Monacor SP-38 / 300NEO
Monacor SP-38/300NEO
1950
218,50 €tax incl.
182,08 € tax excl.
NEODYMIUM speakers now available in the Blue Components IMG Stage Line range with steel bowl. Particularly in combination with stable steel bowls, the advantages of these new magnet systems are very significant: 2.5 kg for the low 38 cm (15 ") and less than 2 kg for the smallest model (30 cm / 12 "): these minimum speaker weights, ideal for such professional applications, can not be further reduced.
NEODYMIUM Professional 600W Professional WooferMAX, 8 Ω
with high-power NEODYMIUM system with aluminum coil coil (CCAW) coil, bass 38 cm (15 "), perfect output for very good frequency linearity, the parameters allow unusual bass reproduction in medium-sized enclosures. In all 2-way systems with high-quality bass speakers, these bass-speaker cabinets allow you to design power cabinets, delivering optimal performance at low weight.
blank.gifImpedance (Z) blank.gif8 Ω
blank.gifResonance frequency (fs) blank.gif36 Hz
blank.gifMaximum bandwidthblank.giff3-4000 Hz
blank.gifMaximum powerblank.gif600 WMAX
blank.gifRated power (P)blank.gif300 WRMS
blank.gifAverage sound pressure (1 W / 1 m)blank.gif101 dB
blank.gifCompliance susp. (Cms)blank.gif0.28 mm / N
blank.gifMoving mass (Mms)blank.gif71 g
blank.gifMechanical overvoltage. (Qms) blank.gif4.13
blank.gifElectrical overvoltage (Qes) blank.gif0.48
blank.gifFact. total surge (Qts)blank.gif0.43
blank.gifVolume equ. (VAS) blank.gif265 l
blank.gifDC resistance. (Re) blank.gif5.4 Ω
blank.gifForce factor (BxL)blank.gif13.5 Tm
blank.gifInductance coil (The)blank.gif0.75 mH
blank.gifCoil diameter blank.gif63 mm
blank.gifCoil holderblank.gifglass fibers
blank.gifLinear excursion (X MAX)blank.gif±3.5 mm
blank.gifTransmitting surface (Sd) blank.gif880 cm2
blank.gif Magnet Weightblank.gif3.9 oz. (neodymium)
blank.gifWeightblank.gif2.5 kg
Colissimo - TNT - SoColissimo
