J'en ai commandé 2, reçu dans une seule et même boite, très bien protégés et emballés dans le carton à l'unité dans des plastiques hermétiques.
Très satisfait !
This FX-Audio amplifier module M-DIY-MINITDA7498,M-DIY V4 TDA7498, will allow you to simply set up your DIY amplification system. Capable of delivering 2x50W and enjoying an excellent performance of 90% thanks to its design in Class D, it will be able to adapt to many audio systems. Simple to implement, this one integrates directly on its PCB a volume controller by potentiometer. The module also proposes the addition of a balance control and a Mute / Standby system.
Flexible and adaptive, it is also possible to adjust the gain to 25.6dB, 31.6dB, 35.1dB or 37.6dB via a switch (see diagram below).
Finally, to ensure better durability and resistance to possible damage, the system offers protection against short circuits and thermal overloads.
Input | PCB Connector |
Output | Screw terminals |
Channel | 2 (Stereo) |
Class | Class D / T |
Amplifier chip | TDA7498 |
Power (W) | 50.0 |
Average votes 5.0 / 5 3 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Florian M.
antonio o.
