SOMMERCABLE STRATOS Modulation cable Asymmetric 1x0,34 mm² Ø8.5mm
SOMMERCABLE STRATOS Interconnect Cable Asymétrical Ø8.5mm
4.5 / 5
Reference : 782
17,90 €tax incl.
14,92 € tax excl.
Shipping date: 30-04-2024.
Shipping from France
Billing in France
Technical support in France
https://www.audiophonics.fr/images2/783/Stratos_anthrazit.gif
SOMMER CABLE - Stratos
Honesty is the safest guarantee ...
This becomes evident when, after a few years of service, some hi-fi cables are put under the microscope. Even very expensive phono cables are in a desolate state: porous sheath, contracted insulation, oxidized copper. The conductors are undoubtedly subjected to extreme conditions when the "boiling" transformerst extreme heat or aggressive gases. In a short time the materials are damaged, and the devaluation of the technical and electrical characteristics is programmed.
What does not happen with the STRATOS: it is not only electrically but also acoustically appropriate to the characteristics of high-end hi-fi systems. The sounds transmitted by STRATOS are distinguished by their unrivaled naturalness, fullness, lightness, discretion and absolute silence during musical breaks. Shielded with a multiple screen (braid + semiconductor), the STRATOS is perfectly protected against the problematic electromagnetic disturbances. The protective tubular braid is combined with special plastic fibers to facilitate thermal clearance, and the heat-resistant sheath ensures extreme durability. For a better conductivity, the copper cores undergo a special surface treatment. The insulation is ensured by a mixture of PE / PP with microscopic structure particularized by its durability. The STRATOS is ideal for connections between CD player / recorder DAT / DVD / preamplifier and terminal amplifier.
ADVANTAGES:
  • Lively and very natural sound
  • Multiple protection against parasitic fields BF and HF
  • Long life, durability of electrical characteristics
  • Adaptable without dito different hi-fi components
USE:
  • Phono cable for extreme requirements
Technical characteristics:
Constitution(LIHS09YHS1x0,34mm 2) DY
Envelope, diameterPVC 8.5 mm
AWG22
Conductor1 x 0.34 mm 2
Copper strands per core7 x 0.25 mm
Conductor insulationeurPE / PP
Protectionscreen by copper braid + semiconductor
Optical cover100%
Operating temperaturemin. -20 ° C
Operating temperaturemax. 80 ° C
Fire resistance per m0.25 kWh
Weight per m55 g
Packaging, packaging unitto the metere
Coloranthracite
Electrical Specifications:
Metric Capacity Screen / Display75 pF
Odometer Resistance, Conductor<53 Ohm
Resistance, insulation> 1 GOhm
Diameter (mm)8.5
Length (m)Sold by length
Number of conductors1
Insulation materialOther
ShieldingYes
Section (mm²)0.34
Ground / ShieldingYes
16 reviews
Bien
rendu naturel, sans agressivité, associé aux fiches viablue t6s.Celles-ci paraissent plus définies que les rca neutrick nf2cb2 montées sur le stratos aussi.
This review has been posted for SOMMERCABLE STRATOS Modulation cable Asymmetric 1x0,34 mm² Ø8.5mm
LIVE !
Ce qui caractérise ce câble c'est la dynamique.
Habitué des prise de sons, je retrouve cette précision du son live où ""on entend tout"...
Je redécouvre mes enregistrements presque comme en MASTER.
Aucun registre n'est mis en avant. Les timbres sont fabuleux
C'est fou toutes les parties du message sonore qui sont masqués par les autres cables.
Très beau grave et c'est très lumineux.
Au montage la tresse verte est pas simple à travailler ; mais ça va quand même !
J'ai utilisé des fiches WBT qui traînaient dans un coin de mon stock avec une soudure argent sur l'âme
Stratos pour phono
C'est le deuxième montage liaison platine phono que je réalise avec ce câble. Silencieux, parfait du moins dans cette configuration de montage où il redonne un peu de chaleur à certains vinyles qui pourraient en manquer.
Qualité, qualité, qualité
Utilisé pour réaliser deux câbles pour platine vinyle, il respire la qualité. C'est vrai que séparer la tresse de l'isolant vert est un peu pénible mais pour le reste que du bonheur. Le câble central est fin (c'est ce qui faut pour un câble phono) mais très bien sécurisé. La rigidité du cuivre à gros cristaux est perceptible lors de la mise en oeuvre. A l'écoute, c'est vrai qu'en l'absence de second blindage, à écoute à volume maximal sur bruit de fond à vide, l'oreille collée au tweeter, on entend une légère pollution du bruit "numérique" ambiant, mais c'est totalement imperceptible en condition d'écoute musicale. Associé à des fiches RCA Elecaudio RC-901, pour lesquelles le diamètre est parfait, même pas besoin de gaine.
Mieux vaut s'informer
Pour répondre à l'avis précédent, une petite recherche Google vous montre votre erreur :
https://shop.sommercable.com/en/Cables/Bulk-Cables-Audio/Hifi-Instrumentenkabel-HighEnd-SC-Stratos-Longlife-800-0056.html
 (3)
