ELECAUDIO CS-361B Power Cable OCC PTFE 3x2.5mm² Double shielding Ø17mm
ELECAUDIO CS-361B Power Cable OCC PTFE 3x2.5mm² Ø 17mm
Reference : 7527
17,90 €tax incl.
14,92 € tax excl.
Shipping date: 30-04-2024.
Shipping from France
Billing in France
Technical support in France
The ELECAUDIO team has devised a mains cable capable of upsetting the established order as it implements materials and technologies usually reserved for products at much higher prices.
TheCS-361B is a mains cable developed according to a famous structure of Audiophile conductors namely the Litz wire, using strands of individually insulated copper wires it allows to control the skin effect of its structure.
Ainif the Phase and Neutral conductors of the CS-361B consist of 3 cores individually insulated with PTFE, these consisting of 6 strands of OFC copper surrounding an OCC core form a 2.5 mm² conductor overall.
These 3 conductors with a highly structured structure are encapsulated individually in PVC sheaths marked with a red / white / green color code. The bundles thus formed are themselves isolated from each other and kept in a distant order by means of a cotton lining which provides both suppleness and firmness to the assembly.
comesthen a first shield made from an aluminum strip, then a second one consisting of a braided copper braid preventing any EMI / RFI interference. Between these two lines of defense also comes a slip OFC copper drain wireant the cable from one end to the other to ensure linear earthing.
A thick silver-colored PVC protective sheath completes this work, and finishes making the CS-361B particularly resistant
Features:
  • 3 OFC Copper Conductors / OCC of Each Section 2.5mm²
  • PTFE insulation on main conductors
  • Exterior PVC Sheath of Forte Thickness Resistant to Wear and Shock
  • Cotton Trim
  • Double Shielding and Protection: Aluminum Sheath, Copper Braid Sheath, Copper Drain OFC
  • High-end Finish Color Silver Pearl
Specifications:
  • Main conductors :  3x (6x0.16mm OCC + 6x(6x0.16mm OFC) + PTFE)
  • Ground conductor : 126 x 0.16mm OFC
  • Diameter of Conductors + Single PVC Sheath: 5.50 mm
  • Total Cable Diameter: 17 mm
  • Bending radius : ~8cm
elecaudio cs361 b occ cable secteur
https://www.audiophonics.fr/images2/7527/7527_ELECAUDIO_CS361B_AUDIOPHILE_GRADE_POWER_CABLE_1.jpg
https://www.audiophonics.fr/images2/7527/7527_ELECAUDIO_CS361B_AUDIOPHILE_GRADE_POWER_CABLE_2.jpg
Example of embodiment:/ P>
https://www.audiophonics.fr/images2/7527/7527_ELECAUDIO_CS361B_AUDIOPHILE_GRADE_POWER_CABLE_4.jpg
Details of the structure:
https://www.audiophonics.fr/images2/7527/7527_ELECAUDIO_CS361B_AUDIOPHILE_GRADE_POWER_CABLE_3.jpg
Cable schematics
https://www.audiophonics.fr/images2/SCHEMA_PHASE.jpg
Diameter (mm)17.0
Number of conductors3
Insulation materialPTFE
ShieldingYes
Section (mm²)2.5
Ground / ShieldingYes
24 reviews
ça vaut le coup ça vaut le coup
Monté avec des bouchons Viborg aux premiers bruits la mandibule touchait le sol. On dit qu’il faut des heures de travail pour montrer ses vraies couleurs.
Je n'ai pas beaucoup d'expérience avec les câbles, mais ce fil "fait" un meilleur son.
This review has been posted for ELECAUDIO CS-361B Power Cable OCC PTFE 3x2.5mm² Double shielding Ø17mm
It actually works
I also was sceptical about what to expect but the cable actually makes a difference. It’s huge (my son was jokingly calling it the water-hose) and you have to purchase appropriate plugs.
Once connected, I immediately noticed a difference in detail and clarity. Also the spacing seems improved. The highs are a bit more prominent and that’s getting used to. But only used the cable for about 8 hours so have to see how this progresses.
Just Great
From the first minutes of powering with this cable i was a little sceptical if it's gonna be something good of him but you must put youre suspicions aside and let it play for about 30 or more hours.After 50 hours of powering it becomes revealing as hell in a good way,stage opens up,details in abundance and bass is more defined.Cable is worth every cent, you wont regret it if you go for it.
Une réelle amélioration du son
Tout d'abord impressionné par la taille de section du cable, on dirait un tuyau d'arrosage. Mais une fois monté avec des prises de qualités, les 3m de câbles ont réellement apporter un plus par rapport à mes tornado dont j'étais et je suis satisfait.
Le montage n'a pas été plus compliqué qu'avec un autre câble de moindre section
Rapport Q/P et Réalisme impressionnant
J'ai tenté ma chance sur ce câble pour remplacer le feu très célèbre (enfin sur ce site) WM Audio Tornado.
Ma configuration est la suivante :
- Platine REGA RP6 + Hana SL
- Gold Note PH5 + PSU5
- REGA brio (dernière génération)
- Mulidine Allegretto V4
J'ai confectionné le cable avec des connectiques VIBORG pur cuivre plaqué or/argent. Il alimente le REGA brio.
Tout d'abord, on constate dès les premières minutes une très belle clarté et un aigu qui respire. Il faut cependant attendre une bonne cinquantaine d'heures pour que la dynamique soit meilleur et que les basses soient mieux "digérées".
Après une bonne centaine d'heures, voilà mon avis :
Points positifs :
- Aigu très détaillé avec beaucoup d'air. J'entends plus de choses qu'avec le WM audio. Garde un souci permenant de douceur même en montant le son !
- Un médium parfait (et là c'est vraiment très impressionant, tellement réaliste sur les voix humaines piano etc...)
- Très bon graves mais on peut faire mieux selon moi.
- Bonne aération et cohérance globale.
- et encore ce médium ... pardon je l'ai déjà dit :)
- très transparent et neutre, chaque enregistrement que j'ai écouté m'a laissé une impression de réalisme et de justesse.
- Très flexible et donc pas besoin d'acheter un mètre et demie comme le WM audio.
Points négatifs :
- Il est moins dynamique que le WM Audio Tornado à niveau égale (j'écoute à environ 9h avec le WM alors que je suis à 9h45 avec le ELECAUDIO)
Avec ce câble, ELECAUDIO réalise un coup de maitre !
