Using a set of 7 wires twisted then varnished, this type of coil has a larger wire surface compared to a single-stranded conductor. This technique gives a better conductivity in the high frequencies (skin effect) and a reduced noise (varnish).
Copper coil 7 strands 3mH
Product type | Coil |
Inductance | 3mH |
Resistance | 0.55Ω |
Conductor material | Copper |
Conductors | Varnished Litz wires, 7x0.6mm |
Section | 1.98mm² |
Wire diameter | Ø1.9mm |
Tolerance | Max : 3% Typ : 1.5% |
Former material | Fiberglass reinforced PA |
Dimensions | Ø70 x 59mm |
