Il a plein de fonctionnalités en entrée et en sorties casques (asymétrique, symétrique). Il est puissant j'alimente un HE-6 sans problème au 1/3 du volume en gain bas.
Même pour beaucoup plus cher difficile de trouver mieux, c'est neutre, puissant, détaillé, musical.
Câble Coaxial Cuivre OFC Plaqué Or Blindé 0.75m Ce câble Coaxial intègre un conducteur en Cuivre OFC assurant une excellente conductivité. Il profite également d'un blindage et d'une ferrite afin de...
bon cable petit prix
Cable numérique qui fait son job,suffisant pour un Dac d'entrée de gamme
Michael L.
SMSL Adaptateur Secteur Alimentation 100-240V AC vers 24V 5.75A DC pour AD18 Cet adaptateur secteur AC 100-240V 50/60Hz 1.2A vers 24V 5.75A DC est idéal pour remplacer un modèle de caractéristiques équivalentes...
It works
I though it was faulty(coilwhine thru my speakers), tried a diffrent power distributor no high pitched sound thru my speakers, because of that i will only give it 4 stars
Thomas G.
Beau rendu
Bonne qualité du boîtier dans l'ensemble. L'aluminium semble de bonne qualité. Se perce facilement. Sur les parois à l'intérieur il y a plusieurs rainures parallèles ce qui est pratique pour faire passer les câbles et les coller.
Côté pratique aussi il y a des rainures sur la plaque de dessus et de dessous pour laisser passer la chaleur.
Une fois les connecteurs en place et une belle plaque en aluminium sur la face avant, le rendu est pratiquement professionnel.
Seul petit bémol, les deux arrêtes de côté de la face avant n'étaient pas 100% plate, un coup de ponçage et c'est Nickel !
A conseiller, super produit !
Dominique M.
Des matériels de qualité
Ces blocs mono, en classe D, permettent une restitution de qualité, associés au préampli phono à tube Dynavox TPR-2.
A recommander
Dominique M.
Excellent matériel !
Ce préamplificateur phono à tube constitue un excellent matériel, avec un très bon rapport qualité / prix.
Il a été associé à des blocs mono AUDIOPHONICS MPA-M250NC Amplificateur Mono Class D NCore 1x250W 4 Ohm, rendant une restitution de grande qualité.
Le tube tube initial (12AU7) a été remplacé par un tube plus qualitatif permettant de tirer le meilleur parti de ce préampli.
A recommander
Avis mitigé
Je partage l'avis précédent. C'est un câble analytique ça manque un peu de rondeur et de souplesse pour moi. Pour cette raison Je mets un avis mitige car j'espérais mieux compte rendu des avis excellents que j'avais lu... mais pour 5 euros c'est un bon rapport qualité prix tout de même, et facile à souder. Par contre message pour les anglais.. ce n'est pas un câble hp mdr les brins sont fins comme des cheveux....
Avez vous bien rassemblé les brins par deux à chaque extrémité ?
Pierrick P.
TECTONIC BMR TEBM65C20F-8 Haut-Parleur Large Bande Papier 20W 8 Ohm 81dB 80Hz - 20kHz Ø8.9cm La gamme BMR de Tectonic se compose de hauts-parleurs larges bandes destinés à couvrir une très large partie du spectre audio audible. Ainsi, le TEBM65C20F-8 présente une...
Ma commande
j'aurais aimé être informé avant la finalisation de la commande qu'il y avait un réapprovisionnement.
Ioannis P.
Value for money
Musical and balanced cable
Excellent price/performance ratio
