Mundorf M-Lytic Capacitors for Audio Power Supplies.
These capacitors have been designed to support the lowest ESR and ESL values in order to achieve the best possible dynamic range.
Technical specifications:
Dimensions: 25 D x 40 Hmm
Temperature range: -40ºC ... + 85ºC
Tolerance: ± 20%
Max. reverse voltage: 2V
Leakage current 5 min. @ UR: 0.007 * C [μF] * U [V] + 6mA
Leakage current 1 h @ UR: 0.15 * Leckstrom 5 min @UR
Specs .: DIN 41332 IEC 384 - 4
Insulation: Heat shrinkable tubing test voltage 3 2500 VAC
Terminals: Snap In
Mundorf M-Lytic Audio Grade Power Caps | ||||
μF | VDC | ESL nH | Ø * h | |
2200 | 25 | 10 | 15 | 22 * 30 |
15000 | 25 | 10 | 35 | 30 * 30 |
22000 | 25 | 10 | 22 | 30 * 40 |
10000 | 35 | 10 | 40 | 25 * 40 |
15000 | 35 | 10 | 26 | 30 * 40 |
22000 | 35 | 10 | 19 | 30 * 50 |
2200 | 50 | 10 | 144 | 22 * 25 |
4700 | 50 | 10 | 68 | 22 * 35 |
10000 | 50 | 10 | 32 | 30 * 40 |
15000 | 50 | 10 | 18 | 30 * 50 |
22000 | 50 | 10 | 14 | 35 * 50 |
2200 | 63 | 10 | 55 | 22 * 30 |
4700 | 63 | 10 | 32 | 25 * 50 |
10000 | 63 | 10 | 25 | 30 * 50 |
22000 | 63 | 10 | 20 | 40 * 80 |
