ST400 V2 HAT Module Class D Amplifier / Headphone Amp / DAC PCM5122
4.0 / 5
10248
44,90 €tax incl.
37,42 € tax excl.
Available
Shipping date: 24-01-2018.
Orders placed before 1pm (GMT+1) will be shipped the same day (working day).
Accessories
This product is designed to make your favorite Raspberry Pi a real all-in-one multimedia, Hifi conversion based on a PCM5122 DAC is backed up by a class D amplifier 2x20W and a headphone amplifier. All in all a 3-in-1 performance and affordability.
chany of these functions can be disengaged at will according to the desired options.
Doall audio options imaginable this product will prove an absolute must have for all audio applications on Pi.
Features:/ Strong>
  • 100% Volumio compatible (Driver: IQaudio Dac plus)
  • GPIO for direct connection to Raspberry Pi B + and 2.0
  • GPIO report for other module connectors
  • 5-Port XHP Connector with 5V Aux
  • DAC Burr Brown PCM5122 (32 / 384Khz)
  • Signal to Noise Ratio (SNR): 112dB
  • THD: 0.0019%
  • Amplifier Class D TI TPA3118D2 (2x 20W at 4 Ohms)
  • Amplifier DirectPath ™ TI TPA6133A (138mW / ch under 16 ohms), Gain + 4dB
  • Input voltage: 6V to 24V DC converts to 5V 3A via step-down DC / DC regulator to power the Raspberry Pi
  • Recommended Power Supply: 12V 2A (not supplied), DC Jack 5.5 / 2.1mm (+ center)
  • Volume control via Alps potentiometer and / or via the software interface used (wired volume control in the PCM5122)
  • Outputs: RCA stereo, 3.5mm jack amplified (Headphones), Speakers via screw terminals
  • IR Receiver (38kHz)NEC code for remote control (connected to the GPIO 17)
  • Dimensions: 85x56mm (same dimensions as PI)
  • Potentiometer: 10mm (without thread), Ø 6mm notched
  • 2 jumpers, 4 spacers (M3x20mm), 8 nylon screws (M3x6mm) and button provided
Volumio
Volumio
Illustration PI delivered separately
ComponentPCM5122
Channel2 channels (Stéréo)
InputI2S
Colissimo - TNT - SoColissimo
2 reviews
Trés bon son et trés facile à utiliser
Réception du colis en 2 jours ;-). Cette carte intégrera à terme un poste audio fait maison.
Pour l'instant il est sur mon bureau et fonctionne à merveille.
Plus tard, pour la réalisation du poste, l’emplacement du potentiomètre et de la sortie casque sera un peu problématique mais sera compensé par les cavaliers permettant d'activer ou débrayer les différentes fonctions de la carte (par exemple débrayer l'ampli quant un casque est branché).
This review has been posted for ST400 V2 HAT Module Class D Amplifier / Headphone Amp / DAC PCM5122
Très bon module pour ampli connecté
C'est le deuxième module que j'achète pour faire un mini lecteur réseau connecté à moindre coût pour mes enfants:
1 Raspberry pi (+ carte µ-SD + alim)
1 module ST400
1 écran tactile 7"
1 paire d'enceinte d'occasion (j'utilise les Eltax mini, rapport qualité prix au top)
Un peu de bricolage pour habiller tout ça proprement.
Ca vous fait une mini-chaine réseau autour de 200€ pour sonoriser une chambre d'enfant avec un son de qualité (meilleur qu'une mini-chaine tout plastique du commerce) . Plus besoin de courir après les CD dans la maison: tout est dans le NAS. Chaque enfant peut écouter la musique qu'il veut, y compris des radio internet (adaptées à leur âge) à partir de 6 ans (maîtrise de la lecture pour qu'il puisse choisir lui-même sa musique dans la CD-thèque).
J'ai enlevé une étoile car le positionnement des sorties est un peu casse-tête pour l'habillage. La solution que j'ai trouvée est de dessouder le potentiomètre et le ressouder sur des fils, afin de pouvoir le positionner plus aisément. C'est d'ailleurs la solution adoptée pour le nouveau module ampli-dac audiophonic.
Puissance suffisante pour une chambre de 15m², mais pas pour sonoriser une soirée avec des copains.
Difficile de trouver mieux pour le prix !
 (3)
