MONACOR SPA-110PA Speaker Driver Midbass 150W 8 Ohm 97dB Ø25cm
Monacor SPA-110PA
Reference : 8669
66,90 €tax incl.
55,75 € tax excl.
Shipping from France
Billing in France
Technical support in France
Monacor SPA-110PA
Professional loudspeaker series with cast aluminum bowl. Professional Bass Loudspeaker, 300 WMAX, 150 WRMS, 8 Ω
They equip the PAB-110MK2, PAB-112MK2 and PAB-115MK2 speakers and are characterized by Thiele and Small balanced parameters and high efficiency.
Features:
  • Medium bass driver 25 cm (10 ") with high efficiency
  • Heat resistant coil, kapton coil support
  • Wider Transmission Range
  • Low moving mass for dynamic feedback
  • Aluminum cast iron bowl
Impedance (Z) 8 Ω
Resonance frequency (fs) 61 Hz
Maximum bandwidthf3-5000 Hz
Maximum power300 WMAX
Rated power (P)150 WRMS
Average sound pressure. (1 W / m) 97 dB
Compliance susp. (Cms)0.23 mm / N
Moving mass (Mms)29 g
Coil diameter 50 mm
Coil holderKapton
Linear Excitation (XMAX) ± 4 mm
Transmitting surface (Sd) 364 cm2
Magnet Weight1.2 kg
Weight3.2 kg
Mechanical overvoltage. (Qms) 10.68
Electrical overvoltage (Qes) 0.49
Fact. total surge (Qts)0.47
Volume equ. (VAS) 38 l
DC resistance. (Re) 5.2 Ω
Force factor (BxL)10.4 Tm
Inductance coil (The)0.68 mH
https://www.audiophonics.fr/images/8669_monacor_SPA-110pa_hp_th.png
https://www.audiophonics.fr/images2/8669/8669_monacor_SPA-110pa_hp_1.jpg
https://www.audiophonics.fr/images2/8669/8669_monacor_SPA-110_hp_1.jpg
Speaker Power (W RMS)150.0
Speaker TypeMidbass
Impedance (Ω)8
Loudspeaker diameter (mm)250.0
Diaphragm typeN/A
Efficiency / Sensitivity (dB)97.0
Max Linear Excursion (Xmax) (mm)4.0
Lowest frequency (Hz)N/A
Highest frequency (Hz)5000
