Vincent B.
Bof
Shigeo I.
Couldn't be more satisfied
A flawless power amplifier. The extension of the sound and the precision of left-right imaging are excellent—especially in solo...
Shigeo I.
outstanding cost-performance!
Purchased together with the Audiophonics LPA-S450ET. Since the power amplifier has a balanced architecture, when used with...
Avis clients - Il y a 19131 avis.
FRANK D.
Adaptateur Fourche vers Bornier Haut-Parleur Banane Plaqué Or 24k (La paire) Ces adaptateurs pour câble HP permettent de transformer une fiche banane de 4mm en fourche pour bornier haut-parleur. Cela vous...
Coup de genie?
Sans doute que oui si ce n'est que les fourchettes sont legerement hors norme.
Juste un poil pas plus mais suffisant pour que ca ne rentre pas sur des borniers de haute precision.
Sinon, ras.
Encore merci a toute l'equipe Audiosonics !
Panagiotis Z.
SHANLING EH2 DAC R2R Amplificateur Casque Transistors Bluetooth 5.2 32bit 768kHz DSD512 Noir Avec le EH2, Shanling présente un DAC et amplificateur casque de bureau se voulant être le successeur du Shanling HE1. Cette évolution intègre une...
Excellent (with one easily fixable caveat)
I am impressed with the EH2. I wanted a small, flexible all in one device for headphone listening on my desk. So that I do not have to fire up my more powerful class A dacs and amps for a spontaneous ad hoc listening session. I got exactly that and more.
Driving power
With sensitive iems it has no audible background noise.
I like to hear my music loud and this little dac-amp delivers. Full sized headphones are driven very well – both high impedance dynamic and low sensitivity planars. It can get my Verite Closed and my Arya Organic to very loud levels where I can feel the physical rumble on my ears without any distortion (knob range between 12 and 3 o clock). In comparison my FiiO K7BT can drive the Arya Organic, but if I push the volume any louder it’s protection circuit kicks in and shuts the device off (with red error LEDs). This did not happen with the EH2 (as to be expected: the EH2 has ~4000mW, double the value of the K7 with ~2000mW).
Tone controls
The tone controls are a nice addition. Fine adjustments in bass and treble are immediately noticeable. Turning the bass to the max would satisfy bass heads. The tone control knobs have a notch in the center that you can feel. In this position the tone alterations are completely off. It’s there if you need it, but you don’t have to use it.
How does it sound?
Nowadays the quality of dacs, even in the lower price segments, has vastly increased to the point that it is difficult to notice differences between dacs. Headphones are the most important factor in the chain. With that aside, yes the R2R dac of the EH2 sounds excellent. It is very clear, detailed, smooth and at the same time full sounding with a nice note weight. No harshness, noise or distortion whatsoever.
Notes
- It produces no pop noise when turning on or shutting off like some other amps.
- Even after many hours listening it does not get very hot, only hand warm.
- Plugging a headphone cable in the front shuts off the line/pre-outs in the back. So if you want to use it purely as a dac to other amps you have to detach any headphone cable in the front.
- The tone controls (bass, treble) also affect the pre-out in the back, but doesn’t alter the line-out (when the switch is set to line-out).
- The small blue LED above the power button is always on, even in standby mode.
- It is very small, about the size of an adult human hand.
Caveat: standby mode is useless
When the EH2 is turned on and not playing music (idle) it consumes about 5 Watt.
In standby mode it still consumes about 4 Watt doing nothing! This mode might as well not exist.
The FiiO K7BT consumes 0 Watt when turned off.
My solution:
As a workaround I plugged a simple power switch between the power supply and the EH2 power socket.
Now I do not use the standby button at all. I turn the EH2 on and off only with the power switch. When it receives power it automatically turns on, no need to additionally press the power/standby button again.
This is working great.
EH1 vs EH2
If you are on the fence about choosing the smaller EH1 or the EH2. Get the EH2. For the extra money you get a lot more: headphone driving power, a real R2R dac instead of delta sigma, more inputs (coax, opt, Bluetooth) and a balanced output. It can drive anything from iems to full sized headphones with no issue. Even if you plan to only listen to easy to drive iems, the EH2 is more future proof with its plus in power and flexibility.
This is a fantastic little powerhouse all in one. It fits many use cases. Headphone all in one, pure R2R dac, tone adjustments, BT receiver, TV Audio via optical input. Small enough for any desk space. Even if one owns bigger “normal size” dac and amp stacks this is still worth getting as a flexible desk device for the office or another room.
Price to performance is very high. I think Shanling priced this aggressively low, to get new customers to know the brand.
I’m glad that it exists. Highly recommended!
Panagiotis Z.
Driving power
Tone controls
How does it sound?
Notes
My solution:
EH1 vs EH2
ELBAC HP225 Câble Haut-Parleur Cuivre OFC 2x2.5mm² Ø8mm Le câble Elbac HP225 est un câble pour haut-parleur doté de deux conducteurs multibrins en cuivre OFC d'une section de 2x2.5mm². Le cuivre OFC offre...
Etonnant pour le prix
Ce câble n’enlève rien et ne rajoute rien
Aucune différence de son comparé a mes autres câbles
A essayer avant de dépenser de l'argent inutilement
De plus très bien construit agréable au toucher et facilite de mise en place car il se dénude facilement
Dominique G.
LHY AUDIO LPS160VA 12V Alimentation Linéaire Régulée Faible Bruit 230V vers 12V 9A 160VA Cette alimentation linéaire régulée LHY Audio LPS160VA assure une grande stabilité pour tout projet DIY audiophile de haute qualité. Tous les...
ALIMENTATION LPS160VA 12V
Commande passée le 24 Février, enfin reçue le 20 Mars.
1 Mois, c'est franchement exagéré, surtout que l'argent est encaissé à la commande. Il pourrait faire un geste commercial sur une prochaine commande.
Heureusement pour Audiophonics, les produits sont de qualités et à part une personne qui m'a fait comprendre que si je n'étais pas content je pouvais annuler ma commande et l'acheter ailleurs, les autres personnes avec qui j'ai échangé techniquement ont toutes été sympathiques et professionnelles.
Dominique Guion.
Peter R.
AMPHENOL AC3MMDZ Embase XLR 3 Pôles Mâle Plaqué Argent Cette embrase XLR 3 pôles mâle Amphenol AC3MMDZ, propose un plaquage en argent de ses connecteurs pour une conductivité maximal. Le corps plaqué en...
A good and sturdy XLR connector.
Delivery was prompt.
Many thanks to Audiophonics. A reliable company.
Peter R.
EXICON ECX10P20 Transistor MOSFET (2SJ162) Les MOSFETS Exicon ont été conçus spécifiquement pour une utilisation linéaire à haute puissance. Ils offrent une capacité de...
replacement type
I used the ECX10P20 transistor as a replacement for the discontinued SJ162 transistor to fix a problem with our power amplifier in the KS SAT MKII PA system. It works perfectly without any circuit modifications.
Replacement type
Peter R.
EXICON ECX10N20 Transistor MOSFET (2SK1058) Les MOSFETS Exicon ont été conçus spécifiquement pour une utilisation linéaire à haute puissance. Ils offrent une capacité de...
replacement type
I used the ECX10N20 transistor as a replacement for the discontinued SK1058 transistor to fix a problem with our power amplifier in the KS SAT MKII PA system. It works perfectly without any circuit modifications.
Replacement type
Remus C.
FX-AUDIO DAC-A10 DAC ES9018K2M Préamplificateur à Tubes 6N3 Bluetooth 5.1 aptX HD LDAC 24Bit 192kHz Le DAC-A10 de la marque FX-Audio est un DAC / Préamplificateur à tubes polyvalent et performant avec un facteur de forme relativement compact. Il repose sur des...
Rapport qualité prix imbattable, la qualité d'écoute sera au rendez vous à seule condition de changer les tubes chinoises fournies par des tubes russes série militaire, la différence tant vraiment notable. Fabriqués selon des cahiers de charges plus exigeantes au niveau endurance, les tubes russes série militaire 6N3P-E (6Н3П-Е) chauffent moins. La puce de réception Bluetooth 5.1 QCC5125 de chez Qualcomm qui permet au DAC-A10 de supporter les codecs Bluetooth haute résolution : SBC, ACC, aptX, aptX LL, aptX HD et LDAC est un plus. Ecoute sur casques Sennheiser HD 650
Gabriel G.
LHY AUDIO LPS50VA Alimentation Linéaire Régulée Faible Bruit 230V vers 5V 2.5A 50VA Voici une alimentation linéaire régulée et stable pour tout projet DIY audiophile de haute qualité. Tous les raffinements techniques...
Alimentation linéaire
Amélioration par rapport à ma précédente alimentation linéaire. Je l'utilise pour alimenter un rpi5 (6.5A 5V)
Mikael M.
HIDIZS MP145 Écouteurs Intra-Auriculaire IEM Planar Magnetic 30 Ohm 104dB 20Hz-40Hz Titane Les écouteurs intra-auriculaires HIDIZS MP145 sont des IEM à driver magnétique planaire  ultra-large de 14.5mm. Ils se dotent d'une conception...
Duo mp145 & Penon audio liqueur O
Ne sous-estimer pas ces écouteurs ! Une foi trouvez les bon emboue , le son est énorme !
J'ais essayé les Dunu S&S ... La bass n'est pas de trés bonne qualité ...
Penon liqueur B .... Boff
Penon liqueur O : Excellant !! Spécialisation , bass , sous bass ( infra ) pur ! Avec filtre gris ( équilibré ) , il est muni de filtre rouge pour encore plus de basse .
En comparaison avec les Focal Elegia , hifiman Arya , Dt 900 x rien ne m'a procurer du plaisir ,
le mP145 et Penon O est mieux pour moi .
Seul le EMU TEAK est aussi bon en basse fréquence ... Et apporte également une meilleur image et scene sonore ... En revanche , l'Emu est moin vif , moin dinamique ( plus doue ) .
Le planaire du hidizs lui donne certaine avantage .
Source qobuz + UAPP en mode Bit perfect + Aune Yuki + topping NX7 .
Ne compté pas en retiré le meilleur de cette écouteur avec un simple d'ongle . ( 30 ohms )
Samu T.
ELECAUDIO TE-RC90S Connecteurs RCA Cuivre Tellurium Argent Ø8.5mm (La paire) Ces connecteurs ont été conçus pour vous offrir une très grande conductivité grâce au Cuivre Tellurium.
Difficult solder
Difficult solder coax cable ground to that wide tiny hole. Plug is not attractive to magnet and that is very good.
PIERRE R.
XANGSANE XS-5N Câbles d'Enceintes Bananes Cuivre OCC Plaqué Argent 2m (La Paire) Les câbles pour enceinte XS-5N de Xangsane sont constitués de 12 brins en monocristal de cuivre OCC 5N plaqués en argent afin d'assurer une...
câble xangsane XS-5N
Excellent produit qui donne une reproduction remarquable du grave à l'aigu avec de la dynamique et de la précision . C'est mon meilleur à ce jour !
Kimmo A.
Adaptateur Convertisseur SPDIF Optique Toslink/Coaxial vers Toslink/Coaxial Pratique, ce petit convertisseur permet de transformer un signal audio SPDIF optique Toslink en coaxial, et inversement. Il supporte les technologies Dolby, DTS, AAC et PCM...
Great
Works great, good value for the price.
Jean-Pierre f.
AIYIMA T9 Amplificateur TPA3250 Tubes 2x 6JK4 Bluetooth 5.0 2x60W 4 Ohm Le Aiyima T9 est un amplificateur intégré polyvalent et accessible, idéal pour monter un système audio sans se ruiner et sans multiplier le nombre...
perplexité et mise en garde
Une seule étoile car j'y entends plus d'inconvénients que de plaisir, même à ce petit prix.
D'abord, le plus gênant, c'est ce volume sonore quasi incontrôlable à l'écoute de la plupart de mes CDs et flac, mes 2 principales sources de musique. Aiyima me dit qu'il n'y a pas de mise à jour possible sur le fait que l'avant-dernier cran du volume sonore reste trop élevé. Un cran de plus, et le son est coupé. La seule façon d'y remédier est de passer par l'ordinateur, où il faut y baisser le son interne pour pouvoir ensuite contrôler celui du T9, dommage. Ce "détournement" permet quand même de profiter des radios internet via l'ordi ou de Youtube par exemple.
Autre inconvénient, ce clic intermittent et récurrent dès qu'on laisse en veille le T9, qui signale sa mise en pause. Il est léger mais vraiment pas indispensable.
Enfin, il faut absolument changer les tubes et utiliser un DAC externe pour obtenir un son plus acceptable. Malgré cela, la stéréo reste simplement confinée dans les enceintes, sans réelle scène sonore.
Bref, je ne le recommande qu'à certaines conditions d'utilisation et d'exigence musicale.
Pascal G.
SMSL VMV D2R DAC ROHM BD34301 XMOS XU316 Bluetooth 5.1 aptX HD LDAC 32bit 768kHz DSD512 MQA Le SMSL VMV D2R se présente comme un DAC haut de gamme, offrant de très hautes performances grâce à une conception soignée et des composants...
Hélas mitigé.
L'appareil en soi est très bon. Construction irréprochable, son à l'avenant, connectique complète.
Malheureusement, pour moi qui écoute beaucoup de SACD, cet appareil n'est pas adapté à cet usage car je n'utilise pas de préampli et donc le réglage du volume sur le DAC est primordial, ce que ce D2R n'est pas en mesure de faire.
En effet, malgré le paramètre PRE MODE sur variable, le volume avec un stream DSD est irrémédiablement réglé à 0.0db, c'est à dire sortie à fond sur mes blocs de puissance ce qui a failli faire sauter mes enceintes.
J'ai contacté SMSL Chine et j'ai reçu la réponse suivante, je vous la livre telle quelle (littéralement) :
"The DSD of D2R cannot control the volume. It is Normal, there is a chip issue". Sans plus de formes.
Ceci est non seulement extrêmement malpoli mais surtout totalement inacceptable d'autant moins que nulle part ce défaut n’est indiqué, ni dans le marketing ni dans la notice sous forme de mise en garde vu les implications potentielles léthales pour vos HP. Que le circuit intégré ne fasse pas le job est une chose, ne pas prévenir le futur acheteur de cette situation en est une autre.
Bref je suis mitigé et ça m’embête car le son en PCM (NAS, Qobuz, transport CD) est vraiment excellent, surtout à ce prix.
J’ai deux autres DAC SMSL, M400 et M500, au demeurant excellent eux aussi. Les deux convertisseurs ont toujours fonctionné sortis de leurs boites sans rechigner et avec tous les formats d’encodage disponibles. Là ce n’est pas le cas et j’en suis navré puisque forcé de le retourner.
5 * pour tout sauf pour la conception (1 *) clairement baclée et la mésinformation inexcusable et dangereuse pour l'équipement.
on a pas sur les mêmes finitions ou design que d'autres connecteurs plus chers mais le rendu sonore est au mois aussi bon voire plus naturel pour 3 fois moins cher...
Olivier L.
AUDIOPHONICS LPA-S450ET Amplificateur de Puissance Stéréo Class D Purifi 1ET6525SA 2x450W 4 Ohm Nous sommes fiers de vous proposer le Audiophonics LPA-S450ET, un amplificateur de puissance stéréo classe D basé sur deux modules Purifi 1ET6525SA....
L'ampli idéal
J'ai eu pas mal d'ampli et souvent pas 100% satisfait mais là j'ai été convaincu dès les premières écoutes. Le son est fantastique tout simplement.
Autant j'ai été déçu par un ampli comme le topping LA90, qui a de bonnes mesures mais est pouratnt très mauvais à l'écoute.
Je n'ai pas encore le comparer à mon ampli de référence mais je suis super content. J'ai l'impression qu'il est diffcilie de trouver mieux à ce prix.
Marc F.
Super sauf l'alim
Excellent petit ampli, pratique et quasi. Mais l'alim à découpage fait du bruit, j'envisage de la changer pour une autre.
Catalin C.
Incredible
I was a cable skeptic, thinking that a decent cable is more than enough for my KSE1200. I bought NEMOI 1220 cable out of curiosity mainly, after seeing all the reviews here.
Oh Boy, I wasn't prepared for all the changes I've got: more details, fuller and lusher (!) sound with better soundstage. Nothing like what people say about silver cables.
It's true that my previous cable was way cheaper, made with DCA16GA, but still, it's just a cable...
I'm impressed, I wish I tried this cable before.
Thank you audiophonics and to all those who post their reviews.
AUDIOPHONICS LPA-M750ET Amplificateur de Puissance Mono Class D Purifi 1ET9040BA 1x750W 4 Ohm Le Audiophonics LPA-M750ET est un amplificateur de puissance Class D profitant d'une architecture mono. Celle-ci intègre un module d'amplification Purifi 1ET9040BA et une...
Impressionnant !!
Dans le cadre d’une évolution progressive de mon système en 5.2 Je viens de m’équiper de 2 bloc mono LPA-M750ET (1ET9040BA) qui sont branchés sur les sorties Pre-Out d’un Yamaha RX3060 (qui a terme sera remplacé par un préampli multicanal plus performant). Mes enceintes principales un peu exigeante (Panneaux Magnepan 1.7i) étaient depuis quelques mois alimentées par un HPA-S500ET (1ET7040) qui déjà m’avait bluffé, mais là avec les 2 bloc mono (choisi pour des questions d’intégration plutôt que la version double mono qui doit avoir le même rendu sonore j’imagine). C’est une autre dimension, séparation des canaux, profondeur, très analytique, je redécouvre quasiment toutes les prises de son. Le réglage du gain est un plus incontournable pour pouvoir associer ces amplis avec les sorties pré out du Yamaha. Le HPA-S500ET est passé sur les enceintes arrière (JMLab Micron Titane) ça les a bien réveillés ! Prochaine étape un bloc mono pour la voie centrale (Dynaudio Gemini). Merci à Audiophonics pour les conseils et rapidité d’expédition.
Pavel Z.
VIBORG VE501G Connecteur Secteur Schuko Type E/F Cuivre Pur Plaqué Argent / Or 24K Ø19mm Ce connecteur Schuko Viborg VE501G est idéal pour la conception et l'amélioration de câbles secteur hautes performances et de grande qualité. Ses...
AV
I will write one review for all ordered goods.
I appreciate a very good approach to the customer in an effort to help in every situation. Very good communication, responses to questions come almost immediately. Thumbs up. I believe that such an approach is standard.
Goods: I ordered the brand of goods on recommendation. I think it's OK.
Max Michel D.
EXCELLENTE QUALITE POUR AUDIO
Cette soudure est vraiment TOP pour faire vos cables audio.
Qualité d'écoute au rendez-vous sur vos cables.
Max Michel D.
EXCELLENT
Connecteur RCA/BNC de grande qualité
Ecoute parfaite sur branchement sur convertisseur
Hugo Darien O.
good
after weeks i feel the signal is to bright
Pavel V.
Câble de Modulation Symétrique Jack 6.35mm TRS Mâle vers XLR 3 Pôles Mâle Cuivre OFC 75cm (La paire) Ces câbles abordables sont des câbles de modulation symétrique Jack 6.35mm TRS Mâle vers XLR 3 Pôles Mâle. Ils...
Solid cables
Solid and well-looking cables for balanced interconnection at a good price.
Pavel V.
AUDIOPHONICS HPA-T450ET Amplificateur de Puissance Class D 3 Canaux Purifi 1ET6525SA 3x450W 4 Ohm L'amplificateur de puissance Audiophonics HPA-T450ET repose sur une architecture classe D, utilisant trois modules d'amplification Purifi 1ET6525SA, une alimentation Hypex...
Excellent amplifier
- the power supply produces a very slight high-piched noise (~4kHz) that can be noticed from a 0.5-1m distance (or more) in silent environment (esp. from behind) ; the sound is different when the amp is off and when it is on (NC252M-based amps don't do this)
- if you plan to use the RCA inputs, expect sensitivity to ground-loops, esp. if you have a more complex sond system; if it includes a USB device (e.g. a DAC), you may need a proper USB isolator (a cheap one based on Adum3165 is just good enough)
- it is a pity that the XLR and RCA inputs cannot be switched remotely via some extension or upgrade; just some connector/header bypassing the mechanical switch would be very useful for a DIY implementation using relays
- ideally, remote switching of the gain (e.g. depending on the selection of the XLR or RCA input) would be fantastic (but possibly too complicated)
Pavel V.
AUDIOPHONICS HPA-H250NC Amplificateur de Puissance 6 Voies Class D Ncore NC252MP 6x250W 4 Ohm Le Audiophonics HPA-H250NC est un amplificateur de puissance 6 voies class D basé sur trois modules Hypex NCore NC252MP. Cette version s'adresse notamment aux audiophiles...
Excellent amplifier
Excellent amplifier. The only missing features are switchable RCA inputs and possibly adjustable gain (but that would be probably complicated and significantly more expensive with NC252MP modules).
André A.
Exceptionnel
Je viens enfin de brancher mon ampli de puissance. Après avoir attendu le temps de chauffe nécessaire, c'est une révélation. J'ai l'impression d'avoir de nouvelles enceintes. Je découvre le potentiel de mes Triangle Esprit Antal EZ, grosse montée au niveau des basses, impressionnant, un caisson de basse s'avère inutile. Mon ampli Yamaha RN1000A se concentre sur les médium haut et sur les aigus.
Pour info, suite au conseil donné ( merci encore aux équipes d’Audiophonics, technique et réactif) j'ai réglé mes curseurs sur un gain de + 29dB pour avoir le même niveau de volume.
Efthymios X.
NEUTRIK NC4FD-LX-B Embase XLR 4 Pôles Femelle Plaqué Or Cette embase Neutrik NC4FD-LX-B, appartenant à la gamme DLX, dispose de 4 pôles avec plaquage Or et d'un corps en métal. La gamme DLX offre des connecteurs...
As expected, good for its price.
Efthymios X.
The typical furutech quality, nothing to add.
Jean-Louis L.
Audiophonics a largement dépassé mes attentes en assistance et conseils, sans parler de sa réactivité et de son amabilité. WIIM Mini m'apporte exactement le service espéré avec une belle efficacité, Acheter cet équipement chez Audiophonics c'est top, merci pour tout !
VINCENT N.
Très bon transfo
J'avais commandé 2 transfos. Celui-ci comme l'autre respire la force tranquille. Très bonne construction, les fils de sortie sont d'un bon diamètre, les bouts sont bien étamés, les tensions aux secondaires sont identiques. Entièrement satisfait de mon achat.
VINCENT N.
Ce transfo respire la force tranquille. Très bonne construction, les fils de sortie sont d'un bon diamètre, les bouts sont bien étamés, les tensions aux secondaires sont identiques. Entièrement satisfait de mon achat.
François C.
LHY AUDIO LPS160VA 19V Alimentation Linéaire Régulée Faible Bruit 230V vers 19V 7A 160VA Cette alimentation linéaire régulée LHY Audio LPS160VA assure une grande stabilité pour tout projet DIY audiophile de haute...
indispensable
Installation sur un Mini PC I9, elle a remplacé l'alimentation d'origine haut la main et contribue au silence électrique de la sortie USB et réseau du logiciel HQPlayer.
Quelque peu imposante tout de même...
Gurhan O.
5239
Happy with the result. Need another 3m piece
Rossano F.
Tubes préamplification
Après l’achat de 4 tubes Golden Lion KT 88, j’ai acheté 2 tubes de la même marque pour la preamplification de mon amplificateur à tubes Fezz Titania !
Les graves sont plus profonds ! Les médiums plus clairs et les aigus plus fins !
Je suis très satisfait de cette évolution et je recommande audiophonics pour sa qualité de service et ses prix concurentiels…
Martynas D.
TOPPING E70 VELVET DAC AK4499EX XMOS XU316 Bluetooth 5.1 aptX Adaptive LDAC 32bit 768kHz DSD512 Noir Avec le E70 Velvet, Topping propose une nouvelle mouture de l'excellent DAC E70 dans une version mettant à l'honneur la nouvelle puce de conversion numérique /...
Topping E70 velvet
In my opinion, the product is well made and works fine. Would not hesitate to purchase a second unit if needed.
Shop experience is excellent, bought from the shop multiple times.
Bruce M.
Excellents résultats
Acheté en remplacement d'un Bluesound Node de 2016. Très satisfait du rapport qualité prix : amélioration nette de la qualité audio et bonne qualité de fabrication et de finition. Nécessite juste quelques connaissances très basiques pour accéder à l'interface utilisateur (expliqué dans le manuel) et sélectionner le mode de transmission réseau. Utilisé sans problème avec Roon (code livré avec l'appareil pour 2 mois gratuits) pour transmettre depuis Qobuz vers un DAC externe en utilisant la sortie SPDIF avec connexion RCA. Egalement testé avec câble USB. Testé également en mode UPnP avec logiciel Audirvana mais des problèmes de bruits blancs lors des changement de fréquence ou de bits dans la numérisation entre les fichiers : problème non résolu avec l'assistance technique Audirvana. Donc au final, utilisé avec Roon en attendant peut être la mise à jour du RED pour gérer Qobuz Connect.
En transport réseau (sans DAC interne donc), je crois que c'est parmi les meilleurs appareils dans cette gamme de prix et il bénéficie d'excellentes critique sur le Web. J'envisageais initialement un Lumin U2 (5000 €) mais je ne regrette pas du tout mon choix au final !
NEOTECH NEI-3004G Câble de Modulation Symétrique Cuivre G-UPOCC Graphène Ø8.5mm Le câble de modulation NEI-3004G de Neotech est un câble de modulation symétrique incorporant 2 conducteurs composites G-UPOCC, combinaison de cuivre OCC et...
câble équilibré, naturel, sans acidité, juste parfait. Entre mon DAC et mon intégré Il est équipé des xlr eizz ez-206, j'ai rien entendu d'aussi naturel. En fait, je crois que c'est la 1ere fois que j'ai l'impression d'écouter la musique sans "entendre" le câble.
Excellente découverte, tout comme le cable secteur de la même marque NEP-3003G. J'ai équipé le dac avec ce dernier et rien a redire, ça le fait.
NEOTECH NEP-3003G Câble Secteur Cuivre G-UPOCC Graphène 3x2.5mm² Ø12mm Le câble NEP-3003G de Neotech est un câble secteur incorporant 3 conducteurs composites G-UPOCC, combinaison de cuivre OCC et...
Cable dac
Equipé de fiches cuivre plaquées or, excellent rendu sur mon dac, c'est naturel, équilibré et ça respire. J'ai préféré ce câble à d'autres en raison de son prix raisonnable, je suis agréablement surpris.
Pas rodé et c'est déjà trés bon. Excellent rapoort qualité prix.
Dominique O.
ELECAUDIO HP-25OFCS Câble Haut-Parleur Cuivre OFC Plaqué Argent Isolé PTFE 2x5.1mm² Ø7.5mm Le reconnu et réputé câble HP Elecaudio HP-25OCC revient dans une nouvelle version, toujours plus performante, le HP-25OFCS. Celui-ci reprend la même...
5 étoiles - très bonne qualité
ai monté ces câbles sur des fourches plaquées or avec soudure à l'argent des embouts ; (sur tubes ampli de puissance KT88)
anciens câbles 2,5 carré ; nouveaux Elecaudio 5,1 carré ;
résultats :
- ciselé des médiums aigus complètement différent (amélioré) ;
- transitoires d'attaque améliorées ;
- basses généreuses sans être floues ;
par contre, étonné d'avoir rencontré un phénomène de rétractabilité de la longueur : sur les 3 m commandés je n'ai reçu que 2m80 , ce qui a rendu le raccordement des H.P. délicat à effectuer !
est-ce dû au transport par poste  ?  ??
Philippe S.
DIY OEUF JMLab/hp Atohm
Utilisé pour modifier des "oeufs" jmlab en plâtre en enceintes bass reflex avec des haut-parleurs Atohm Absolute Séries (kit EURUS E-5). Adaptation de l’évent parfaite.
Jerome C.
Fil de Câblage Cuivre / Argent 4mm² Gaine PTFE Ø3.6mm Rouge Ce fil de câblage d'un diamètre de 3.6mm dispose d'un unique conducteur de 4mm² en Cuivre OFC plaqué Argent. Cela permet d'obtenir une excellente...
En alimentation secteur, performant mais rodage très long.
J'ai utilisé ce fil de câblage pour recâbler une barrette secteur que j'ai optimisé , amortissement, câblage interne, filtrage passif.
L'écoute se fait au casque Sennheiser HD 600, Focal Clear , lecteur streamer Atoll ST 300 et ampli casque Sennheiser , donc l'acoustique de la pièce n'intervient pas.
Pour bien saisir le "gain" du bloc secteur, son cordon secteur est absolument basique, cordon générique 3 X 1mm2 de même pour les appareils.
C'est un fil de câblage qui fait très "premium" avec un PTFE très fortement serré sur un multibrin dont le placage argent, de bonne qualité ne se fait pas la malle lors du serrage sous vis.
Il nécessite un très long "rodage" comme il est coutume de dire dans le milieu audiophile , et je dois avouer que j'ai traversé des doutes avant que ce câblage se "réalise" enfin, il ne se passait rien même à 30 heures, comptez 60 heures.
A 60 heures l'écoute s'assouplie enfin car au début c'est dur et très "dans la face" donc pas écoutable, par contre ça devient bigrement intéressant à 60 heures avec un équilibre qui ne pêche pas par un aigu insistant (c'était ma crainte avec le placage argent )
L'ensemble est plus clair par une sensation de transparence accrue, clair mais pas maigre car du grave au médium la matière est là.
Le grave est très lisible, il plonge bas et donne une tension et articulation qui apporte au réalisme, on retrouve cette sensation sur les cordes de guitare.
Je gagne en transparence et les timbres se réalisent mieux, sur les voix c'est également tout bénef.
En fait les contours sont plus nets sur l'ensemble du message.
Les détails sur les fréquences aigus sont plus évidents.
Je pense qu'à la base le match de mes appareils est bon, donc il est possible que ça ne colle pas sur un match déjà limite sur l'aigu.
60 heures de rodage propose une restitution encourageante, je mets un léger bémol car j'attends encore un peu + de souplesse à l'écoute , je fais confiance au commentaire de notre ami anglais, ce câblage devrait se bonifier encore ....
Gérald F.
Transfo sur mesure
Top produit !
L’attente est longue mais ça vaut le coup !
VIABLUE T8 SOLDER Connecteurs RCA Plaqué Or Ø9.5mm (La paire) Ces connecteurs RCA T8 Solder de la marque Viablue bénéficient d'une grande qualité de conception. En effet, ils disposent...
Très bien !!
Fiches utilisées pour monter un câble numérique blindé en argent pur monobrin Xangsane XS-1001Ag diamètre 9mm.
Très bien au niveau des soudures et des vis qui bloquent bien le câble.
Il a fallu que je frotte avec du papier de verre pour réduire le diamètre de la gaine du câble Xangsane qui est un peu trop épaisse et la rentrer avec de la vaseline, les fiches n'y sont pour rien.
Top livraison Audiophonics !!
Hugues E.
AUDIOPHONICS GXDC-25 Câble d'Alimentation Jack DC 5.5/2.5mm vers GX16 Cuivre OFC pour Alimentations LHY 1m Ce câble d'alimentation Audiophonics, assemblé en France dans nos ateliers, se compose d'une part d'un connecteur Jack DC 5.5/2.5mm et d'autre part d'un connecteur...
Câble secteur DC
Apporte un vrai plus , plus d’ouverture , scène plus ample , pas d’agressivité ni effondrement de la dynamique, un petit rodage et que du bonheur
Olivier b.
Câble de Modulation XLR Femelle vers XLR Mâle Plaqué Or 1.31mm² 7.6m Ce câble de modulation XLR femelle vers XLR mâle offre de très bonnes performances à petit prix. Il intègre ainsi des conducteurs d'une section...
Câbles achetés il y a quelques temps car mon préampli hifi est positionné sur le côté de ma salle et assez éloigné des amplis (blocs monos). La qualité de fabrication est excellente, les câbles sont souples et facile à mettre en oeuvre, les fiches XLR robustes. J'ai eu l'occasion de les comparer avec des câbles 1er prix et il n'y a pas photo, le son est très nettement meilleur. Je craignais vu la longueur de perdre en détail et d'avoir du souffle par rapport à des RCA plus courts... il n'en est rien, aucun souffle y compris avec un pré ampli à tubes (bien entendu cela dépend du matériel) et la restitution musicale est top. Je recommande ce produit sans réserve, en remerciant Audiophonics pour assurer une logistique parfaite et ce depuis des années.
Vincent M.
Niveau à Bulle 66x11m pour Platines Vinyles Ce niveau à bulle en acrylique vous permettra d'effectuer une mise à l'horizontale juste de votre platine vinyle. Il s'agit en effet d'un paramètre important afin de conserver...
Niveau bien lisible de par sa taille. Prix très correct. Top !
Vincent M.
DYNAVOX TW-2 Pèse Cellule Électronique 0.01g - 200g +/-0.01g Cette balance Dynavox TW-2 est destinée à peser vos cellules phono vinyle. Ainsi, elle offre une mesure de haute précision sur une plage de 0.01g à...
Parfait. Qualité prix impeccable. Content de mon achat.
