OYAIDE DST-75R V2 Coaxial Cable RCA SPDIF 75 Ohm 102SSC Rhodium Plated 1m
The OYAIDE DST-75R V2 cable is a very high quality 75Ω RCA coaxial cable with a unique architecture and assembled with high-end connectors. These RCA connectors feature Silver + Rhodium plating for unrivalled conductivity and transmission.
Reference : 11408
95,00 €tax incl.
79,17 € tax excl.
Shipping date: 30-04-2024.
Shipping from France
Billing in France
Technical support in France
OYAIDE DST-75R V2
The DST-75R V2 is an RCA coaxial cable developed for music lovers seeking optimum lossless quality and full-bandwidth neutrality for great musicality above all else.
Oyaide builds every cable the same way, with optimized engineering solutions applied to materials and manufacturing processes, complemented by meticulous craftsmanship.
This cable features a double layer of shielding against interference; copper foil and 102SSC braided copper, as well as insulation thanks to a "Cordell" structure. The cable conductor is made of 102SSC copper for precise, clear signal transmission. The connection to the RCA connectors is made using SS-47 acoustic solder, a lead-free silver solder.
Product typeRCA 75 Ohm coaxial cable
Cable structureSingle-strand
Conductor material102SSC Copper (1.05mm² - AWG17)
InsulationHigh-density polyethylene
ShieldingCopper foil
Contacts materialCopper
Contact platingSilver + Rhodium
Total cable diameterØ6.6mm
ColorWhite
Cable length1m
Package1x OYAIDE DST-75R V2 cable
Length (m)1.0
ShieldingYes
Section (mm²)1.05
ConnectorCoaxial
très bon câble
je viens de brancher le câble donc aucun rodage.....
il y a de la matière, une bonne scène sonore,une bonne définition et surtout tout est bien en place....c'est très droit sans froideur comme j'ai pu le constater en écoutant les électroniques accuphase...c'est délicat comme écoute à l'opposé du démonstratif....il faut dire que j'écoute principalement de la musique de chambre et de petites formations de jazz....
mais ce n'est pas le câble ultime,ce n'est que l'entrée de gamme,il a des limites comme les timbres qui pourraient être plus riches ou des basses plus profondes et des aigus filant plus haut...sa dynamique n'est pas très explosive et il se peut que sur de la musique qui demande de la pèche,il soit un peu trop sage....attention cela ne veut pas dire qu'il soit mou;il est juste posé comme une personne d'âge mûr....
mais son médium est envoutant !!!
vous pourrez écouter votre système durant de longues heures sans aucune fatigue toujours avec une grande délicatesse....
This review has been posted for OYAIDE DST-75R V2 Coaxial Cable RCA SPDIF 75 Ohm 102SSC Rhodium Plated 1m
The OYAIDE DST-75R V2 cable is a very high quality 75Ω RCA coaxial cable with a unique architecture...
