Metal Drill Bit HSS Cobalt 5% Ø 4.2mm
This twist metal drill bit is made from a high speed steel alloy (HSS) and 5% Cobalt. This design ensures excellent wear resistance and protection against heat. Taking advantage of a double helix structure, the drill bit can be used longer than a conventional drill by promoting chip evacuation.
Reference : 5350
1,90 €tax incl.
1,58 € tax excl.
Available
Shipping date: 25-06-2018.
Orders placed before 1pm (GMT+1) will be shipped the same day (working day).
Metal drill bit
High Speed Steel (HSS) and Cobalt 5% ⌀4.2mm
Foret à métaux HSS-Co
This twist metal drill bit is made from a high speed steel alloy (HSS) and 5% Cobalt. This design ensures excellent wear resistance and protection against heat. Taking advantage of a double helix structure, the drill bit can be used longer than a conventional drill by promoting chip evacuation. It is suitable for drilling on alloyed or non-alloy steel, stainless steel, cast steel, cast iron or heat and acid resistant metals. The drill bit is equipped with a cylindrical shank of the same diameter as the screw drills or drill stands.
Drill typeDouble twist metal drill
MaterialHigh Speed Steel (HSS) and Cobalt 5% alloy
Diameter4.2mm
Total length64.6mm
Shank typeCylindrical
Quantity1 (Unit)
Colissimo - TNT - SoColissimo
This twist metal drill bit is made from a high speed steel alloy (HSS) and 5% Cobalt. This design ensures excellent wear resistance and protection...
