SMSL Q5 Black Amplifier STA350BW 2x 50W AKM AK5358AET sa9027 24bit 96kHz
Reference : 9984
129,90 €tax incl.
108,25 € tax excl.
Shipping from France
Billing in France
Technical support in France
With an AKM converter AK5358AET and an USB interface SA9027 embedded, the SMSL Q5 is a particularly gifted amplifier.
It incorporates an amplifier module STA350BW delivering 2x 50W under 4 Ohms and 2x 35W under 8 Ohms.
Versatile, it allows you to assign 4 sources (RCA, Coaxial S / PDIF, Optical Toslink and USB A).
It has a digital display and a remote control to be controlled with ease.
Its internal architecture as well as the choice of materials and finishes are all assets that make the Q5 an amplifier particularly effective and suitable for a large number of configurations.
Characteristics :
  • ADC AKM AK5358AET
  • Digital Amplifier STA350BW
  • S & PDIF Interface AKM AK4113VF
  • Asynchronous USB interface SA9027
  • Support for files up to 24bit 96kHz
  • Power consumption : 2x 35W under 8 Ohm, 2x 50W at 4 Ohm
  • Frequency response: 20Hz - 22kHz to +/- 3dB
  • Noise Ratio: 81dB
  • Dynamic range 102dB
  • Inputs: Stereo RCA, Coaxial S / PDIF, Optical Toslink, USB-A
  • Output Hp terminal blocks accepting banana plugs
  • Volume control
  • On / Off switch
  • Power consumption max. : 102W
  • Chassis Aluminum machined CNC anodized Black
  • Front Aluminum Anodized Black
  • Dimensions: 137x103x33mm
  • Weight: 1.1kg
  • Power supply, remote control and USB-A cable supplied
  • Compatible with Android 4.0 and higher in USB OTG
[Img-11341-left-thickbox_default]
[Img-11338-left-thickbox_default]
[Img-11339-left-thickbox_default]
[Img-11340-left-thickbox_default]
[Img-11342-left-thickbox_default]
Channel2 (Stereo)
