The NFB-1.32 family of the non-feeedback family integrates an ES9018 Sabre supporting up to 32 bits 192khz and this on all inputs thanks to the new asynchronous interface USB32 of the manufacturer (32bit / 384Khz).
NFB is the acronym for Non-feedback; technology used by Audio-Gd so as not to "color" the sound at the level of the electronics of the output stage giving you a sound of a very professional neutrality.
The 100% symmetrical and discreet design of this converter is backed by a 5 class A power supply.
24k Gold Plated RCAs and Nover (UK) capacitors have been specially manufactured on Audio-Gd specifications.
Characteristics :
Signal / noise ratio | > 120db |
Output Impedance | |
Output Level | 2.5V (RCA) |
Input sensitivity | 0.5 Vp-p (75 Ohms, Coaxial) |
Supported Systems | Windows: 44.1kHz to 192kHz |
Supported sampling rates | size = "2"> USB model: 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz DSD 64/128 DXD |
Frequency Response |
Consumption | 220-240V AC 50/60 Hz 17W |
Dimensions | 240 X 360 X 80 mm |
Weight | 5KG |
Accessories | AC power cord X1 |
Input | USB |
Input | Optical |
Input | SPDIF |
Output | RCA |
Output | ACSS |
Output | XLR |
DAC / ADC Chip | ES9018 |
Max sampling rate | 192kHz |
Color | Black |
