Metal Drill Bit HSS Cobalt 5% Ø3.2mm
Metal Drill HSS Cobalt 5% Ø 3.2mm
This twist metal drill bit is made from a high speed steel alloy (HSS) and 5% Cobalt. This design ensures excellent wear resistance and protection against heat. Taking advantage of a double helix structure, the drill bit can be used longer than a conventional drill by promoting chip evacuation.
Reference : 5349
1,50 €tax incl.
1,25 € tax excl.
Shipping date: 26-04-2024.
Shipping from France
Billing in France
Technical support in France
Metal drill bit
High Speed Steel (HSS) and Cobalt 5% ⌀3.2mm
Foret à métaux HSS-Co
This twist metal drill bit is made from a high speed steel alloy (HSS) and 5% Cobalt. This design ensures excellent wear resistance and protection against heat. Taking advantage of a double helix structure, the drill bit can be used longer than a conventional drill by promoting chip evacuation. It is suitable for drilling on alloyed or non-alloy steel, stainless steel, cast steel, cast iron or heat and acid resistant metals. The drill bit is equipped with a cylindrical shank of the same diameter as the screw drills or drill stands.
Drill typeDouble twist metal drill
MaterialHigh Speed Steel (HSS) and Cobalt 5% alloy
Diameter3.2mm
Total length64.6mm
Shank typeCylindrical
Quantity1 (Unit)
Quel soulagement!
J'ai une bonne perceuse Bosh Blue et même avec ça c'était un cauchemar pour moi faire des petits trous pour des vis M3, pour mes pre amplis, amplis, dac, etc. Avec ce foret j'utilise mon Dremel et je fais des trous dans l’aluminium comme du beurre. Doux, rapide, pas de bruit pour les voisins. C'est fastoche et pratique!
This review has been posted for Metal Drill Bit HSS Cobalt 5% Ø3.2mm
This twist metal drill bit is made from a high speed steel alloy (HSS) and 5% Cobalt. This design ensures excellent wear resistance and protection...
