Richard H.
Dayton Audio BST-300EX
précis et chaleureux
Eric v.
bonne prise
Avis clients - Il y a 19688 avis.
Emmanuel A.
NEOTECH NES-5004 Câble Haut-Parleur Cuivre UP-OFC 2x4mm² La gamme NES-5000 de Neotech intègre des câble à conducteurs Cuivre Ultra Pur UP-OFC tout en assurant un prix abordable. Dans cet esprit, le NES-5004 va...
Très très bon
Rendu très fin sans brillance sur un ampli marantz et enceinte b&w
Martins R.
XANGSANE XS-DIY1 Fil Argent Pur 99.99% FEP 0.08mm² Ø0.62mm Ce fil de câblage Xangsane XS-DIY1 profite d'une conception high-end, utilisant comme matériau conducteur de l'argent pur à 99.99%. Il assure ainsi une...
Perfect headphone cable
This is perfect quality pure silver cable. Phenomenal sound, pretty much no microfonics perhaps a bit on the stiffer side, but that's alright. Compared to silver that used before( which was 3n purity 0.2mm from silversmith) this has a lot better clarity, coherence of sound, and picks up almost no interference. Also a lot sturdier. Can recommend. Wil actually but again.
Douwe v.
FOSI AUDIO LC30 Commutateur Sélecteur Audio pour Amplificateurs / Enceintes Vu-mètre Jaune Avec son LC30, Fosi Audio dévoile un sélecteur d'amplificateur et d'enceinte. C'est-à-dire qu'il permet de commuter facilement et rapidement entre deux...
Good switcher but disappointing VU meter sensitivity
Unit was delivered with a loose screw inside. Not very nice but quickly fixed with permission of AudioPhonics support.
Build quality is rather decent especially from listening distance.
Remote control: great/logical layout. Yes it's light and a bit plasticy but it functions well. A more classy remote like the Apple Tv's aluminium remote would've been nicer at this price point.
Auto-on or Audio passthrough when the unit is switched off is not advertised or mentioned but it can be done. This unit seems a bit of a clone of the Douk VU3 and that one has powered-off passthrough:
Connect your main speakers @ Speaker 2 terminals and your main amp @ Amp B!
Then the VU meters..
Well, as mentioned everywhere: they're NOT sensitive, even at their maximum sensitivity. I am running quite sensitive Klipsch speakers and it's about 25 dB behind. So even with less sensitive speakers, I don't think you'd get a lot of swinging meters. They look nice though!
Dominique V.
Ampoule LED 6V Blanc Chaud Cette ampoule LED offre un éclairage blanc chaud. Elle s'alimente en 6V et saura trouver sa place dans de nombreux projets DIY.
Pour magnétophone Akai
J'ai commandé cette ampoule pour un remplacement sur un magnétophone à bande Akai qui a une cinquantaine d'années, pour l'éclairage des VU-mètres.
Elle fait parfaitement le "job" . Aucun problème d'adaptation de taille, elle fait le même diamètre et la même longueur que celle d'origine, une petite soudure à l'étain et le tour est joué. Dommage que je ne peux pas joindre une photo pour voir le résultat.
Dominique.
Matt H.
The best spade I’ve used
Really high quality spade. The construction with the 2 half’s of the spade work like a spring and help clamp in the binding post much better than a solid spade.
Matt H.
EIZZ EZ-206 Connecteur XLR Mâle 3 Pôles PTFE Plaqué Or Ø9mm Rouge (Unité) Ce connecteur XLR EIZZ avec isolant PTFE permet la conception de câbles XLR symétrique de qualité. Sa finition plaquée Or et ses borniers à vis...
Very good quality
Good value too and the solderless termination is perfect for the best sound.
FOSI AUDIO BOX X1 Préamplificateur Phono MM Le  Fosi Audio Box X1  est un petit  préamplificateur phono MM  simple, efficace et abordable. Celui-ci utilise des composants à faible...
Très bien !
Pour le prix, il est très bien !
Je l'ai commandé en express car j'attendais un préampli phono MM à tubes, clone d'un Audio Note (1 tube ECL82 + 1 tube 6z5p + 2 tubes 12au7 + 2 tubes 12ax7).
Il s'en tire très bien, avec interrupteur marche/arrêt en plus.
Livraison ultra-rapide de la part d'Audiophonics, bravo !
Excellent, vraiment !
Toujours aussi excellents ces condensateurs, que ce soit pour du filtrage HP ou pour remplacer des condensateurs dans des éléments électroniques haute-fidélité.
Celui-ci remplace un condo MKP chinois 0.22 µF dans mon préampli phono MM à tubes (1 tube ECL82 + 1 tube 6z5p + 2 tubes 12au7 + 2 tubes 12ax7) clone d'un Audio Note et le résultat est là.
Livraison express, félicitations à Audiophonics.
JANTZEN AUDIO SUPERIOR Z-CAP Condensateur 800V 0.47µF La gamme Superior Z-Cap de chez Jantzen Audio se compose de condensateurs non polarisés haut de gamme, conçus spécialement pour l'audio afin de permettra...
Excellents, vraiment !
Celui-ci remplace un condo MKP chinois 0.47 µF dans mon préampli phono MM à tubes (1 tube ECL82 + 1 tube 6z5p + 2 tubes 12au7 + 2 tubes 12ax7) clone d'un Audio Note et le résultat est là.
Romain G.
JANTZEN AUDIO SUPERIOR Z-CAP Condensateur 800V 2.7µF La gamme Superior Z-Cap de chez Jantzen Audio se compose de condensateurs non polarisés haut de gamme, conçus spécialement pour l'audio afin de permettra...
Meilleurs rapport qualité prix
Ses condensateurs (avec les mundorf suprême) sont le minimum à essayer si vous voulez entendre une véritable différence en terme de définition et à condition d'avoir un tweeter haut de gamme derrière, comme souvent je ne modifie qu'une enceintes sur le 2 et je fait des comparatif sur un signal mono (enceintes côte à côte) et la il n'y a pas de doute ce condensateurs apporte une scène sonor plus grande plus de définition, sont grand frère le allumen va plus loins surtout sur des compressions, chez mundorf la montée en gamme est moins significative je trouve
Romain G.
Enfin une connecteur non magnétique
Pour avoir essayé pas mal de connecteur rca la plupart sont magnétique lorsque qu'on approche l'aimant sur la partie centrale (donc pas du cuivre) celle ci est donc le meilleur rapport qualité prix même si c'est possible que ce soit tu laiton elles reste abordable et cran au dessu des concurrents
Patrick A.
SMSL AO200 MKII Amplificateur Class D Symétrique MA5332MS Symétrique Bluetooth 5.0 Subwoofer 2x160W 4 Ohm Le SMSL AO200 MKII est un amplificateur numérique Class D compact et performant, capable de développer une puissance de 2x160W sous 4Ω grâce à sa puce...
Accord parfait
Je ne trouve pas de mot plus approprié que "parfait". Cet ampli est le parfait mariage avec mes Tannoy System 800 (monitor). Le son est chaleureux, détaillé, la scène est ample, remplit tout l'espace. Ce son me plait beaucoup, je verrai à l'usage s'il s'améliore après quelques heures de rôdage.. Je destinais initialement l'ampli à mes Tannoy Mercury V1i (bibliothèque), pour remplacer un vieil Alientek D8 dans la chambre, qui donne pourtant toujours un effet WOW sur des pistes haute définition et bien mixées (couplé à un DAC Topping D50), mais après avoir testé l'ampli en XLR sur un Eversolo DMP-A6, d'abord sur les monitor 800, puis sur les V1i, je dois avouer que les 800 sortent gagnantes, le son est ample, enveloppant, chaque instrument à sa place selon le mixage initial de la musique. L'ampli SMSL AO200 MKII est très transparent, surtout en mode SDB sur l'égaliseur, il reproduit le son tel qu'il le reçoit. Pour le prix, n'hésitez pas, si comme moi vous aviez un petit ampli qui rendait déjà service (type Alientek ou Topping) et qu vous voulez un son qui monte en gamme, sans se ruiner, c'est l'ampli parfait! Les gros + : entrée USB, les entrées XLR, l'entrée bluetooth (quand on a un vieux DAC non équipé), les 2 sorties subwoofer, le réglage EQ maison SDB. Les petits - : pas de auto On/auto Off comme sur l'alientek (bien pratique pour que l'ampli se mette sous tension à la détection d'un signal audio) et pas de prise casque (mais je ne le destinais pas à un casque). Bref très content de cet achat, merci Audiophonics pour la rapidité du traitement de la commande!
Vladimir p.
GENALEX GOLD LION Tube Redresseur GZ34 / U77 / 5AR4 (Unité) Ce tube Genalex Gold Lion GZ34 / U77 est un tube redresseur, idéal pour remplacer un modèle équivalent défectueux.
Rectifier Gold Lion GZ34
Got this particular order the very next day (!) though the distance was few thousend km !!! Not only I did not expect delivarance this fast but I could never imaging this would be possible. Bravo, Audiophonics!
About rectifier GL GZ34 for my Muzi x7... It was very good right from the box - good separation, much more to hear in the Mids, good bass but Highs just a little rolled off. I knew that rectifiers need about 50hrs of burn in and after few days of use - voila! - Highs are comme il faut! My x7 never sounded better, and I have not even tried to roll power tubes yet (KT88)! But the most remarkable thing about GL GZ34 is that it is very musical: it takes notessounds and makes of them music. Love it! Can't wait to see what Mullard GZ34 will do (aph.fr has just shipped it to me).
So now I have 3 different very dicent rectifires to use - stock Muzi (very "tasty" sounding, slightly coloured but not too much), GL GZ34 and Mullard GZ34 (which is on its way home).
And thnx to aph.fr for excelent service, if I need something that they have I certanly will order from them. thnx.
alain l.
Produit très pratique quand on n'a pas les moyens ou la place pour acheter une machine à laver les vinyles. Par contre la dernière fois que j'en ai acheté dans un magasin parisien le flacon contenait 500mL. Pour un prix équivalent maintenant on a droit a 360mL. Il y a un peu de shrinkflation comme disent les américains.
Jean-Baptiste C.
EVERSOLO H1 DAC Amplificateur Casque Portable ES9281AC Pro MQA 32bit 384kHz DSD256 EVERSOLO propose avec le H1 un combo DAC et amplificateur casque portable compact et puissant. Disposant d'une entrée sur USB-C, c'est un compagnon idéal...
Excellent petit DAC
Sur les conseils de David Aubert (que je remercie au passage), j'ai acquis ce petit DAC pour y connecter mon smartphone et des écouteurs Sennheiser IE200. Le son est bon et assez puissant. En y connectant un casque plus gourmand, c'est un peu faible mais ce n'etait pas mon objectif donc je suis très satisfait. Le DAC est petit et n'est pas génant dans une poche.
Jean-Pierre D.
Avis complémentaire (usage avec préampli Gustard P26)
J'utilise l'ampli en mode Hi-Fi avec un préampli compétent le Gustard P26, j'ajoute donc un complément à mon précédent avis. Je confirme l'extrême qualité de la transparence et de la transparence sonore, cela n'ajoute rien et n'enlève rien. Cela ne pourra pas plaire à des personnes qui recherche quelque chose de "flatteur" moins rigoureux et plus indulgent. Par contre, par exemple le réalisme des instruments et des voix est surprenant. Je vois ça par mon utilisation avec des enceintes colonnes Triangle (gamme signature juste en dessous du haut de gamme Magellan) où rien n'est enlevé, ce n'est pas agressif dans l'aigu par exemple. Je dispose d'un second système avec un Denon PMA 110 de caractère différent que j'utilise avec des enceintes Focal. A mon avis, il est intéressant d'associer cet ampli de puissance avec un préampli au traitement raffiné et le résultat pour le prix est sans concurrence sur le marché.
BENOIT D.
HIDIZS S9 PRO Amplificateur DAC Portable ES9038Q2M Symétrique 32bit 768kHz DSD512 Hidizs propose avec son S9 Pro une version revue et corrigée du déjà excellent S9. Le combo DAC et amplificateur casque portable se base maintenant sur...
J'ai donné mon S9 à mon fils, je l'ai donc remplacé par le S9 pro. Je n'ai malheureusement pas pu les comparer en direct, de toutes manières je ne pense pas avoir les oreilles assez affutées pour percevoir la différence. Mais je suis ravi par la qualité du S9 pro. Je l'utilise principalement connecté entre mon smartphone Samsung et mon casque Grado SR325x. Parfait. Livraison parfaite par Audiophonics que je remercie pour la qualité de leurs produits.
BENOIT D.
AUDIOPHONICS Rallonge Jack 6.35mm Neutrik Mogami 2549 2.5m Ce câble rallonge Jack 6.35mm de 2.5m a été conçue à partir des meilleurs éléments du marché de façon à...
Très bonne qualité, la fixation du jack est très efficace. Livraison très rapide, comme d'habitude.
Daniel P.
J'ai d'abord regretté mon achat.
Montés sur un vieux Cayin A-88T le son son était vraiment mauvais, les anciens tubes étaient meilleurs et mon ampli Yamaha à transistors bien mieux. J'ai modifié plusieurs fois le bias, aucun changement, très décevant. Ce n'est qu'après trois semaines d'écoutes sans grand plaisir qu'un jour tout à changé, tout s'est mis en place, d'abord la scène sonore puis les basses et le reste, et maintenant c'est vraiment excellent. Très content.
Pierre F.
FIIO BR13 Récepteur Bluetooth 5.1 QCC5125 DAC ES9018K2M aptX-HD LDAC 24bit / 96kHz Le FiiO BR13 est un récepteur Bluetooth équipé d'un DAC performant. POINTS CLÉS : Puce de réception Bluetooth 5.1 QCC5125 SBC,...
fait le job pour moderniser une chaine HiFi qui n'avait pas d'entrée Bluetooth ou USB.
rappel : la qualité de la transmission dépend de la source (mp3, CD, qualité studio, ...)
entrée Bluetooth :
il faut une alimentation externe (prise USB)
appairage sans difficulté avec le smartphone
appairage plus compliqué avec le PC (w10) : il m'a fallu aller dans la gestion des services windows (prise en charge Bluetooth) et basculer la sortie audio du PC de "haut-parleurs" vers "audio FiiO BR13" pour transmettre le son vers la chaine.
entrée USB :
la source (PC) fournit à la fois les données et l'alimentation (USB Type-A)
Pierre F.
produit conforme mais attention
le câble livré avec, est un Type-A _ Micro-B
Jérôme P.
Vis à Bois à Tête Cylindrique à Six Pans Creux Acier 8.8 CHC M5x35mm Noire (x10) Ces vis à tête cylindrique à six pans creux noires sont au format M5x35mm. En acier 8.8 elles assurent une grande durabilité.
Vis de très bonne facture, et difficile à trouver sur internet !
La tête CHc donne un super look PRO, parfait pour faces avant, planches de bord, instrumentation de cockpit, etc..
Eelco R.
It actually works
I also was sceptical about what to expect but the cable actually makes a difference. It’s huge (my son was jokingly calling it the water-hose) and you have to purchase appropriate plugs.
Once connected, I immediately noticed a difference in detail and clarity. Also the spacing seems improved. The highs are a bit more prominent and that’s getting used to. But only used the cable for about 8 hours so have to see how this progresses.
Bettinger F.
Fi-03 or vs FI-03 rhodium
J'avais initialement remplacé la fiche iec de mon intégré à tubes par le modèle identique mais plaqué or. Les deux variantes sont plus performantes que la prise d'origine, mais elles ont des caractères différents.
Si votre système est sec/agressif, et que vous cherchez à calmer les choses, ou si vous cherchez un peu de chaleur, optez pour la version or.
Si au contraire vous voulez améliorer le niveau de détail, les transitoires, tout en conservant un équilibre tonal neutre, je vous conseillerais plutôt la version rhodium. Sur un système à tubes, après 300h de fonctionnement le gain est évident.
Pensez également à tester les deux sens du fusible, eh oui cela a aussi une influence !
GUSTARD R26
GUSTARD DAC-R26 is an excellent R2R DAC, I used to have SMSL D1s, they are quite decent, however, GUSTARD is far away in sound, has stronger dynamics, clear highs, solid bass, full mids, settings are simple, then I did not try RJ45, nothing USB works great, I probably wouldn't use Roon, it's a parody of Audirvan, everything can be set much better there and with good tuning it gives excellent performance. Of course, it plays even better with the HQ player, which I would recommend. The conversion to DSD 512/1bit is fantastic. MQA also has very good results in presenting the sound space. You will then receive an excellent signal into your amplifier. This DAC is an excellent choice for more advanced connoisseurs. I recommend listening to the album Jean Guillou – Orgue et Percussions. You will get excellent space, wonderful acoustics, perfect dynamics, of course it depends on the type of your amplifier and speakers. This DAC is so good that I am considering buying another one. I can definitely recommend
Stéphane L.
MINIDSP FLEX Processeur Audio DSP SHARC ADSP21489 XMOS Bluetooth Le miniDSP Flex est la 3ème génération de processeur audio à 2 entrées et 4 sorties de la marque. Il garde ainsi le puissant processeur...
Très bon DSP
Excellent rapport qualité prix. Utilisé dans une config 2.1. Le jour et la nuit avec mon ancien filtre passif sur le caisson. Sorties analogiques de bonne qualité (genre DAC à 300/500€). Manque juste un trigger 12v pour en faire un produit parfait.
David L.
Trés sympa mais calibrage limité
Petit appareil tres bien fini, solide, design simple et propre.
L’idée etait de juste en tester un pour éventuellement en prendre 4 pour mon 4.1 haut rendement.
C’est surtout un watt metre et selon le systeme ça va swinguer plus ou moins.
Dans mon cas, oú en plus je ne cesse de réduire la puissance suite aux mesures de tensions en utilisations diverses, ben ça bougeait presque pas.
J’ai bien tenté de l’ouvrir pour voir si on pouvait le modifier pour étendre la plage de calibrage, mais c’est au dessus de mon niveau.
Du coup en fouillant un peu les interwebs, “Z review” proposait une bonne idée pour palier au calibrage trop limité : carrément lui dédier un ampli.
Cad ne brancher qu’un ampli supplémentaire en source, sans hps, une sorte de circuit parallele et plus facile á calibrer du coup, pour swinguer les aiguilles sans se péter les feuilles.
J’avais un canal libre sur mon master dsp donc facile, un ptit v3 qui trainait et hop on branche.
Ensuite réglages niveau dsp / volume ampli / calibrage lc30 pour atteindre un comportement plus vivant.
Au final c’est tres sympa, d’ou le long retour ici.
Ça bougeotte a peine pour les ecoutes tranquilles, ça swingue bien pour le pêchu, mais bien sûr ça sort du cadran pour le vraiment fort, pas grave c’est rare de toutes façons.
Selon Fosi l’ampli voit quand meme 390ohms, en tous cas il ne chauffe absolument pas, et consomme rien.
Le top serait le meme genre d’appareil mais branché en digital sur la source, sur le -0dbfs.
Un step de plus en 25% sur les leds serait pas mal aussi, voir choisir la couleur elle meme, ça je vais ptet le bricoler.
Aiguilles tres reactives, a chacun de juger moi ça me va.
Ha, et il est assez gros et vide pour y mettre une TPA, j’dis ça comme ça Audiophonics hein ;)
Robert C.
Must try cable for speaker cables
For my DIY amplifiers with output power up to 40W per channel this cable is absolute favorite. Easy to assemble, flexible and more important absolutely transparent.
Robert C.
Incredible discrete OPAs
Everything is written and said in the online reviews on the web.
Natural, transparent, never harsh and with very good sound stage width and depth. Outstanding for the OPAs. Bravo Sparkos!
super génial
très bon produit le seule bémol les taxe de douane pour la Réunion dom 5 étoile merci
Philippe s.
Branché sur une platine Rega Planar One, il assure complètement le job et cela pour un prix défiant toute concurrence. Comme d’habitude avec Audiophonics, expédition très rapide et soignée.
Jimmy S.
EVERSOLO AMP-F2 Amplificateur Class D 2x250W 4 Ohm / 1x450W 2 Ohm Le AMP-F2, développé par EverSolo en collaboration avec l'équipe Starke Sound, est un amplificateur Class D basé sur l'intégration de...
Puissance
Produit très bien, mais manque de puissance par rapport a ce qui est annoncé, voila pourquoi je retire une étoile,
Notre atelier a vérifié les données constructeur.
La puissance annoncée est bien au rendez vous.
Luis C.
todo el proceso impecable
todo el proceso impecable, buen embalaje y buen precio
Thierry V.
NEOTECH SOCT-20 Fil de câblage Cuivre UP-OCC PTFE 0.5mm² Neotech a longtemps été le leader dans la production de câbles en utilisant le cuivre UP-OCC "monocristal" développé par le professeur Ohno de...
Bon cuivre mais...
Il n'y a rien à redire en ce qui concerne le cuivre. Le bât blesse par contre un peu dans l'isolant extrêmement difficile à travailler, à dénuder, glissant, et qui n'est que rouge. Ce qui oblige à le gainer si on cherche l'esthétique.
Kevin H.
SMPS800RE Module d'Alimentation à Découpage 800W +/-40V L'alimentation à découpage SMPS800RE est un modèle à très haut rendement capable de développer une puissance nominale de 800 Watts dans...
LD Systems Maui 11G2
Parfait pour remplacer les alims défectueuses des LD Systems Maui 11G2. Sur les trois systèmes que j'ai (qui ont environ 5 ans) deux ont vu leur alimentation d'origine casser de la même manière, sans aucune raison apparente...
Manuel G.
Avec ce câble, j’ai à la fois réalisé des cables d’enceintes et des cables secteur. Le résultat est à la hauteur de ce que j’attendais. J’ai essayé sur plusieurs types d’enceintes. Ce câble amène plus de douceur, de neutralité, de définition et à la fois plus de dynamisme.
Soyez bien équipé des bons outils. La pince à dénuder est obligatoire, Une petite pince qui serre, mais sans couper vous permettra de dénuder les petites gaines PE.
Si vous voulez relier votre câble à la carcasse de votre ampli, il faudra couper une première fois et recouper une seconde fois les cables de manière à ce que le fil de drain soit plus long.
Je note cinq étoiles ce câble, mais je note uniquement 2 étoiles le service commercial, qui n’a pas été à l’écoute de ma demande. Ils m’ont automatiquement orienté vers des cables d’une autre marque (Mogami, elecaudio) Qui soi-disant ont un meilleur rapport qualité prix. Je connais ces cables et il n’arrivent pas au niveau des ramm audio. À croire que les commerciaux de Audiophonics se basent uniquement sur les avis et le nombre de ventes… D’autre part, même pour une commande de 1000 € pour 14 m de câble, ils sont inflexibles sur les prix. Dommage que la démarche commerciale ne soit pas de la partie.
Alain D.
Excellent et compatible ROON
Très rapide sur les frappes de cordes et peaux, fin et détaillé. Spatial
pas de distorsion a fort niveau. géré par ROON est très pratique
Jean-Pierre D.
GUSTARD P26 Préamplificateur symétrique Discret Class A XLR RCA Noir Le P26 de chez Gustard est un préamplificateur / contrôleur de volume / sélecteur de souce (3 entrées) élaboré. Il fera le bonheur des...
Un composant intéressant pour un ampli de puissance
Je recherchais pour exploiter mon ampli Purifi Audiophonics HP 400 ce type de préamplificateur, il s'avère idéal car j'ai à driver des enceintes Signature Delta de Triangle (vu sa caractéristique classe A). Les Triangle sont exigeantes en électronique car ce son des enceintes extraverties très chantantes.
Le résultat est très bon pour un prix d'achat pas dans ce que l'on trouve habituellement sur le marché. Pour l'instant, j'ai connecté en XLR avec l'ampli de puissance en XLR et en RCA avec le lecteur réseau (un Eversolo DMP A6), j'envisage plus tard un XLR pour cette dernière interconnexion. La restitution est pleine, détaillée et neutre avec un joli son jamais agressif, c'est une prouesse avec les Triangle. Je recommande pour ceux qui recherchent ce type de préamplificateur.
jean michel G.
Avis
Sur un ampli BC ACCOUSTIQUE EX362D avec des Monitor Audio Silver 300 7g que je trouve un haut du spectre présent, ce câble ferait-il l'affaire ?
Marco H.
APERION AUDIO ENERGY 7 Amplificateur de Puissance Class AB 7 Canaux 7x230W 4 Ohm Le Aperion Energy 7, amplificateur de puissance Class AB à 7 canaux, permet de fournir une puissance et une dynamique considérable à votre installation...
High quality Sound with amazing Bass!
Imported one Aperion Audio Energy E7 Amplifier to pair Marantz Cinema 40. It is a new demension in Bass with high quality of Sound! Thx to Aperion Audio and Audiophonics in France from Germany ❤
David C.
SHANLING ET3 Lecteur CD Philips SAA7824 Sanyo HD850 WiFi DLNA AirPlay Bluetooth 5.0 aptX HD LDAC 32bit 768kHz DSD512 MQA Noir Le Shanling ET3 se présente comme un lecteur CD complet et puissant, proposant un design moderne et offrant d'excellentes performances sonores. Polyvalent, il met...
Superbe!!!
Ce drive CD est tout simplement magnifique & dans tout les sens du terme! La qualité de fabrication est très sérieuse, cela ce ressent au poids de l'appareil par rapport à sa taille....
Il est couplé en câble toslink au Bleusound Node 130 utilisé sur un ampli REGA BRIO (2017) équipé d'enceintes colonne HIGHLAND AUDIO ORAN 4305. Et très sincèrement bluffé par le rendu sonore de ce lecteur, rien à envier à mon ex ATOLL MD100!!!
La prise en n'est pas évidente surtout que le mode d'emploi est dans une langue que je pige pas (l'anglais)! Mais j'ai quand même réussi, après quelques heures de bataille à exploiter quelques fonctions: le Bluethooth franchement excellent rendu, appairage facile; AIRPLAY via Mac génial la pochette de l'album s'affiche sur l'écran!! J'adore! Bon parfois quand ont change d'album le changement de pochette peu prendre un peu de retard..... Il y la possibilité de se connecter à Tidal, pas encore essayé .... je verrais ça si je valide l'abonnement. Concernant l'application pas mal... mais certaines fonctions me paraisse pas assez aboutie, dont une réservée à la chine. Pour ce qui est du MQA pas encore l'utilité, ont verra ce que ça vaut le jour où....
Bref ce lecteur est une petite merveille!!! Il est beau, prend peu de place et procure un son splendide !!!!
Merci à AUDIOPHONICS pour l'expédition super rapide et son emballage sérieux, car le carton avait pris des coups & heureusement que SHANLING aussi n'hésite pas à mettre un double carton!!
p.s: Attention au disc cover il est en verre (épais quand même), pas besoin de vous expliquer plus..... Donc petite question à AUDIOPHONICS: Est-il possible d'en avoir de rechange???
Guillotin O.
HIFIBERRY DAC+ RCA Module DAC pour Rasberry Pi Burr Brown 24bit 192kHz Le HiFiBerry DAC+ est un module convertisseur numérique / analogique basé sur une puce DAC Burr Brown supportant les flux PCM jusqu'au 24bit 192kHz. Il a...
Le produit est conforme à la description. C'est la 2e carte hifiberry que j'utilise et je ne suis pas déçu.
AIYIMA TUBE-T3 Préamplificateur Phono MM à Tubes 2x 6A2 Noir Le Aiyima T3 est un préamplificateur phono simple et abordable pour platine MM. Il embarque deux tubes 6A2 et dispose d'un contrôle de gain à trois niveaux,...
tres tres bon !
j'ai attendu un peu que les tubes se rodent avant de poster ! vraiment ce petit boitier est surprenant ! excellent son je dirais !
puis j'ai remplacé les tubes d'origine par des mazda 5654 v4 nos et c'est encore bien mieux ! ma vieille mais encore vaillante thorens 160 mk 2 s'est remise à chanter comme à l'époque ou je l'ai achetée en 1975! ! je redécouvre mes vinyles ! Son chaud et rond trés tube ,bien détaillé ,bel equilibre !
niveau livraison :comme d'hab rien à dire parfait !
merci audiophonics !
Sebastien D.
DYNAVOX Fiches Bananes Plaquées Or Ø5mm (La paire) Ces fiches bananes Dynavox à petit prix permettent une connexion simple et rapide aux borniers de vos enceintes et amplificateurs. Les contacts sont plaqués Or afin d'assurer...
bien
Fiches banane de qualité pour le prix, faire attention quand meme certaines vis peuvent etre déjà serrées d'origine faut y aller molo si c'est le cas sur les votres pour désserrer sans foirer le pas de vis, ce que j'ai fais et tout c'est bien passé ;)
Sebastien D.
Câble HDMI 2.1 8K 60Hz 48Gbps HDR eARC ALLM Dolby 1.5m Ce câble HDMI 2.1 d'une longueur de 1.5m supporte les flux vidéo haute définition jusqu'en 8K 60Hz, 4K 120Hz ou encore 2K 144Hz. Il est par ailleurs...
Un cable bien conçu qui respire la qualité.
Dario G.
AUDIOPHONICS DA-S125NC Amplificateur Intégré Class D NCore NC122MP DAC ES9038Q2M Bluetooth 2x125W 4 Ohm 32bit 768kHz DSD256 Polyvalent et performant, nous vous proposons avec le DA-S125NC un amplificateur intégré à entrées numériques auquel il suffira d'ajouter des...
Très étonnant !!!
Félicitations audiophonics, envoie rapide, emballage sérieux.
Ai eu plusieurs amplis intégrés, classe AB, CLASSE T, tube...
Dans le cas de cet intégré, conseillé par un ami c'est une excellente surprise !!
Il sort à peine du carton et déjà grave ( Hp de 38) profond et très articulé, scène sonore large et profonde, beaucoup de nuances, détails abondants, son reposant sans aucune acidité.
A ce prix... pourquoi dépenser plus, bravo audiophonics.
Thomas C.
AUDIOPHONICS HC Trigger Switcheur d'installation Home-Cinéma / Hi-Fi 12V L'Audiophonics HC est un trigger home-cinéma dont le premier interêt est de vous éviter de changer les branchements de câbles...
Au top
Voici le genre d’accessoires très pratique au quotidien.
Deux installations un ampli de puissance. Plus besoin de débrancher/rebrancher son installation.
A l’usage pas de souffle perçu sans musique, la bascule se fait automatiquement.
A recommander.
A quand une version qui ajoutera la fonction de symetrisation du signal ?
tres tres bon !
j'ai attendu un peu de rodage des tubes fournis c'était déjà vraiment très bien ! puis je les ai remplacés par des Mazda 5654 v4 nos ! c'est encore bien meilleur !! ce petit pré est vraiment étonnant ! très bel équilibre et des mediums et aigus chauds et ronds très tubes très fins !!
bref très très bon achat !! je peux enfin écouter mes vieux vinyles sereinement avec délectation !!!
ne surtout pas oublier de connecter le fil de masse bien sur !!
le son est meilleur chez moi avec le maximum de gains !
ma vieille Thorens td 160mk ii retrouve ses airs de jeunesse !
ps: niveau livraison ras ,parfait comme d'hab !
merci audiophonics ......
André G.
Qualité et ecoute
Utilise entre un ampli de puissance et un equalizer paramétrique pro ce câble qui semble solide m a donné satisfaction au niveau sonore. À recommander
OPA1612 AOP Double DIP8 (Unité) L'amplificateur opérationnel double TI OPA1612 profite d'excellentes caractéristiques techniques, permettant de très bonnes performances électriques...
Upgrade indeniable
Par rapport au ne5532, cet aop offre de meilleures bass,, moins de bruit donc plus de définition et de musicalité.
