SOMMERCABLE ONYX 2025 MKII Asymmetric Modulation Cable 2 x Ø4.1mm
SOMMERCABLE ONYX 2025 MKII Interconnect Cable Asymétrical Ø8.5mm
4.8 / 5
Reference : 687
2,05 €tax incl.
1,71 € tax excl.
Shipping date: 26-04-2024.
Shipping from France
Billing in France
Technical support in France
https://www.audiophonics.fr/images2/783/Onyx2025_schwarz.gifasymmetric
SOMMER CABLE - Onyx 2025 MKII
The twin...
is similar to the SESSION type by its design and quality, but the twinned conductors bring a reduction in the clutter of the sheath. Its use is recommended for the production of hi-fi cables, adapters, and for fixed wiring. It is compatible with plupart jacks and cinch connectors.
The ONYX cable consists of separable conductors. Each has an individual helical shielding of copper and is equipped with a thick insulation, coded in colors: white and red or respectively white and yellow (ONYX 2008).
Because of its small diameter, the ONYX 2008 type is predestined for use with mini jack connectors.
ADVANTAGES:
  • High flexibility due to thin strands
  • Each conductor separately insulated and shielded by helical copper winding
  • The conductors can be easily separated by hand
  • Outer sleeve of reduced diameter, advantageous for the mounting of the connectors jack or cinch
USE:
  • Wiring for asymmetric devices (keyboards)
  • Connections for hi-fi equipment
  • Manufacture of Y adapters
  • Manufacture of cables insert
<tr>Operating temperaturemin. -25 ° C
Technical characteristics:
ConstitutionTheI2YDY2x0.25mm 2
Envelope, outside diameterPVC 3.8 x 8.5 mm
AWG24
Conductor2 x 1 x 0.25 mm 2
Copper strands per core32 x 0.10 mm
Insulation of the conductorPE
Protectionhelical screen by copper wire
Optical cover90%
Operating temperaturemax. 70 ° C
Fire resistance per m0.23 kWh
Weight per m35 g
Packaging, packaging unitroll 100 m
Colorblack
Electrical Specifications:
Metric Capacity Screen / Display= "font-size: xx-small;"> 60 pF
Odometer Resistance, Conductor115 Ohm
Resistance, insulation> 1 GOhm
Diameter (mm)4.1
Length (m)Sold by length
Number of conductors2
Insulation materialOther
ShieldingYes
Section (mm²)0.25
Ground / ShieldingYes
5 reviews
Parfait très bien
This review has been posted for SOMMERCABLE ONYX 2025 MKII Asymmetric Modulation Cable 2 x Ø4.1mm
Bonne calité
Rien à redire ce câble semble de bonne qualité..
Idéal
Parfait pour recâbler une platine Vinyle. Blindage suffisant pour ne pas avoir de hum.
Excellent
Très bon cable de modulation utilisé pour recabler des platines vinyl.
Souple et facile à souder à raccorder avec des fiches rca de qualité.
De plus le prix au mètre et vraiment inintéressant.
A été utilisé pour recâbler le casque d'une proche, rien à dire fonctionne parfaitement bien et repérage par couleurs rouge et blancs. Le casque réparé étant blanc j'y ai ajouté une gaine nylon blanche avec morceaux de thermo blanc au niveaux des sorties haut parleurs et du connecteur. Que du bon !
