SURE AA-JA32472 JAB 2 Bluetooth APTX 4.0 Amplifier Class D 2.1 2x30W 8 Ohm
SURE JAB 2 Bluetooth APTX 4.0 Stereo Amplifier Class D 2.1 2x30W 8 Ohm
11332
31,90 €tax incl.
26,58 € tax excl.
Available
Shipping date: 19-01-2018.
Orders placed before 1pm (GMT+1) will be shipped the same day (working day).
Accessories
The SURE Electronics JAB2-30 is a versatile Bluetooth Stereo amplifier module that delivers 2x30W at 8 Ohm.
This new Sure JAB series offers amplification modules for nomadic use. They are optimized for Lithium battery operation. it is possible to use them in mono (BTL) mode.
The possibilities of use are great for the design of speakers and wireless speaker: yachting, small sound, jukebox, home automation, camping car, speakers In Wall and ceiling./ P>
This module can even be used for DIY design of Bluetooth wireless dock.
The power supply can be done on battery, AC adapter, solar panels (see the PDF in the download tab).
This Bluetooth amplifier will allow you to listen to your favorite songs on your Audio systems in Bluetooth type Smartphone, Tablet, iPhone, iPad ...
This amplifier is CE and FCC certified. a PDF is downloadable indicating all the possibilities offered and installation of this Bluetooth amplifier module.
See the tabdownloading at the bottom of the card.
In order for this KIT JAB 2 to workthe cable bundle optional :
AA-JA11114: (cable switch, 3.5mm jack cable, volume, cable on Molex).
This module has many possible options:
  • AA-JA11115:A supportumbrella for wall mounting, wall
  • AA-JA11112: An expansion interface with two USB ports (charge smartphone), a 3.5 jack connector and On / Off switch
Characteristics :
  • Amplifier chip : TPA3118
  • Power: 2x 30W under 8 Ohm (THD + N <1%)
  • Frequency response: 20Hz - 20kHz
  • Bluetooth Compatibility V4.0 APTX + EDR, A2DP
  • LED Status Indicators
  • Over Current and Overtemperature Protection
  • Power supply: 12 to 24 VDC
Analog Inputs:
  • Stereo input on Molex connectors
  • Bluetooth Inputs 4.0
Analog Outputs:
On Molex43025-400 / 43025-4000 connector
This amplifier is sold with the basic bundle:
A 50cm power cable, a 50cm stereo speaker cable on Molex X4 on one side and bare wire.
A bundle is available as an option with LED and potentiometer:
SURE JAB 2 AA-JA11114 product specifications: 10850
Dimensions :
  • 91.5 x 68.5mm
Included in the package:
  • A SURE amplifier module 2x30W Bluetooth 4.0
Option with JAB module not included:
Available on the card 10850.
Channel2 channels (Stéréo)
Colissimo - TNT - SoColissimo
5 étoiles méritées
Installé dans une enceinte bluetooth (DIY) et connecté sur deux HPs large bande Monacor SPH-60X avec filtre, le rendu est tout simplement parfait, le son est clair et puissant. L’appairage est rapide, sans soucis, sans code. Ce modu la s'alimente en 19V DC. C'est des alimentations faciles à trouver. Prévoir l'achat du pack de câbles (ref: SURE JAB2 AA-11114) pour le faire fonctionner.
This review has been posted for SURE AA-JA32472 JAB 2 Bluetooth APTX 4.0 Amplifier Class D 2.1 2x30W 8 Ohm
