Amazing quality a big difference than same production from AliExpress.
Speaker Terminals Pure Copper ⌀4.5mm
With its BP-603, Viborg offers exceptional terminal blocks for speakers, thanks to a design using particularly high-end materials.
Thus, the contact material of the terminal block is made of Pure Copper, which is not without attention. Indeed, copper is an excellent conductor, more efficient than gold. In addition, the use here of Copper, characterized by a "dew" colour, gives the connector an original and elegant aesthetic. Viborg also incorporates a brass body to properly protect the connector for longer life. On the practical side, the terminals can either be screwed or receive banana plugs.
In short, these speaker terminals are fully adapted to fit into a high-end HiFi audio system.
Conductor | Pure Copper |
Housing material | Brass |
Accepts banana plugs | Yes |
Connection | To screw / To solder (hexagonal socket screw 2mm) |
Cable diameter | 4.5mm |
Housing dimensions | 15 x 21mm |
Max panel thickness | 3.6mm |
Drilling diameter | 11.5mm |
Length | 48.8mm |
Mounting type | To weld |
Mounting type | To screw |
Connectic | Female |
Max panel thickness (mm) | 3.5 |
Accepts Banana Plugs | Yes |
Connector | Speaker terminal |
Contacts Material (Connector) | Copper |
Contacts Plating (Connector) | None |
Average votes 5.0 / 5 3 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Andrius N.
Jonas S.
Vincent M.
