FURUTECH FP-209-10 (G) Spade Plug Rhodium Plated Pur Copper Ø4mm (Set x10)
Furutech FP-209-10R Spade Plug Rhodium Plated Copper Ø 4mm (Set x10)
Reference : 7331
39,90 €tax incl.
33,25 € tax excl.
Shipping date: 26-04-2024.
Shipping from France
Billing in France
Technical support in France
Ce lot de 10 pièces de fourches Furutech en cuivre pur plaqué Rhodium est une aubaine pour toute personne désireuse d'optimiser les terminaisons de ces connectiques avec un excellent produit abordable.
Caractéristiques:
  • Cuivre pur plaqué Rhodium traité avec le procédé Anti-magnétisme "Furutech Alpha α"
  • Connexion : à souder ou sertir
  • Dimensions : 8x 25 mm
  • Espacement des fourches : 4.3 mm
  • Compatible avec un câble jusqu'a 4 mm de diamètre
https://www.audiophonics.fr/images2/7331/7331_FURUTECH_FP-209-10R_1.jpg
Max cable diameter (mm)4.0
Mounting typeTo weld
ConnecticMale
ConnectorSpade
2 reviews
Best buy
The fork is very solid, you can´t climp it to a cable with normal tongs !
You have to have access to and use a screw- device - wrench.
Only the final finish can be done with strong tongs !
Otherwise it is fine product, that sounds great !
This review has been posted for FURUTECH FP-209-10 (G) Spade Plug Rhodium Plated Pur Copper Ø4mm (Set x10)
Very good quality product
I use them after crimp on cables for mount cables in power plug with rodium coatings. You have to use carefully, because the FP-209 are long and you can have about 0,5 cm of free cable (with inner isolation) to mount them in Furutech IEC power plugs. With longer free cable you can't holding whole cable in plug jaws. There limitation is only for IEC, for Schuko you have more space in power plug.
 (4)
