AUDIO-GD NFB-11.28 MUSIC EDITION ES9028PRO DAC / Preamp DSD 32bit / 384kHz TCXO
AUDIO-GD NFB-11.28 ES9028 DAC / Preamp DSD 32bit / 384kHz TCXO
The Audio-GD NFB-11.28 is THE Swiss Army Knife for audiophiles. Combining the functions of DAC, preamplifier and headphone amplifier, it will meet most needs.
Reference : 12032
379,00 €tax incl.
315,83 € tax excl.
Shipping from France
Billing in France
Technical support in France
DAC / Preamplifier / Headphone Amplifier
Audio-GD NFB-11.28 2017
Versatility and efficiency
Featuring many new features, this new version of the acclaimed NFB11 now features a DAC SABRE ES9028Pro, a USB Amanero Combo 384, a dual-stage power supply, selectable digital filters and an MCU controller.
Qobuz test of this Audio-GD NFB-11.28
Discover by clicking on the logo the test by Qobuz of this Audio-GD: a DAC with amplifier for powerful helmet and with quality sound performances!
Logo Qobuz FR
Equipped with a USB interface Amanero Combo 384 rather than a USB32, celit offers both optimal performance and compatibility. It supports sampling rates up to 32bit / 384kHz as well as the DXD, DSD64 and DSD128 (DSD256 and DSD512 on Windows). Its design allows it to enjoy a very low jitter.
A breathtaking sound reproduction
Non-Feedback and ACSS
The NFB11.28 delivers optimum performance through carefully chosen components. In addition to supporting the DSD / DXD and sampling rates of up to 32bit / 384kHz, it benefits from the NFB (Non-Feedback) technology developed by Audio-GD on the ACSS stage.
This allows the NFB-11.28 to offer a lower color tone and consequently a faithful reproduction, a very low distortion and a great linearity. You gain in dynamics, details and neutrality.
TCXO 100MHz
With its 100MHz TCXO clock associated with the ES9028 SABRE converter, this NFB-11.28 offers an Ultra-Low jitter for ever higher performance.
Sabre ES9028Pro
The NFB-11.28 now includes an ES9028Pro DAC ESS to convert digital signals to analog. This allows output sample rate support up to 32bit / 384kHz and a Signal / Noise ratio of 118dB.
It brings significant improvements in comparison to its predecessor (ES9018) as a compensation for the harmonic distortion rate of the analog output through the 32bit processing block, an improvement in the over-sampling filters, the phase-locked loop forgreater precision or even distribution of the feed.
Audio-GD NFB 11.28 ES9028Pro
High-end components
All of the components have been carefully selected to offer a device that is as efficient as it is durable. Thus, for example, you will find an ALPS 27 potentiometer or pure copper RCA plugs.
Connectors
Input1x USB Amanero
1x Coaxial
1x Optical
Output1x RCA
1x Jack 6.35mm ACSS
S/N118dB
Output levelHeadphone : 10V RMS
Variable : 5V Max
Fixe : 2.5V RMS
Headphone output impedance2 Ohm
DAC output impedance2 Ohm
Coaxial input sensitivity0.5Vp-p (75 Ohm)
Optical sensitivity19 dBm
Frequency response20Hz - 20kHz (-0.2dB)
3Hz - 350kHz (Analog)
Sampling rateUSB : up to 384kHz
Coaxial : up to 192kHz
Optique : up to 96kHz
Divers
CompatibilityWindows
Mac
Power consumption12W
Weight2kg
Dimensions180 x 220 x 55mm
Accessoiries1x AC power cable
1x USB cable
OutputACSS
OutputJack 6.35mm
Product customization
After saving your customized product, remember to add it to your cart.
Text
loader
* required fields
6 reviews
Audio Gd
Utilisé depuis un peux plus d'un mois en tant que préamplificateur. Utilisation en coax sur mon lecteur cd Vincent, et en numérique sur mon lecteur réseau Yamaha. Ampli Yamaha AS 700. La qualité de fabrication est très très bonne, cela respire la qualité. Sur mon lecteur CD, le rendu est tout simplement magnifique. Je redecouvre mes cd avec des détails que je n'avais jamais entendu avant. Les basses sont profonde et tendue, le medium juste parfait et les aigus très precis sans être agressif. Le son retransmis est neutre, et pas coloré. J'ai modifié le type de filtrage avec les cavaliers fournis. Cette possibilité de filtrage est un grand plus, car chacun pourra trouver son réglage par rapport à son matériel et ses goûts. Par contre je n'ai pas aimé le son plus chaud que l'on peut choisir aussi via les modifications de filtrage. Moi je suis complètement ravi et satisfait de ce Dac. Il a veritablement upgrader mon système.
This review has been posted for AUDIO-GD NFB-11.28 MUSIC EDITION ES9028PRO DAC / Preamp DSD 32bit / 384kHz TCXO
Petit boitier magique...
Je recherchais un nouvel ampli casque pour mon Sennheiser HD600, et là, à moins de 400 Euros le AUDIO-GD NFB-11.28 est un petit boitier miracle, bien construit, solide, des connectiques de qualités.
A l' écoute, dynamisme et définition, le champ stéréophonique est d'une excellente facture pour le HD600.
Comme préamplificateur entre mon lecteur CD et mon ampli de puissance le DAC ES9028 TCXO de l'AUDIO-GD NFB-11.28 est parfaitement à la hauteur, voire au dessus d'autre DAC ou préamplificateur.
Je suis très content de mon investissement, livraison rapide, encore merci a l'équipe d'Audiophonics.
AUDIO-GD NFB-11.28
Only a few days in but very happy with this dac/amp. It's my first venture away from on-board pc sound and with a decent pair of headphones (DT770 custom studios) there's a marked improvement in all round clarity and smoothness, as well as having much more volume available now. I'd say the sound stage is wider now also and as there's no distortion the whole package sounds much more refined than using my pc's on-board sound chip did.
My headphones are 80ohm and in either high or low gain setting I've not had the vol dial past 12 o'clock - that is already plenty loud enough and I'm sure this amp will easily drive higher ohm headphones if I wish to purchase some in the future.
I'm on windows 10 and after first installing the drivers from Audio GD's site everything worked flawlessly. The build quality looks very good indeed and so all together, I'd thoroughly recommended this product and also Audiophonics who delivered it within a week to the UK - very good service and I would certainly shop with them again with confidence. Many thanks.
excellent produit.Utilisation en préampli,pas fini de roder à mon avis.marche fort dès le début.
nas synology
Comment se fait il que mon NAS Synology ne reconnait pas le NFB 11 ?
Bonjour,
Quelle est la longueur du câble USB utilisé ?
Et de quelle interface USB disposez vous.
N'hésitez pas à nous contacter via les formulaires du site, nous vous aiderons plus facilement.
The Audio-GD NFB-11.28 is THE Swiss Army Knife for audiophiles. Combining the functions of DAC, preamplifier and headphone amplifier, it will meet...
