Elfidelity USB-MAX DAC / Headphone amplifier XMOS DSD256 PCM1795 32Bit
Elfidelity XMOS USB-MAX DAC DSD256 PCM1795 32Bit
Reference : 10722
159,00 €tax incl.
132,50 € tax excl.
Shipping from France
Billing in France
Technical support in France
Elfidelity offers a latest generation DSD 256 compatible USB DAC with unmatched specifications on the market. Here is the evolution of the USB DAC AX-MQ-9 with a USB3.0 connection.
The aluminum chassis, the circuits have been completely revised and corrected to provide immunity to noise and background noise among the tiniest at the price offered.
Equipped with a state-of-the-art XMOS XL8-TQ128 chip, the high-performance DM PCM 1795 from Burr Brown, the Elfidelity USB MAX has a sophisticated analog output that drives the most demanding headphones in the Hi-Fi industry.
The's current and revamped I / V current stage works with the 3rd generation of exclusive Elfidelity "Growler 3" based Motorola MC33078 offering an SNR of over 123Db.
Thiss OP amps benefit from the HAPS Elfidelity system, which ensures high voltage stability.
This is an undeniable advantage because, by changing the OP amps at the output to adapt the sound signature, these will always have a stable 12V voltage and high precision.
The quality of construction is a real challenge to the price offered including the best of passive components with compatibility of HD 32 bit 384Khz and native DSD 256.
Main Features :
  • DAC 32Bit 384KHZ PCM 1795.
  • USB3.0 input on XMOS chip.
  • Headphone output 16 ~ 300Ohm.
  • Dual headphone output 6.35 and 3.5mm jack.
  • DSD 256 native (11.2896Mhz).
  • Output on AOP interchangeable.
  • low Jitter of 3.3 Picoseconds.
  • Compatible with Bit Perfect ASIO 2.2. Latency 1ms.
Digital inputs and outputs:
  • Inputs USB3.0.
  • Output on optical jack 24Bit 96Khz.
Analog Outputs:
  • Stereo output on RCA CINCH.
  • Headphone output on 6.35mm and 3.5mm jacks.
Electrical characteristics and dimensions:
  • 5V DC / 2A power input (3.5mm jack): available in accessories below
  • Chassis with anti-interference mass circuit.
  • Dimensions: 165x65x25mm.
  • Power supply not supplied.
[Img-15716-left-thickbox_default]
[Img-15730-left-thickbox_default]
[Img-15731-left-thickbox_default]
[Img-15720-left-thickbox_default]
[Img-15722-left-thickbox_default]
Excellent Rapport Q/P
+ Le plus important, le son : c'est neutre, comme il se doit, aucune différence perçue avec mon interface pro. ESI
+ Décode tous les formats actuels.
- Sur le format DXD 384kHz présence de souffle, drivers à corriger je suppose, mais vu la taille des fichiers, leur rareté et leur prix, je ne l'utilise pas.
+ Très belle fabrication, très dense.
+ Aucune interférence avec les autres électroniques
+ Très compact, consomme et chauffe peu.
Le port USB des PC n'est pas assez puissant, le DAC doit être alimenté avant que les ports du PC fonctionnent.
+ "Grande prise" casque de bonne qualité avec un casque AKG.
+ Bundle complet, plug and play, avec des cables USB de belle qualité, les drivers sur CD, l'alimentation.
- Ce serait parfait si les adaptateurs secteur pouvaient se brancher sur nos prises ! je vous recommande d'acheter ou récupérer un chargeur de tablette de qualité.
+ Sur windows 10 après installation des drivers du CD le boitier est reconnu, on peut régler la taille du buffer.
+ Sur JRiver tout est possible, bit perfect ou resampling,et en DSD réception native du flux ou par dop.
+ Fonctionne parfaitement avec Volumio et Daphile. J'aime beaucoup Daphile, c'est un serveur audio jeOS headless léger, rapide et bourré d'options.
+ Bref le service rendu par rapport au prix est excellent.
+Je tiens à remercier L'équipe d'Audiophonics qui a toujours répondu rapidement à mes questions sur la boutique eBay.
This review has been posted for Elfidelity USB-MAX DAC / Headphone amplifier XMOS DSD256 PCM1795 32Bit
