Adjustable digital soldering station 80W with support
Soldering iron with LCD 60W 450°C Ø5.8mm
Reference : 11278
59,90 €tax incl.
49,92 € tax excl.
Shipping from France
Billing in France
Technical support in France
This welding station with its soldering iron is perfect for all your DIY projects and projects. The temperature can be adjusted directly at the station, from 200 to 480 ° C, allowing you to choose precisely the desired heat depending on the application. The bracket and sponge provided with it provide an ergonomic and clean workstation.
Orbeing suitable for welding electronic components to printed circuits (PCBs), it can also be used to make metallic welds a little more complex thanks to its power of 80W.
Features:
  • Digital temperature control 200 to 480 ° C
  • Temperature display on the station's LCD screen
  • Accuracy of more or less 1 ° C
  • Support for soldering iron with cleaning sponge
  • Power :80 Watts
  • Power supply: AC 220V / 50Hz
  • Supplied power cable
Dimensions / Weight:
  • Station size: 131x80x130mm
  • Weight of the station: 1,2kg
  • Color: Green / Yellow
  • Dimensions soldering iron: 190mm length / 24mm diameter Ø
  • Weight of the soldering iron: 10g
  • Cable length: 1,2m
[Img-19265-left-thickbox_default]
[Img-19266-left-thickbox_default]
