Marc C.
Que dire ?
Bertrand j.
neutrik
Ramiro F.
Avis clients - Il y a 20142 avis.
lars s.
Superb sound
Superb sound quality
Leonas J.
TUNG-SOL 12AU7 / ECC82 Tubes (Unité) Le Tung-Sol 12AU7, fabriqué en Russie, assure un très faible bruit. Il a été conçu pour imiter les performances des tubes américains...
leonasj
very musical tubes,separate instrumens,3D sound ,low noise,nice vocals,linear gain. way far better vs im tried TAD,telefunken,rft tubes. immediatly loved them after change my xduoo ta-22 stock tubes( also very good linear sound,but tungsol goes further)
Clive S.
The whole order/delivery process went perfectly.
My first reaction on listening was something was wrong with my foot, then I realised that I was tapping my foot to the music, something that I hadn't done for a while!
I'm still running the DAC in but so far I'm very surprised and very impressed. More later
Clive
Roland v.
LITTLE DOT MKIII Amplificateur Casque / Préamplificateur à Tubes Le Little Dot MKIII est un très bel amplificateur casque à tubes, offrant d'excellentes performances audio. Il est surmonté de deux tubes GE5654 (United...
Excellent!
I bought this pre amp after reading a lot of positive reviews on the internet. I use it only for headphones (AKG 500, Beyer Dynamic DT 770 Pro and Sennheiser HD600). The amp was delivered as expected en well packed. The look and finish is beautifull, construction very solid and the potmeter feels very good and even on all volume setting. The sound is very good paired with the HD600! A touch of tube warmth and detailled sound with good space. I've orderd som Vosnek tubes to try. I also try it with HD 605 wich I expect soon. The unit is stille burning in (3 days now) but very happy so far. For this price very very good! If you have a HD 600 or Beyer DT 770 pro it is a serious upgrade compared to a standard headphone connection. Highly recommended!
Peter B.
Excellent quality
I had to wait for quite some time to get this modules but they are worth waiting. The modules are (compared to a lot of other TPA3255 modules) of excellent quality. A large milled heat sink with tapped holes to fix the modules in an enclosure, high quality parts, precisely aligned (SMD)components, and larger/heavier components fixed with an elastic adhesive. I haven't tested them yet but I am quite confident that they sound as good as they look.
jean luc L.
MUNDORF MRESIST SUPREME MRES20-2.7 Résistance 20W 2.7 Ohm La gamme de résistance Mundorf MResist SUPREME propose des produits d'une qualité exceptionnelle. Avec un réel impact sur la restitution sonore, des...
MUNDORF MRESIST SUPRÊME
Sa fourmillent de détailles !! super
Jean-Marie B.
Qualité et subtilité du son
J'ai acheté un 2 em pour mettre entre la platine CD et l'ampli HG MARANZ pm8006 ..une seulle critique et un défaut a signaler au fabricant ''les slots dans lesquels rentre les tubes sont de mauvaises factures car les lampes fournient 6k4 pour les rentrer c'est du délire de fou
gilbert d.
Pour une enceinte centrale
gilbert d.
JANTZEN AUDIO ELECAP Condensateur Électrolytique 100V 5.6µF 5% Les condensateurs électrolytiques Jantzen Audio EleCap sont des condensateurs aluminium non-polarisés utilisant une feuille gravée ou "brute". Avec une...
gilbert d.
JANTZEN AUDIO CROSS-CAP Condensateur 400V 10µF Les condensateurs Jantzen Audio Cross Cap MKP 400V sont considérés comme étant le meilleur rapport qualité/prix pour la conception de filtres passifs...
gilbert d.
DAYTON AUDIO RS125-4 Reference Haut-Parleur Bas Médium 30W 4 Ohm 90dB 65Hz - 5400Hz Ø13cm En combinant un moteur sophistiqué doté en interne de 2 raccourcis électriques distincts, et un cône en aluminium ultra rigide, les transducteurs de...
Pour une enceinte centrale diy
gilbert d.
Ovidiu P.
MINIBOSS PLAYER PLUS Lecteur Réseau Volumio DAC 32bit 384kHz Amplificateur 2x50W 4 Ohm À l'image de son grand frère le Boss DAC, ce Allo MiniBoss Player Plus est un convertisseur numérique / analogique (DAC) haute résolution basé...
Awesome little streaming combo!
If its power is enough for your speakers this is a pleasure to use and listen to. I would even say it is amazing in this price range.
I replaced the preinstalled Volumio with MoodeAudio and this little streaming amp + DAC is now giving me a lot of joy.
However my advice to potential buyers is to replace the SD card with a higher quality one. You should also use a high quality power supply for the RPI zero w and if possible disable the onboard Bluetooth as it seems to interfere with the WiFi chip.
Lionel B.
J'ai monté ce câble avec des Furutech CF-102 en liaison numérique entre Bluray et processeur en remplacement d'un câble O2A Elegance.
Bien que ce dernier me donnait pleine satisfaction il n'y a pas photo. Ce câble Furutech ramène une foule d’informations supplémentaires. La dynamique est nettement améliorée. Un rapport prix / agrément imbattable comme souvent avec Furutech (Compter une dizaine d'heures de rodage pour ôter toute agressivité)
Panos M.
Module DAC ESS ES9038Q2M I2S Optique Coaxial 32bit 384khz DSD256 Ce module DIY basé sur un DAC I2S ESS ES9038Q2M offre de nombreuses possibilités d'utilisation dans un format de carte compact. Celui-ci dispose en effet...
Quite nice to build uppon
For its price it is really a no-brainer. Using a few of them and if you are up to it, use muses3 opamps, change the clock and use dedicated cpu's on all sections, removing the onboard regulators.
Then this baby can sing
Michel B.
DYNAVOX AMP-S MKII Commutateur Sélecteur Audio pour Enceintes / Amplificateurs Noir Le Dynavox AMP-S MKII offre la possibilité de commuter entre deux paires d'enceintes lors de l'utilisation d'un amplificateur HiFi. Inversement, il permet aussi de...
Solide, bien construit avec des composants de qualité, suffisamment lourd pour ne pas être soulevé par les câbles qui y sont branchés, excellent donc.....bon ce n'est qu'une boîte noire qui n'est pas particulièrement jolie mais je suis sûr qu'il y a plus horrible sur les étagères !
Patrice J.
Connecteur USB mâle Type B DIY Plaqué Or / Nickel Ce connecteur USB-B est idéal pour confectionner votre propre câble USB ou réparer un connecteur défaillant. Les contact sont en alliage de cuivre et...
Connecteur USB B d'excellente qualité pour fabriquer un câble numérique. En ce qui me concerne, j'ai reçu cet article sur lequel il manquait une fiche pour souder un des conducteurs du câble numérique (en théorie au nombre de quatre).
Après avoir signaler cet incident, le SAV d'Audiophonics m'a renvoyé un connecteur conforme, montrant ainsi leur sérieux et le besoin de satisfaire sa clientèle.
Bravo Audiophonics pour votre professionnalisme !
Dragoljub Ć.
IKKO OBSIDIAN OH10 Écouteurs Intra-Auriculaire IEM Hybrides Dynamique et Balanced Armature Les Ikko OH10 sont des écouteurs intra-auriculaires hybrides, intégrant à la fois un haut-parleur dynamique et un haut-parleur balanced armature. Sa...
Cyberpunk
Really great with FLAC material using foobar2000 and RetroArch upsampler, and also my own electronic music in Ableton Live, going through RME Fireface UCX II at 192kHz (98kHz in Ableton Live), the original cable, and some cheap 3.5mm to 1/4" adapter. Also very good with Moondrop Dawn 4.4mm over phone and CTU-01 cable, although I didn't get it to work in higher bitrates on my phone yet. I'm not sure, but I think I need to get some app for that. It seems like it has less bass compared to listening from the RME interface. Which seems reasonable considering that RME has an external power supply.
This is my first pair of IEMs. But I've used Behringer Truth B2030A and AKG K 271 MKII.
Having two types of drivers seems very basic, at least in modern terms, but it's part of a world of miniaturized Hi-Fi sound systems which fit into your ear.
Yes, my initial assumptions were confirmed. This is the closest thing we have to a virtual reality device like some of the devices described in novels of ... ah, help... the guy who wrote Neuromancer, yes, William Gibson.
Balanced armature - who cares what it means. It screams cyberpunk.
Luc M.
CYP CPLUS-V11PE8 Extracteur Audio HDMI 4K60 LPCM 7.1 avec EDID et Contrôle RS-232 Cet extracteur audio HDMI peut récupérer jusqu'à 8 canaux du flux LPCM depuis une source HDMI, permettant de convertir un flux HDMI audio...
Tres Pratique
Me permet d’attaquer mon DAC en 192 Khz en provenance d'une source HDMI avec protection HDCP 2.0
Christophe G.
Très bon connecteur
J'ai commandé ce connecteur pour une alimentation externe à un préamplificateur. Le connecteur me permet de connecter le coté négatif, la masse et le coté positif. En plus, j'ai connecté la terre sur le boitier du connecteur, de façon à relier le boitier du préampli à la terre.
Marco P.
IAN CANADA DUAL MONO PLUS DAC ES9038Q2M HAT Raspberry Pi / I2S & SPDIF / PCM DSD Le module Ian Canada 9038Q2M Dual Mono DAC HAT est un DAC de très haut niveau pour Raspberry Pi. Il exploite deux puces ES9038Q2M SABRE 32-bit intégrées en mode double Mono.
Very Good
I built a streamer-DAC on Volumio platform and this hat was simply surprising. With transformers output and a linear supply it gives great reproduction results. Smooth and clear timber, stable scene. To me it's really good solution, better than other I implemented in the past. Cost is a bit high but you will be rewarded with good sonic performance
Jean Paul T.
Absorbant vraiment efficace
Produit très bien réalisé, facile à utiliser, diminution des résonnances internes très importante, mesure "perso" d'environ 15 dB à partir de 600 Hz , de loin largement supérieur à de la ouate en vrac. Devrait supprimer l'effet de boite, et donner un son beaucoup plus naturel.
Werner H.
NEOTECH STDCT-20 Fil de Câblage Multibrins Cuivre UP-OCC PTFE 0.52mm² Le fil de câblage STDCT est un câble de très grande qualité multi-brins avec conducteur en Cuivre UP-OCC pur à 99.99998% et isolation PTFE....
very good product
Werner H.
NEOTECH STDCT-18 Fil de Câblage MultiBrins UP-OCC PTFE 0.8mm² Le fil de câblage STDCT est un câble de très grande qualité multi-brins avec conducteur en Cuivre UP-OCC pur à 99.99998% et isolation PTFE....
very good product
Werner H.
very good product
Werner H.
very expensive but very good product
Fabien C.
NEOTECH NES-5001 Câble Haut-Parleur Cuivre UP-OFC 2x4mm² Ø15mm La gamme NES-5000 de Neotech est composée de câbles à conducteurs Cuivre Ultra Pur UP-OFC tout en assurant un prix abordable. Le NES-5001 est composé...
Fait le café
Un très bon câble. Pour ma part, le registre grave s'est amélioré. Beaucoup plus de matière, de profondeur et surtout mieux contrôlé. Pour le reste du registre (médium, aigu) un peu plus d'aération dans le haut du spectre (lumineux ?).
Pour la qualité du câble en lui-même : câble très souple malgré sa taille. En parlant de taille :), il faut faire attention à la découpe. La gaine extérieure est très tendre donc les gaines des conducteurs sont très vite atteints. Dans l'ensemble très content de l'achat et un rqp pas trop mal.
Quant à Audiophonics, parfait comme d'habitude.
Config : RME ADI-2 DAC FS (tu parles d'un nom... :), Simply Italy, B&W 705 Signature, source Audirvana
Chére mais efficace
Fais presque aussi bien que sa grande sœur de la même marque pour un prix moindre qui reste élevé toutefois . Restitution d' un grand naturel ou rien ne manque .
Ludovic M.
Commandé pour reparer un preampli JC concept
Identique a l’original.tres fin a l’ecoute
Jean-Michel N.
NEOTECH NEET-1008 Câble Ethernet RJ45 Argent UP-OCC 1m Neotech propose avec son NEET-1008 un excellent câble Ethernet RJ45, profitant d'une conception d'exception. Celui-ci intègre en effet quatre paires de conducteurs...
beaucoup plus de plaisir....
Amélioration dans tous les registres.vives recommandations.
Dominique L.
Un amplificateur audiophile basique
J'ai commandé le premier amplificateur Audiophonics K214 V2 le 24/11/2020, puis un deuxième qui arrive prochainement. Suite à un rodage de cent heures, le son n'était toujours pas chaud alors je l'ai gardé comme amplificateur de dépannage sans trop comprendre pourquoi le mien conservait un son froid, creux, analytique.
Je m’en suis servi de temps en temps et j'ai constaté une nette amélioration du son avec une chaleur bien venue. J'ai réalisé le test avec le casque Beyerdynamic DT 770 PRO qui m'avait servi pour le rodage de l'amplificateur à sa réception. J’ai d’ailleurs utilisé d’autres casques pour les tests. Ce casque semble être une bonne association avec cet amplificateur. J’ai utilisé mon PC et YouTube (la sortie est paraît-il en PCM 2.0). La différence entre le premier test et le deuxième est incommensurable. J’ai du mal à croire à un effet psycho-acoustique et je pense plutôt qu’il est question ici d’un vieillissement des composants utilisés car il est bien question d’un montage audiophile classique de classe A à transistor. Ce qui complique la donne, c’est que la source n’est pas stable comme avec du matériel HIFI classique en raison du fait qu’il est question d’un objet connecté supportant de nombreuses mises à jour, en l’occurrence Windows 10 puis Windows 11.
Il n’y a pas beaucoup d’amplificateur à transistor mais plutôt à AOP (Amplificateur Opérationnel), il y a également le MONOLITH LIQUID SPARK qui est à transistor mais il utilise des composants de surface plus modernes, il représente également une exception dans les amplificateurs pour casque dans sa catégorie.
Nnanna E.
FIIO KA2 LIGHTNING DAC Amplificateur Casque Portable 2x CS43131 32bit 384kHz DSD256 Avec le KA2, FiiO propose un combo DAC et amplificateur casque portable performant et abordable, pour vous permettre de profiter de la meilleure qualité sonore possible,...
Decent DAC for iPhone
Listening to music on this DAC is impressive and you can tell FiiO engineered a good device with quality components. It gets loud enough if you like a bit more power but doesn’t drive full size headphones to their full capacity. Distortion can be heard on certain earphones only at very high volumes but below that it is a pleasure to listen to
Maurizio B.
TOPPING PRE90 Préamplificateur Symétrique / Asymétrique NFCA Argent Le Pre90 de Topping est un préamplificateur extrêmement performant, basé sur un circuit totalement symétrique et des modules NFCA hautes performances....
Perfectly transparent Preamp
I decided to add the Pre90 plus the EXT90 to the D90SE to avoid switching my cables between my home theatre processor and the D90SE. I was not sure how to do it, but a quick email to Topping support provided a perfect solution: add a custom button to the Home Theatre setup with 00db attenuation and the other to the stereo setup. Voilà! After many years I have the perfect solution for my needs. On top of that, the Pre90 is as transparent as it gets and I did not notice any difference by adding it.
MUNDORF SUPREME SILVERGOLD OIL Condensateur 1000V 0.47µF La métallisation de la feuille du condensateur MCap Supreme SilverGold est composé d'Argent pur mélangé a 1% d'Or très pur. L'or Modifie la...
Le meilleur que j’ai pu écouter .un équilibre ,une douceur,aération et précision.
Excellent câble pour réaliser un câble de modulation, le mien est en fiches RCA. Le son est transparent, toutes les fréquences passent bien, c'est net et précis, merci Audiophonics !!
Jean-Pierre L.
satisfait
excellent produit. livré dans les temps. bien empaqueté
Jean-Pierre L.
satisfait
Jean-Pierre L.
satisfait
Jean-Pierre L.
satisfait
Jean-Pierre L.
satisfait
produit excellent. livré ans les temps. bien empaqueté.
Patrick D.
SMSL SU-10 DAC Symétrique 2x ES9038Pro XMOS XU316 Bluetooth 5.0 aptX HD LDAC 32bit 768kHz DSD512 MQA MQA-CD Le SMSL SU-10 est un DAC symétrique high-end, profitant d'une conception rigoureuse lui permettant de fournir une restitution sonore précise, au plus proche du...
SMSL SU-10 DAC
J'ai longtemps possédé un AURALIC VEGA de 2016 dont je fus très satisfait: dynamique, transparence, large scène sonore (son holographique), très précis mais pas analytique donc très musical....mais le SMSL SU-10 qui a la même signature sonore va encore plus loin... et d'une façon notoire (au moins 20%).
Je remercie Audiophonics pour son honnêteté puisque m'a longtemps conseiller de rester avec mon Auralic et de ne pas en changer inutilement pour un autre... mais c'était sans compter l'arrivée sur le marché du SMSL SU-10 avec un rapport qualité/prix exceptionnel.
Bernard G.
Rapport qualité prix douteux!!!
Dans la description de ce produit,il est spécifié que l'isolation est en
téflon! Or,lors de la soudure des conducteurs,cet isolant de couleur
noire s'est mis à fondre!!!! J'ai donc un doute sur le fait que cet
isolant soit en téflon!!! D'autre part,l'emplacement pour souder le
conducteur canal gauche est très mal conçu par rapport à celui du
canal droit! À ce niveau de tarif,ce n'est pas acceptable!
Très bon câble pour fabriquer un cordon de modulation RCA.
Rémi L.
A ce prix, autant passer en actif
Après l’avoir utilisé sur des colonnes Davis (passives) avec beaucoup de satisfaction en remplacement d’un Marantz, j’ai souhaité pousser mon système plus loin. J’utilise donc désormais cet ampli sur des bibliothèques DIY 2 voies actives (deux amplis donc) équipées de hauts parleurs SB Acoustic (Design inspiré des enceintes Buschardt S400MKII/A500). Le filtrage actif / Crossover est assuré par un Mini DSP NanoDigi (fonctionnement full digital) et la source étant un PC via la sortie optique. J’utilise des cordons mini-coax / SPDIF entre le DSP et les amplis. Les deux amplis sont alimentés par une alimentation unique SMPS300RS 24V qui avec ses 300W encaisse largement les deux amplis pour un rendu et une dynamique excellente avec des grave bien tenue. Sur les amplis, le câblage interne a été remplacé par du fil cuivre plaqué argent + quelques autres modifications.
Le rapport qualité prix du système en filtration active est assez incroyable et même en version d’origine en usage passif, c’est un excellent appareil que j’ai fait acheter à bon nombre d’amis qui eux-mêmes sont conquis
Bert D.
Heel handig
Voelt betrouwbaar aan vanwege stevige afwerking en prettige bediening. Lekker veel ingangen.
Bert D.
Very diverse and good looking
It's a very handsome and diverse device and above all very good sounding.
Bert D.
Good quality
Build quality is very good for its price.
Bert D.
DYNAVOX Fiches Bananes Plaquées Or Ø5mm (La paire) Ces fiches bananes Dynavox à petit prix permettent une connexion simple et rapide aux borniers de vos enceintes et amplificateurs. Les contacts sont plaqués Or afin d'assurer...
Robust
Good connecting and installation quality for little money.
Bert D.
Alright
It does the thing it has to do, without spending much money.
