SMSL sAp-10 Balanced Headphone Amplifier TPA6120A2 660W 32 Ohm Black
SMSL sAp-10 Balanced Headphone Amplifier 660W 32 Ohm Black
Reference : 12204
185,00 €tax incl.
154,17 € tax excl.
Shipping from France
Billing in France
Technical support in France
SMSL sAp-10 TPA6120A2 660mW 32 Ohm Black
Amplifier for balanced and unbalanced headphones
Front view SMSL sAp-10
High fidelity and power
The SMSL sAp-10 is a symmetrical headphone amplifier in an aluminum case with a very elegant bevelled front. Powerful and precise with two Texas Instruments TPA6120A2 chips, it provides a real easy-to-use solution with symmetrical and unbalanced input, power button, and volume control on the front panel. It will allow you to drive easily high-end headphones
The two circuits (Symmetrical and Asymmetrical) of this headphone amplifier are completely independentwhich further reduces distortion and possible noise. Every detail has been conceived with the aim of offering a very high quality device at the lowest possible price. As evidenced by its all gold-plated and resistant in time.
An audiophile quality design
Internal view of headphone amplifier sAp10
This sAp-10 has a TRIAD transformer from the USA, designed to be efficient and vibration-free. The capacitors Nichicon 33000uF audiophiles are used to filter the circuit, coupled with other PANASONIC capacitors to prevent loss or degradation of the audio signal.
The volume control chip is a well known NJW1195 for its very low distortion and to respect in all points the separation of the two channels for the balanced outputand asymmetrical output. You have a resistance switch attenuator driven by a truly high-end rotary encoder.
SMSLsAp-10 indicates its status via the only LED on the device (Façade): blue LED when non-symmetrical input is active, purple LED when balanced input is active, red LED when the device is on to go out.
Signal-to-Noise Ratio104dB
THD + N0.002%
Balanced headphone output660mW (32Ω) / 170mW (300Ω)
Headphone output power275mW (32Ω) / 48IW (300Ω)
OutputHeadphones Jack 6.35mm
Symmetrical XLR 4 pins helmet
Inputbalanced XLR 3 pins stereo
unbalanced RCA Stereo
Weight1.44kg
Dimensions205 x 155 x 47mm
Non-slip feetx4
AccessoriesPower cord
InputXLR
OutputJack 6.35mm
ClassClass A / AB
Remarquable appareil...
Voici un ampli casque avec un rapport qualité prix exceptionnel. Pour moins de 200 €, nous sommes en présence d'un coffret en aluminium parfaitement usiné, d'un électronique sophistiquée avec des composants audiophiles de premier choix, un montage symétrique et asymétrique. Bref un condensé de ce qui se fait de mieux en la matière. La puissance permet de driver les casques les plus gourmands. Quant à la musicalité du grave à l'aigu l'écoute est dynamique, fouillée et parfaitement équilibrée. Le contrôle de volume fait appel à une technologie digne d'appareil très haut de gamme avec des commutations par résistances. Le réglage est d'une très grande précision et l'équilibre des canaux parfait.
J'en suis déjà à plusieurs heures d'écoute sur différentes musiques (classique, jazz, electro, folk ...) bref je ne regrette pas mon achat. Un grand merci à Audiophonics de nous faire découvrir des appareils de cette qualité et relativement abordables financièrement.
This review has been posted for SMSL sAp-10 Balanced Headphone Amplifier TPA6120A2 660W 32 Ohm Black
